#define | TMS570_RTP_GLBCTRL_TEST BSP_BIT32(24) |
#define | TMS570_RTP_GLBCTRL_PRESCALER(val) BSP_FLD32(val,16, 18) |
#define | TMS570_RTP_GLBCTRL_PRESCALER_GET(reg) BSP_FLD32GET(reg,16, 18) |
#define | TMS570_RTP_GLBCTRL_PRESCALER_SET(reg, val) BSP_FLD32SET(reg, val,16, 18) |
#define | TMS570_RTP_GLBCTRL_DDM_WIDTH(val) BSP_FLD32(val,12, 13) |
#define | TMS570_RTP_GLBCTRL_DDM_WIDTH_GET(reg) BSP_FLD32GET(reg,12, 13) |
#define | TMS570_RTP_GLBCTRL_DDM_WIDTH_SET(reg, val) BSP_FLD32SET(reg, val,12, 13) |
#define | TMS570_RTP_GLBCTRL_DDM_RW BSP_BIT32(11) |
#define | TMS570_RTP_GLBCTRL_TM_DDM BSP_BIT32(10) |
#define | TMS570_RTP_GLBCTRL_PW(val) BSP_FLD32(val,8, 9) |
#define | TMS570_RTP_GLBCTRL_PW_GET(reg) BSP_FLD32GET(reg,8, 9) |
#define | TMS570_RTP_GLBCTRL_PW_SET(reg, val) BSP_FLD32SET(reg, val,8, 9) |
#define | TMS570_RTP_GLBCTRL_RESET BSP_BIT32(7) |
#define | TMS570_RTP_GLBCTRL_CONTCLK BSP_BIT32(6) |
#define | TMS570_RTP_GLBCTRL_HOVF BSP_BIT32(5) |
#define | TMS570_RTP_GLBCTRL_INV_RGN BSP_BIT32(4) |
#define | TMS570_RTP_GLBCTRL_ON_OFF(val) BSP_FLD32(val,0, 3) |
#define | TMS570_RTP_GLBCTRL_ON_OFF_GET(reg) BSP_FLD32GET(reg,0, 3) |
#define | TMS570_RTP_GLBCTRL_ON_OFF_SET(reg, val) BSP_FLD32SET(reg, val,0, 3) |
#define | TMS570_RTP_TRENA_ENA4 BSP_BIT32(24) |
#define | TMS570_RTP_TRENA_ENA2 BSP_BIT32(8) |
#define | TMS570_RTP_TRENA_ENA1 BSP_BIT32(0) |
#define | TMS570_RTP_GSR_EMPTYSER BSP_BIT32(12) |
#define | TMS570_RTP_GSR_EMPTYPER BSP_BIT32(11) |
#define | TMS570_RTP_GSR_EMPTY2 BSP_BIT32(9) |
#define | TMS570_RTP_GSR_EMPTY1 BSP_BIT32(8) |
#define | TMS570_RTP_GSR_OVFPER BSP_BIT32(3) |
#define | TMS570_RTP_GSR_OVF2 BSP_BIT32(1) |
#define | TMS570_RTP_GSR_OVF1 BSP_BIT32(0) |
#define | TMS570_RTP_RAM1REGx_CPU_DMA(val) BSP_FLD32(val,29, 30) |
#define | TMS570_RTP_RAM1REGx_CPU_DMA_GET(reg) BSP_FLD32GET(reg,29, 30) |
#define | TMS570_RTP_RAM1REGx_CPU_DMA_SET(reg, val) BSP_FLD32SET(reg, val,29, 30) |
#define | TMS570_RTP_RAM1REGx_RW BSP_BIT32(28) |
#define | TMS570_RTP_RAM1REGx_BLOCKSIZE(val) BSP_FLD32(val,24, 27) |
#define | TMS570_RTP_RAM1REGx_BLOCKSIZE_GET(reg) BSP_FLD32GET(reg,24, 27) |
