RTEMS 5.2
threadqimpl.h
1
12/*
13 * COPYRIGHT (c) 1989-2014.
14 * On-Line Applications Research Corporation (OAR).
15 *
16 * The license and distribution terms for this file may be
17 * found in the file LICENSE in this distribution or at
18 * http://www.rtems.org/license/LICENSE.
19 */
20
21#ifndef _RTEMS_SCORE_THREADQIMPL_H
22#define _RTEMS_SCORE_THREADQIMPL_H
23
24#include <rtems/score/threadq.h>
28#include <rtems/score/smp.h>
29#include <rtems/score/status.h>
30#include <rtems/score/thread.h>
32
33#if defined(RTEMS_DEBUG)
34#include <string.h>
35#endif
36
37#ifdef __cplusplus
38extern "C" {
39#endif
40
47#define THREAD_QUEUE_LINK_OF_PATH_NODE( node ) \
48 RTEMS_CONTAINER_OF( node, Thread_queue_Link, Path_node );
49
54typedef struct {
55#if !defined(RTEMS_SMP)
56 /*
57 * The struct _Thread_queue_Queue definition is independent of the RTEMS
58 * build configuration. Thus, the storage space for the SMP lock is always
59 * present. In SMP configurations, the SMP lock is contained in the
60 * Thread_queue_Queue.
61 */
62 unsigned int reserved[2];
63#endif
64
67
77 Thread_queue_Queue *queue,
78 Thread_Control *the_thread,
79 Per_CPU_Control *cpu_self,
80 Thread_queue_Context *queue_context
81);
82
92 Thread_queue_Queue *queue,
93 Thread_Control *the_thread,
94 Per_CPU_Control *cpu_self,
95 Thread_queue_Context *queue_context
96);
97
109 Thread_queue_Queue *queue,
110 Thread_Control *the_thread,
111 Per_CPU_Control *cpu_self,
112 Thread_queue_Context *queue_context
113);
114
126 Thread_queue_Queue *queue,
127 Thread_Control *the_thread,
128 Per_CPU_Control *cpu_self,
129 Thread_queue_Context *queue_context
130);
131
139
146
153 Thread_queue_Context *queue_context
154)
155{
156#if defined(RTEMS_DEBUG)
157 memset( queue_context, 0x7f, sizeof( *queue_context ) );
158#if defined(RTEMS_SMP)
159 _Chain_Initialize_node( &queue_context->Lock_context.Wait.Gate.Node );
160#endif
161 queue_context->enqueue_callout = NULL;
162 queue_context->deadlock_callout = NULL;
163#else
164 (void) queue_context;
165#endif
166}
167
179 Thread_queue_Context *queue_context,
180 States_Control thread_state
181)
182{
183 queue_context->thread_state = thread_state;
184}
185
196 Thread_queue_Context *queue_context,
198)
199{
200 queue_context->Timeout.ticks = ticks;
201}
202
213 Thread_queue_Context *queue_context,
214 const void *arg
215)
216{
217 queue_context->Timeout.arg = arg;
218}
219
230 Thread_queue_Context *queue_context,
231 Thread_queue_Enqueue_callout enqueue_callout
232)
233{
234 queue_context->enqueue_callout = enqueue_callout;
235}
236
246 Thread_queue_Context *queue_context
247)
248{
250}
251
263 Thread_queue_Context *queue_context,
265)
266{
267 queue_context->Timeout.ticks = ticks;
269}
270
282 Thread_queue_Context *queue_context,
283 const struct timespec *abstime
284)
285{
286 queue_context->Timeout.arg = abstime;
287 queue_context->enqueue_callout =
289}
290
302 Thread_queue_Context *queue_context,
303 const struct timespec *abstime
304)
305{
306 queue_context->Timeout.arg = abstime;
308}
309
325 Thread_queue_Context *queue_context,
326 Thread_queue_Deadlock_callout deadlock_callout
327)
328{
329 queue_context->deadlock_callout = deadlock_callout;
330}
331
339 Thread_queue_Context *queue_context
340)
341{
342 queue_context->Priority.update_count = 0;
343}
344
354 Thread_queue_Context *queue_context
355)
356{
357 return queue_context->Priority.update_count;
358}
359
368 Thread_queue_Context *queue_context,
369 size_t update_count
370)
371{
372 queue_context->Priority.update_count = update_count;
373}
374
384 Thread_queue_Context *queue_context,
