#define | TMS570_SYS2_PLLCTL3_ODPLL2(val) BSP_FLD32(val,29, 31) |
#define | TMS570_SYS2_PLLCTL3_ODPLL2_GET(reg) BSP_FLD32GET(reg,29, 31) |
#define | TMS570_SYS2_PLLCTL3_ODPLL2_SET(reg, val) BSP_FLD32SET(reg, val,29, 31) |
#define | TMS570_SYS2_PLLCTL3_PLLDIV2(val) BSP_FLD32(val,24, 28) |
#define | TMS570_SYS2_PLLCTL3_PLLDIV2_GET(reg) BSP_FLD32GET(reg,24, 28) |
#define | TMS570_SYS2_PLLCTL3_PLLDIV2_SET(reg, val) BSP_FLD32SET(reg, val,24, 28) |
#define | TMS570_SYS2_PLLCTL3_REFCLKDIV2(val) BSP_FLD32(val,16, 21) |
#define | TMS570_SYS2_PLLCTL3_REFCLKDIV2_GET(reg) BSP_FLD32GET(reg,16, 21) |
#define | TMS570_SYS2_PLLCTL3_REFCLKDIV2_SET(reg, val) BSP_FLD32SET(reg, val,16, 21) |
#define | TMS570_SYS2_PLLCTL3_PLLMUL2(val) BSP_FLD32(val,0, 15) |
#define | TMS570_SYS2_PLLCTL3_PLLMUL2_GET(reg) BSP_FLD32GET(reg,0, 15) |
#define | TMS570_SYS2_PLLCTL3_PLLMUL2_SET(reg, val) BSP_FLD32SET(reg, val,0, 15) |
#define | TMS570_SYS2_STCCLKDIV_CLKDIV(val) BSP_FLD32(val,24, 26) |
#define | TMS570_SYS2_STCCLKDIV_CLKDIV_GET(reg) BSP_FLD32GET(reg,24, 26) |
#define | TMS570_SYS2_STCCLKDIV_CLKDIV_SET(reg, val) BSP_FLD32SET(reg, val,24, 26) |
#define | TMS570_SYS2_ECPCNTL_ECPSSEL BSP_BIT32(24) |
#define | TMS570_SYS2_ECPCNTL_ECPCOS BSP_BIT32(23) |
#define | TMS570_SYS2_ECPCNTL_ECPINSEL(val) BSP_FLD32(val,6, 17) |
#define | TMS570_SYS2_ECPCNTL_ECPINSEL_GET(reg) BSP_FLD32GET(reg,6, 17) |
#define | TMS570_SYS2_ECPCNTL_ECPINSEL_SET(reg, val) BSP_FLD32SET(reg, val,6, 17) |
#define | TMS570_SYS2_ECPCNTL_ECPDIV(val) BSP_FLD32(val,0, 15) |
#define | TMS570_SYS2_ECPCNTL_ECPDIV_GET(reg) BSP_FLD32GET(reg,0, 15) |
#define | TMS570_SYS2_ECPCNTL_ECPDIV_SET(reg, val) BSP_FLD32SET(reg, val,0, 15) |
#define | TMS570_SYS2_CLK2CNTRL_VCLK3R(val) BSP_FLD32(val,0, 3) |
#define | TMS570_SYS2_CLK2CNTRL_VCLK3R_GET(reg) BSP_FLD32GET(reg,0, 3) |
#define | TMS570_SYS2_CLK2CNTRL_VCLK3R_SET(reg, val) BSP_FLD32SET(reg, val,0, 3) |
#define | TMS570_SYS2_VCLKACON1_VCLKA4R(val) BSP_FLD32(val,24, 26) |
#define | TMS570_SYS2_VCLKACON1_VCLKA4R_GET(reg) BSP_FLD32GET(reg,24, 26) |
#define | TMS570_SYS2_VCLKACON1_VCLKA4R_SET(reg, val) BSP_FLD32SET(reg, val,24, 26) |
#define | TMS570_SYS2_VCLKACON1_VCLKA4_DIV_CDDIS BSP_BIT32(20) |
#define | TMS570_SYS2_VCLKACON1_VCLKA4S(val) BSP_FLD32(val,16, 19) |
#define | TMS570_SYS2_VCLKACON1_VCLKA4S_GET(reg) BSP_FLD32GET(reg,16, 19) |
#define | TMS570_SYS2_VCLKACON1_VCLKA4S_SET(reg, val) BSP_FLD32SET(reg, val,16, 19) |
#define | TMS570_SYS2_VCLKACON1_VCLKA3R(val) BSP_FLD32(val,8, 10) |
#define | TMS570_SYS2_VCLKACON1_VCLKA3R_GET(reg) BSP_FLD32GET(reg,8, 10) |
#define | TMS570_SYS2_VCLKACON1_VCLKA3R_SET(reg, val) BSP_FLD32SET(reg, val,8, 10) |
#define | TMS570_SYS2_VCLKACON1_VCLKA3_DIV_CDDIS BSP_BIT32(4) |
#define | TMS570_SYS2_VCLKACON1_VCLKA3S(val) BSP_FLD32(val,0, 3) |
#define | TMS570_SYS2_VCLKACON1_VCLKA3S_GET(reg) BSP_FLD32GET(reg,0, 3) |
#define | TMS570_SYS2_VCLKACON1_VCLKA3S_SET(reg, val) BSP_FLD32SET(reg, val,0, 3) |
#define | TMS570_SYS2_CLKSLIP_PLL1_SLIP_FILTER_COUNT(val) BSP_FLD32(val,8, 13) |
#define | TMS570_SYS2_CLKSLIP_PLL1_SLIP_FILTER_COUNT_GET(reg) BSP_FLD32GET(reg,8, 13) |
#define | TMS570_SYS2_CLKSLIP_PLL1_SLIP_FILTER_COUNT_SET(reg, val) BSP_FLD32SET(reg, val,8, 13) |
#define | TMS570_SYS2_CLKSLIP_PLL1_SLIP_FILTER_KEY(val) BSP_FLD32(val,0, 3) |
#define | TMS570_SYS2_CLKSLIP_PLL1_SLIP_FILTER_KEY_GET(reg) BSP_FLD32GET(reg,0, 3) |
#define | TMS570_SYS2_CLKSLIP_PLL1_SLIP_FILTER_KEY_SET(reg, val) BSP_FLD32SET(reg, val,0, 3) |
#define | TMS570_SYS2_EFC_CTLREG_EFC_INSTR_WEN(val) BSP_FLD32(val,0, 3) |
#define | TMS570_SYS2_EFC_CTLREG_EFC_INSTR_WEN_GET(reg) BSP_FLD32GET(reg,0, 3) |
#define | TMS570_SYS2_EFC_CTLREG_EFC_INSTR_WEN_SET(reg, val) BSP_FLD32SET(reg, val,0, 3) |
This header file provides SYS2 interfaces.