#define | TMS570_RTP_RAM1REGx_BLOCKSIZE_SET(reg, val) BSP_FLD32SET(reg, val,24, 27) |
#define | TMS570_RTP_RAM1REGx_STARTADDR(val) BSP_FLD32(val,0, 17) |
#define | TMS570_RTP_RAM1REGx_STARTADDR_GET(reg) BSP_FLD32GET(reg,0, 17) |
#define | TMS570_RTP_RAM1REGx_STARTADDR_SET(reg, val) BSP_FLD32SET(reg, val,0, 17) |
#define | TMS570_RTP_RAM2REGx_CPU_DMA(val) BSP_FLD32(val,29, 30) |
#define | TMS570_RTP_RAM2REGx_CPU_DMA_GET(reg) BSP_FLD32GET(reg,29, 30) |
#define | TMS570_RTP_RAM2REGx_CPU_DMA_SET(reg, val) BSP_FLD32SET(reg, val,29, 30) |
#define | TMS570_RTP_RAM2REGx_RW BSP_BIT32(28) |
#define | TMS570_RTP_RAM2REGx_BLOCKSIZE(val) BSP_FLD32(val,24, 27) |
#define | TMS570_RTP_RAM2REGx_BLOCKSIZE_GET(reg) BSP_FLD32GET(reg,24, 27) |
#define | TMS570_RTP_RAM2REGx_BLOCKSIZE_SET(reg, val) BSP_FLD32SET(reg, val,24, 27) |
#define | TMS570_RTP_RAM2REGx_STARTADDR(val) BSP_FLD32(val,0, 23) |
#define | TMS570_RTP_RAM2REGx_STARTADDR_GET(reg) BSP_FLD32GET(reg,0, 23) |
#define | TMS570_RTP_RAM2REGx_STARTADDR_SET(reg, val) BSP_FLD32SET(reg, val,0, 23) |
#define | TMS570_RTP_PERREGx_CPU_DMA(val) BSP_FLD32(val,29, 30) |
#define | TMS570_RTP_PERREGx_CPU_DMA_GET(reg) BSP_FLD32GET(reg,29, 30) |
#define | TMS570_RTP_PERREGx_CPU_DMA_SET(reg, val) BSP_FLD32SET(reg, val,29, 30) |
#define | TMS570_RTP_PERREGx_RW BSP_BIT32(28) |
#define | TMS570_RTP_PERREGx_BLOCKSIZE(val) BSP_FLD32(val,24, 27) |
#define | TMS570_RTP_PERREGx_BLOCKSIZE_GET(reg) BSP_FLD32GET(reg,24, 27) |
#define | TMS570_RTP_PERREGx_BLOCKSIZE_SET(reg, val) BSP_FLD32SET(reg, val,24, 27) |
#define | TMS570_RTP_PERREGx_STARTADDR(val) BSP_FLD32(val,0, 23) |
#define | TMS570_RTP_PERREGx_STARTADDR_GET(reg) BSP_FLD32GET(reg,0, 23) |
#define | TMS570_RTP_PERREGx_STARTADDR_SET(reg, val) BSP_FLD32SET(reg, val,0, 23) |
#define | TMS570_RTP_PCx_ENAFUNC BSP_BIT32(18) |
#define | TMS570_RTP_PCx_CLKFUNC BSP_BIT32(17) |
#define | TMS570_RTP_PCx_SYNCFUNC BSP_BIT32(16) |
#define | TMS570_RTP_PCx_DATAFUNC(val) BSP_FLD32(val,0, 15) |
#define | TMS570_RTP_PCx_DATAFUNC_GET(reg) BSP_FLD32GET(reg,0, 15) |
#define | TMS570_RTP_PCx_DATAFUNC_SET(reg, val) BSP_FLD32SET(reg, val,0, 15) |
This header file provides RTP interfaces.