385 Thread_Control *the_thread
386)
387{
388 size_t n;
389
390 n = queue_context->Priority.update_count;
391 _Assert( n < RTEMS_ARRAY_SIZE( queue_context->Priority.update ) );
392
393 queue_context->Priority.update_count = n + 1;
394 queue_context->Priority.update[ n ] = the_thread;
395}
396
397#define _Thread_queue_Context_ISR_disable( queue_context, level ) \
398 do { \
399 _ISR_Local_disable( level ); \
400 _ISR_lock_ISR_disable_profile( \
401 &( queue_context )->Lock_context.Lock_context \
402 ) \
403 } while ( 0 )
404
412 Thread_queue_Context *queue_context,
413 ISR_Level level
414)
415{
417 &queue_context->Lock_context.Lock_context,
418 level
419 );
420}
421
430 Thread_queue_Context *queue_context
431)
432{
434 &queue_context->Lock_context.Lock_context
435 );
436}
437
447#if defined(RTEMS_MULTIPROCESSING)
449 Thread_queue_Context *queue_context,
450 Thread_queue_MP_callout mp_callout
451)
452{
453 queue_context->mp_callout = mp_callout;
454}
455#else
456#define _Thread_queue_Context_set_MP_callout( queue_context, mp_callout ) \
457 do { \
458 (void) queue_context; \
459 } while ( 0 )
460#endif
461
462#if defined(RTEMS_SMP)
468RTEMS_INLINE_ROUTINE void _Thread_queue_Gate_close(
469 Thread_queue_Gate *gate
470)
471{
472 _Atomic_Store_uint( &gate->go_ahead, 0, ATOMIC_ORDER_RELAXED );
473}
474
481RTEMS_INLINE_ROUTINE void _Thread_queue_Gate_add(
482 Chain_Control *chain,
483 Thread_queue_Gate *gate
484)
485{
486 _Chain_Append_unprotected( chain, &gate->Node );
487}
488
494RTEMS_INLINE_ROUTINE void _Thread_queue_Gate_open(
495 Thread_queue_Gate *gate
496)
497{
498 _Atomic_Store_uint( &gate->go_ahead, 1, ATOMIC_ORDER_RELAXED );
499}
500
508RTEMS_INLINE_ROUTINE void _Thread_queue_Gate_wait(
509 Thread_queue_Gate *gate
510)
511{
512 while ( _Atomic_Load_uint( &gate->go_ahead, ATOMIC_ORDER_RELAXED ) == 0 ) {
513 /* Wait */
514 }
515}
516#endif
517
524 Thread_queue_Heads *heads
525)
526{
527#if defined(RTEMS_SMP)
528 size_t i;
529
530 for ( i = 0; i < _Scheduler_Count; ++i ) {
531 _Chain_Initialize_node( &heads->Priority[ i ].Node );
533 heads->Priority[ i ].Queue.scheduler = &_Scheduler_Table[ i ];
534 }
535#endif
536
539}
540
548 Thread_queue_Queue *queue,
549 const char *name
550)
551{
552#if defined(RTEMS_SMP)
553 _SMP_ticket_lock_Initialize( &queue->Lock );
554#endif
555 queue->heads = NULL;
556 queue->owner = NULL;
557 queue->name = name;
558}
559
568 Thread_queue_Queue *queue,
569#if defined(RTEMS_SMP) && defined(RTEMS_PROFILING)
570 SMP_lock_Stats *lock_stats,
571#endif
572 ISR_lock_Context *lock_context
573)
574{
575#if defined(RTEMS_SMP)
576 _SMP_ticket_lock_Acquire(
577 &queue->Lock,
578 lock_stats,
579 &lock_context->Lock_context.Stats_context
580 );
581#else
582 (void) queue;
583 (void) lock_context;
584#endif
585}
586
587#if defined(RTEMS_SMP) && defined( RTEMS_PROFILING )
588 #define \
589 _Thread_queue_Queue_acquire_critical( queue, lock_stats, lock_context ) \
590 _Thread_queue_Queue_do_acquire_critical( queue, lock_stats, lock_context )
591#else
592 #define \
593 _Thread_queue_Queue_acquire_critical( queue, lock_stats, lock_context ) \
594 _Thread_queue_Queue_do_acquire_critical( queue, lock_context )
595#endif
596
604 Thread_queue_Queue *queue,
605 ISR_lock_Context *lock_context
606)
607{
608#if defined(RTEMS_SMP)
609 _SMP_ticket_lock_Release(
610 &queue->Lock,
611 &lock_context->Lock_context.Stats_context
612 );
613#else
614 (void) queue;
615 (void) lock_context;
616#endif
617}
618
626 Thread_queue_Queue *queue,
627 ISR_lock_Context *lock_context
628)
629{
630 _Thread_queue_Queue_release_critical( queue, lock_context );
631 _ISR_lock_ISR_enable( lock_context );
632}
633
647 const Thread_queue_Queue *queue,
648 char *buffer,
649 size_t buffer_size,
650 Objects_Id *id
651);
652
659#if defined(RTEMS_SMP)
661 Thread_queue_Control *the_thread_queue,
662 ISR_lock_Context *lock_context
663);
664#else
666 Thread_queue_Control *the_thread_queue,
667 ISR_lock_Context *lock_context
668)
669{
670 (void) the_thread_queue;
671 (void) lock_context;
672}
673#endif
674
682 Thread_queue_Control *the_thread_queue,
683 Thread_queue_Context *queue_context
684)
685{
687 the_thread_queue,
688 &queue_context->Lock_context.Lock_context
689 );
690}
691
698#if defined(RTEMS_SMP)
700 Thread_queue_Control *the_thread_queue,
701 Thread_queue_Context *queue_context
702);
703#else
705 Thread_queue_Control *the_thread_queue,
706 Thread_queue_Context *queue_context
707)
708{
709 (void) the_thread_queue;
711}
712#endif
713
722#if defined(RTEMS_DEBUG)
723RTEMS_INLINE_ROUTINE bool _Thread_queue_Is_lock_owner(
724 const Thread_queue_Control *the_thread_queue
725)
726{
727#if defined(RTEMS_SMP)
728 return the_thread_queue->owner == _SMP_lock_Who_am_I();
729#else
730 return _ISR_Get_level() != 0;
731#endif
732}
733#endif
734
741#if defined(RTEMS_SMP)
743 Thread_queue_Control *the_thread_queue,
744 ISR_lock_Context *lock_context
745);
746#else
748 Thread_queue_Control *the_thread_queue,
749 ISR_lock_Context *lock_context
750)
751{
752 (void) the_thread_queue;
753 (void) lock_context;
754 _Assert( _Thread_queue_Is_lock_owner( the_thread_queue ) );
755}
756#endif
757
765 Thread_queue_Control *the_thread_queue,
766 Thread_queue_Context *queue_context
767)
768{
770 the_thread_queue,
771 &queue_context->Lock_context.Lock_context
772 );
773}
774
781#if defined(RTEMS_SMP)
783 Thread_queue_Control *the_thread_queue,
784 Thread_queue_Context *queue_context
785);
786#else
788 Thread_queue_Control *the_thread_queue,
789 Thread_queue_Context *queue_context
790)
791{
792 (void) the_thread_queue;
793 _Assert( _Thread_queue_Is_lock_owner( the_thread_queue ) );
795}
796#endif
797
807 Thread_queue_Control *the_thread_queue,
808 const Thread_queue_Operations *operations
809#if defined(RTEMS_MULTIPROCESSING)
810 ,
811 Thread_queue_MP_callout mp_callout
812#endif
813);
814
826#if defined(RTEMS_MULTIPROCESSING)
827 #define _Thread_queue_Dequeue( \
828 the_thread_queue, \
829 operations, \
830 mp_callout \
831 ) \
832 _Thread_queue_Do_dequeue( \
833 the_thread_queue, \
834 operations, \
835 mp_callout \
836 )
837#else
838 #define _Thread_queue_Dequeue( \
839 the_thread_queue, \
840 operations, \
841 mp_callout \
842 ) \
843 _Thread_queue_Do_dequeue( \
844 the_thread_queue, \
845 operations \
846 )
847#endif
848
927 Thread_queue_Queue *queue,
928 const Thread_queue_Operations *operations,
929 Thread_Control *the_thread,
930 Thread_queue_Context *queue_context
931);
932
933#if defined(RTEMS_SMP)
956Status_Control _Thread_queue_Enqueue_sticky(
957 Thread_queue_Queue *queue,
958 const Thread_queue_Operations *operations,
959 Thread_Control *the_thread,
960 Thread_queue_Context *queue_context
961);
962#endif
963
985 Thread_queue_Queue *queue,
986 const Thread_queue_Operations *operations,
987 Thread_Control *the_thread,
988 Thread_queue_Context *queue_context
989);
990
1006 bool unblock,
1007 Thread_queue_Queue *queue,
1008 Thread_Control *the_thread,
1009 ISR_lock_Context *lock_context
1010);
1011
1059 Thread_queue_Queue *queue,
1060 const Thread_queue_Operations *operations,
1061 Thread_Control *the_thread,
1062 Thread_queue_Context *queue_context
1063);
1064
1074void _Thread_queue_Extract( Thread_Control *the_thread );
1075
1087 Thread_Control *the_thread
1088);
1089
1107 Thread_queue_Queue *queue,
1108 Thread_queue_Heads *heads,
1109 Thread_Control *previous_owner,
1110 Thread_queue_Context *queue_context,
1111 const Thread_queue_Operations *operations
1112);
1113
1114#if defined(RTEMS_SMP)
1135void _Thread_queue_Surrender_sticky(
1136 Thread_queue_Queue *queue,
1137 Thread_queue_Heads *heads,
1138 Thread_Control *previous_owner,
1139 Thread_queue_Context *queue_context,
1140 const Thread_queue_Operations *operations
1141);
1142#endif
1143
1153 const Thread_queue_Queue *queue
1154)
1155{
1156 return queue->heads == NULL;
1157}
1158
1174 Thread_queue_Control *the_thread_queue,
1175 const Thread_queue_Operations *operations
1176)
1177{
1178 Thread_queue_Heads *heads = the_thread_queue->Queue.heads;
1179
1180 if ( heads != NULL ) {
1181 return ( *operations->first )( heads );
1182 } else {
1183 return NULL;
1184 }
1185}
1186
1198 Thread_queue_Control *the_thread_queue,
1199 const Thread_queue_Operations *operations
1200);
1201
1223typedef Thread_Control *( *Thread_queue_Flush_filter )(
1224 Thread_Control *the_thread,
1225 Thread_queue_Queue *queue,
1226 Thread_queue_Context *queue_context
1227);
1228
1239 Thread_Control *the_thread,
1240 Thread_queue_Queue *queue,
1241 Thread_queue_Context *queue_context
1242);
1243
1256 Thread_Control *the_thread,
1257 Thread_queue_Queue *queue,
1258 Thread_queue_Context *queue_context
1259);
1260
1273 Thread_Control *the_thread,
1274 Thread_queue_Queue *queue,
1275 Thread_queue_Context *queue_context
1276);
1277
1301 Thread_queue_Queue *queue,
1302 const Thread_queue_Operations *operations,
1304 Thread_queue_Context *queue_context
1305);
1306
1314 Thread_queue_Control *the_thread_queue,
1315 const char *name
1316);
1317
1318#if defined(RTEMS_SMP) && defined(RTEMS_DEBUG) && defined(RTEMS_PROFILING)
1319 #define THREAD_QUEUE_INITIALIZER( _name ) \
1320 { \
1321 .Lock_stats = SMP_LOCK_STATS_INITIALIZER( _name ), \
1322 .owner = SMP_LOCK_NO_OWNER, \
1323 .Queue = { \
1324 .Lock = SMP_TICKET_LOCK_INITIALIZER, \
1325 .heads = NULL, \
1326 .owner = NULL, \
1327 .name = _name \
1328 } \
1329 }
1330#elif defined(RTEMS_SMP) && defined(RTEMS_DEBUG)
1331 #define THREAD_QUEUE_INITIALIZER( _name ) \
1332 { \
1333 .owner = SMP_LOCK_NO_OWNER, \
1334 .Queue = { \
1335 .Lock = SMP_TICKET_LOCK_INITIALIZER, \
1336 .heads = NULL, \
1337 .owner = NULL, \
1338 .name = _name \
1339 } \
1340 }
1341#elif defined(RTEMS_SMP) && defined(RTEMS_PROFILING)
1342 #define THREAD_QUEUE_INITIALIZER( _name ) \
1343 { \
1344 .Lock_stats = SMP_LOCK_STATS_INITIALIZER( _name ), \
1345 .Queue = { \
1346 .Lock = SMP_TICKET_LOCK_INITIALIZER, \
1347 .heads = NULL, \
1348 .owner = NULL, \
1349 .name = _name \
1350 } \
1351 }
1352#elif defined(RTEMS_SMP)
1353 #define THREAD_QUEUE_INITIALIZER( _name ) \
1354 { \
1355 .Queue = { \
1356 .Lock = SMP_TICKET_LOCK_INITIALIZER, \
1357 .heads = NULL, \
1358 .owner = NULL, \
1359 .name = _name \
1360 } \
1361 }
1362#else
1363 #define THREAD_QUEUE_INITIALIZER( _name ) \
1364 { \
1365 .Queue = { \
1366 .heads = NULL, \
1367 .owner = NULL, \
1368 .name = _name \
1369 } \
1370 }
1371#endif
1372
1379 Thread_queue_Control *the_thread_queue
1380)
1381{
1382#if defined(RTEMS_SMP)
1383 _SMP_ticket_lock_Destroy( &the_thread_queue->Queue.Lock );
1384 _SMP_lock_Stats_destroy( &the_thread_queue->Lock_stats );
1385#endif
1386}
1387
1394#if defined(RTEMS_MULTIPROCESSING)
1395void _Thread_queue_MP_callout_do_nothing(
1396 Thread_Control *the_proxy,
1397 Objects_Id mp_id
1398);
1399
1406void _Thread_queue_Unblock_proxy(
1407 Thread_queue_Queue *queue,
1408 Thread_Control *the_thread
1409);
1410#endif
1411
1422#if defined(RTEMS_SMP)
1423bool _Thread_queue_Path_acquire_critical(
1424 Thread_queue_Queue *queue,
1425 Thread_Control *the_thread,
1426 Thread_queue_Context *queue_context
1427);
1428
1434void _Thread_queue_Path_release_critical(
1435 Thread_queue_Context *queue_context
1436);
1437#endif
1438
1445typedef struct {
1446 Objects_Control Object;
1447 Thread_queue_Control Wait_queue;
1449
1450#define THREAD_QUEUE_OBJECT_ASSERT( object_type, wait_queue_member, msg ) \
1451 RTEMS_STATIC_ASSERT( \
1452 offsetof( object_type, wait_queue_member ) \
1453 == offsetof( Thread_queue_Object, Wait_queue ) \
1454 && RTEMS_HAVE_MEMBER_SAME_TYPE( \
1455 object_type, \
1456 wait_queue_member, \
1457 Thread_queue_Object, \
1458 Wait_queue \
1459 ), \
1460 msg \
1461 )
1462
1463#define THREAD_QUEUE_QUEUE_TO_OBJECT( queue ) \
1464 RTEMS_CONTAINER_OF( \
1465 queue, \
1466 Thread_queue_Object, \
1467 Wait_queue.Queue \
1468 )
1469
1470extern const Thread_queue_Operations _Thread_queue_Operations_default;
1471
1472extern const Thread_queue_Operations _Thread_queue_Operations_FIFO;
1473
1474extern const Thread_queue_Operations _Thread_queue_Operations_priority;
1475
1476extern const Thread_queue_Operations _Thread_queue_Operations_priority_inherit;
1477
1484extern const char _Thread_queue_Object_name[];
1485
1495 Thread_queue_Control *the_thread_queue
1496);
1497
1500#ifdef __cplusplus
1501}
1502#endif
1503
1504#endif
1505/* end of include file */
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
Chain Handler API.
#define _Assert(_e)
Assertion similar to assert() controlled via RTEMS_DEBUG instead of NDEBUG.
Definition: assert.h:100
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
RTEMS_INLINE_ROUTINE void _Chain_Initialize_empty(Chain_Control *the_chain)
Initializes this chain as empty.
Definition: chainimpl.h:505
RTEMS_INLINE_ROUTINE void _Chain_Append_unprotected(Chain_Control *the_chain, Chain_Node *the_node)
Appends a node (unprotected).
Definition: chainimpl.h:680
RTEMS_INLINE_ROUTINE void _Chain_Initialize_node(Chain_Node *the_node)
Initializes a chain node.
Definition: chainimpl.h:122
#define _ISR_lock_ISR_enable(_context)
Restores the saved interrupt state of the ISR lock context.
Definition: isrlock.h:419
#define _ISR_lock_ISR_disable(_context)
Disables interrupts and saves the previous interrupt state in the ISR lock context.
Definition: isrlock.h:398
RTEMS_INLINE_ROUTINE void _ISR_lock_Context_set_level(ISR_lock_Context *context, ISR_Level level)
Sets the ISR level in the ISR lock context.
Definition: isrlock.h:159
#define _ISR_Get_level()
Return current interrupt level.
Definition: isrlevel.h:128
uint32_t ISR_Level
Definition: isrlevel.h:41
uint32_t Objects_Id
Definition: object.h:80
RTEMS_INLINE_ROUTINE void _Priority_Initialize_empty(Priority_Aggregation *aggregation)
Initializes the priority aggregation empty.
Definition: priorityimpl.h:211
#define _Scheduler_Count
Count of registered schedulers.
Definition: scheduler.h:325
const Scheduler_Control _Scheduler_Table[]
Registered schedulers.
uint32_t States_Control
Definition: states.h:46
RTEMS_INLINE_ROUTINE void _Thread_queue_Context_set_ISR_level(Thread_queue_Context *queue_context, ISR_Level level)
Sets the thread queue context ISR level.
Definition: threadqimpl.h:411
RTEMS_INLINE_ROUTINE Thread_Control * _Thread_queue_First_locked(Thread_queue_Control *the_thread_queue, const Thread_queue_Operations *operations)
Returns the first thread on the thread queue if it exists, otherwise NULL.
Definition: threadqimpl.h:1173
RTEMS_INLINE_ROUTINE void _Thread_queue_Release(Thread_queue_Control *the_thread_queue, Thread_queue_Context *queue_context)
Releases the thread queue control and enables interrupts.
Definition: threadqimpl.h:787
RTEMS_INLINE_ROUTINE void _Thread_queue_Context_restore_priority_updates(Thread_queue_Context *queue_context, size_t update_count)
Sets the priority update count of the thread queue context.
Definition: threadqimpl.h:367
void _Thread_queue_Add_timeout_realtime_timespec(Thread_queue_Queue *queue, Thread_Control *the_thread, Per_CPU_Control *cpu_self, Thread_queue_Context *queue_context)
Adds a monotonic timespec to the thread and sets the watchdog header to realtime.
Definition: threadqtimeout.c:110
#define _Thread_queue_Context_set_MP_callout(queue_context, mp_callout)
Sets the MP callout in the thread queue context.
Definition: threadqimpl.h:456
Thread_Control *(* Thread_queue_Flush_filter)(Thread_Control *the_thread, Thread_queue_Queue *queue, Thread_queue_Context *queue_context)
Thread queue flush filter function.
Definition: threadqimpl.h:1223
RTEMS_INLINE_ROUTINE void _Thread_queue_Acquire_critical(Thread_queue_Control *the_thread_queue, Thread_queue_Context *queue_context)
Acquires the thread queue control in a critical section.
Definition: threadqimpl.h:681
void _Thread_queue_Surrender(Thread_queue_Queue *queue, Thread_queue_Heads *heads, Thread_Control *previous_owner, Thread_queue_Context *queue_context, const Thread_queue_Operations *operations)
Surrenders the thread queue previously owned by the thread to the first enqueued thread.
Definition: threadqenqueue.c:660
RTEMS_INLINE_ROUTINE void _Thread_queue_Context_set_enqueue_timeout_monotonic_timespec(Thread_queue_Context *queue_context, const struct timespec *abstime)
Sets the enqueue callout to add an absolute monotonic timeout in timespec format.
Definition: threadqimpl.h:281
RTEMS_INLINE_ROUTINE bool _Thread_queue_Is_empty(const Thread_queue_Queue *queue)
Checks if the thread queue queue is empty.
Definition: threadqimpl.h:1152
RTEMS_INLINE_ROUTINE void _Thread_queue_Context_set_timeout_ticks(Thread_queue_Context *queue_context, Watchdog_Interval ticks)
Sets the timeout ticks in the thread queue context.
Definition: threadqimpl.h:195
RTEMS_INLINE_ROUTINE void _Thread_queue_Acquire(Thread_queue_Control *the_thread_queue, Thread_queue_Context *queue_context)
Definition: threadqimpl.h:704
void _Thread_queue_Enqueue(Thread_queue_Queue *queue, const Thread_queue_Operations *operations, Thread_Control *the_thread, Thread_queue_Context *queue_context)
Blocks the thread and places it on the thread queue.
Definition: threadqenqueue.c:380
void _Thread_queue_Add_timeout_monotonic_timespec(Thread_queue_Queue *queue, Thread_Control *the_thread, Per_CPU_Control *cpu_self, Thread_queue_Context *queue_context)
Adds a monotonic timespec to the thread and sets the watchdog header to monotonic.
Definition: threadqtimeout.c:90
RTEMS_INLINE_ROUTINE void _Thread_queue_Queue_release(Thread_queue_Queue *queue, ISR_lock_Context *lock_context)
Releases the thread queue queue and enables interrupts.
Definition: threadqimpl.h:625
RTEMS_INLINE_ROUTINE void _Thread_queue_Context_set_enqueue_timeout_ticks(Thread_queue_Context *queue_context, Watchdog_Interval ticks)
Sets the enqueue callout to add a relative monotonic timeout in ticks.
Definition: threadqimpl.h:262
RTEMS_INLINE_ROUTINE void _Thread_queue_Context_add_priority_update(Thread_queue_Context *queue_context, Thread_Control *the_thread)
Adds a priority update of the thread to the thread queue context.
Definition: threadqimpl.h:383
RTEMS_INLINE_ROUTINE void _Thread_queue_Release_critical(Thread_queue_Control *the_thread_queue, Thread_queue_Context *queue_context)
Releases the thread queue control in a critical section.
Definition: threadqimpl.h:764
void _Thread_queue_Deadlock_fatal(Thread_Control *the_thread)
Results in an INTERNAL_ERROR_THREAD_QUEUE_DEADLOCK fatal error.
Definition: threadqenqueue.c:375
void _Thread_queue_Enqueue_do_nothing_extra(Thread_queue_Queue *queue, Thread_Control *the_thread, Per_CPU_Control *cpu_self, Thread_queue_Context *queue_context)
Does nothing.
Definition: threadqenqueue.c:360
RTEMS_INLINE_ROUTINE Per_CPU_Control * _Thread_queue_Dispatch_disable(Thread_queue_Context *queue_context)
Disables dispatching in a critical section.
Definition: threadqimpl.h:429
void(* Thread_queue_Enqueue_callout)(Thread_queue_Queue *queue, Thread_Control *the_thread, struct Per_CPU_Control *cpu_self, Thread_queue_Context *queue_context)
Thread queue enqueue callout.
Definition: threadq.h:72
bool _Thread_queue_Extract_locked(Thread_queue_Queue *queue, const Thread_queue_Operations *operations, Thread_Control *the_thread, Thread_queue_Context *queue_context)
Extracts the thread from the thread queue, restores the default wait operations and restores the defa...
Definition: threadqenqueue.c:565
RTEMS_INLINE_ROUTINE void _Thread_queue_Do_release_critical(Thread_queue_Control *the_thread_queue, ISR_lock_Context *lock_context)
Checks if the thread queue control is the owner of the lock.
Definition: threadqimpl.h:747
void(* Thread_queue_Deadlock_callout)(Thread_Control *the_thread)
Thread queue deadlock callout.
Definition: threadq.h:86
void _Thread_queue_Extract_with_proxy(Thread_Control *the_thread)
Extracts the_thread from the_thread_queue.
Definition: threadqextractwithproxy.c:30
RTEMS_INLINE_ROUTINE void _Thread_queue_Queue_initialize(Thread_queue_Queue *queue, const char *name)
Initializes the thread queue queue with the given name.
Definition: threadqimpl.h:547
The special thread queue name to indicated that the thread queue is embedded in an object with identi...
Definition: threadq.c:135
RTEMS_INLINE_ROUTINE void _Thread_queue_Destroy(Thread_queue_Control *the_thread_queue)
Destroys the thread queue.
Definition: threadqimpl.h:1378
RTEMS_INLINE_ROUTINE void _Thread_queue_Context_set_enqueue_do_nothing_extra(Thread_queue_Context *queue_context)
Sets the do nothing enqueue callout in the thread queue context.
Definition: threadqimpl.h:245
RTEMS_INLINE_ROUTINE void _Thread_queue_Context_set_timeout_argument(Thread_queue_Context *queue_context, const void *arg)
Sets the timeout argument in the thread queue context.
Definition: threadqimpl.h:212
RTEMS_INLINE_ROUTINE void _Thread_queue_Context_set_deadlock_callout(Thread_queue_Context *queue_context, Thread_queue_Deadlock_callout deadlock_callout)
Sets the deadlock callout in the thread queue context.
Definition: threadqimpl.h:324
RTEMS_INLINE_ROUTINE void _Thread_queue_Context_set_enqueue_timeout_realtime_timespec(Thread_queue_Context *queue_context, const struct timespec *abstime)
Sets the enqueue callout to add an absolute realtime timeout in timespec format.
Definition: threadqimpl.h:301
RTEMS_INLINE_ROUTINE void _Thread_queue_Context_set_thread_state(Thread_queue_Context *queue_context, States_Control thread_state)
Sets the thread state for the thread to enqueue in the thread queue context.
Definition: threadqimpl.h:178
Thread_Control * _Thread_queue_Flush_status_object_was_deleted(Thread_Control *the_thread, Thread_queue_Queue *queue, Thread_queue_Context *queue_context)
Status object was deleted thread queue flush filter function.
Definition: threadqflush.c:37
RTEMS_INLINE_ROUTINE void _Thread_queue_Context_clear_priority_updates(Thread_queue_Context *queue_context)
Clears the priority update count of the thread queue context.
Definition: threadqimpl.h:338
size_t _Thread_queue_Queue_get_name_and_id(const Thread_queue_Queue *queue, char *buffer, size_t buffer_size, Objects_Id *id)
Copies the thread queue name to the specified buffer.
Definition: threadq.c:163
size_t _Thread_queue_Flush_critical(Thread_queue_Queue *queue, const Thread_queue_Operations *operations, Thread_queue_Flush_filter filter, Thread_queue_Context *queue_context)
Unblocks all threads enqueued on the thread queue.
Definition: threadqflush.c:63
void _Thread_queue_Deadlock_status(Thread_Control *the_thread)
Sets the thread wait return code to STATUS_DEADLOCK.
Definition: threadqenqueue.c:370
RTEMS_INLINE_ROUTINE void _Thread_queue_Queue_do_acquire_critical(Thread_queue_Queue *queue, ISR_lock_Context *lock_context)
Acquires the thread queue queue in a critical section.
Definition: threadqimpl.h:567
Thread_Control * _Thread_queue_Do_dequeue(Thread_queue_Control *the_thread_queue, const Thread_queue_Operations *operations)
Dequeues the first thread waiting on the thread queue and returns it.
Definition: threadqenqueue.c:742
Thread_Control * _Thread_queue_First(Thread_queue_Control *the_thread_queue, const Thread_queue_Operations *operations)
Definition: threadqfirst.c:23
void _Thread_queue_Extract(Thread_Control *the_thread)
Extracts thread from thread queue.
Definition: threadqenqueue.c:624
Thread_Control * _Thread_queue_Flush_default_filter(Thread_Control *the_thread, Thread_queue_Queue *queue, Thread_queue_Context *queue_context)
Default thread queue flush filter function.
Definition: threadqflush.c:26
void _Thread_queue_Object_initialize(Thread_queue_Control *the_thread_queue)
Initializes a thread queue embedded in an object with identifier.
Definition: threadq.c:148
RTEMS_INLINE_ROUTINE void _Thread_queue_Context_initialize(Thread_queue_Context *queue_context)
Initializes a thread queue context.
Definition: threadqimpl.h:152
RTEMS_INLINE_ROUTINE void _Thread_queue_Context_set_enqueue_callout(Thread_queue_Context *queue_context, Thread_queue_Enqueue_callout enqueue_callout)
Sets the enqueue callout in the thread queue context.
Definition: threadqimpl.h:229
void _Thread_queue_Unblock_critical(bool unblock, Thread_queue_Queue *queue, Thread_Control *the_thread, ISR_lock_Context *lock_context)
Unblocks the thread which was on the thread queue before.
Definition: threadqenqueue.c:579
void _Thread_queue_Add_timeout_ticks(Thread_queue_Queue *queue, Thread_Control *the_thread, Per_CPU_Control *cpu_self, Thread_queue_Context *queue_context)
Adds timeout ticks of the queue to the thread.
Definition: threadqtimeout.c:17
void _Thread_queue_Initialize(Thread_queue_Control *the_thread_queue, const char *name)
Initializes the thread queue control to the given name.
Definition: threadq.c:137
RTEMS_INLINE_ROUTINE size_t _Thread_queue_Context_save_priority_updates(Thread_queue_Context *queue_context)
Returns the priority update count of the thread queue context.
Definition: threadqimpl.h:353
RTEMS_INLINE_ROUTINE void _Thread_queue_Heads_initialize(Thread_queue_Heads *heads)
Initializes the thread queue heads.
Definition: threadqimpl.h:523
RTEMS_INLINE_ROUTINE void _Thread_queue_Do_acquire_critical(Thread_queue_Control *the_thread_queue, ISR_lock_Context *lock_context)
Definition: threadqimpl.h:665
RTEMS_INLINE_ROUTINE void _Thread_queue_Queue_release_critical(Thread_queue_Queue *queue, ISR_lock_Context *lock_context)
Releases the thread queue queue in a critical section.
Definition: threadqimpl.h:603
void _Thread_queue_Extract_critical(Thread_queue_Queue *queue, const Thread_queue_Operations *operations, Thread_Control *the_thread, Thread_queue_Context *queue_context)
Extracts the thread from the thread queue and unblocks it.
Definition: threadqenqueue.c:600
Thread_Control * _Thread_queue_Flush_status_unavailable(Thread_Control *the_thread, Thread_queue_Queue *queue, Thread_queue_Context *queue_context)
Status unavailable thread queue flush filter function.
Definition: threadqflush.c:50
RTEMS_INLINE_ROUTINE Per_CPU_Control * _Thread_Dispatch_disable_critical(const ISR_lock_Context *lock_context)
Disables thread dispatching inside a critical section (interrupts disabled).
Definition: threaddispatch.h:179
uint32_t Watchdog_Interval
Type is used to specify the length of intervals.
Definition: watchdogticks.h:38
Priority Handler API Implementation.
Constants and Structures Associated with the Scheduler.
Constants and Structures Related with the Thread Control Block.
SuperCore SMP Support API.
Local ISR lock context for acquire and release pairs.
Definition: isrlock.h:65
Definition: objectdata.h:39
Per CPU Core Structure.
Definition: percpu.h:347
Thread queue context for the thread queue methods.
Definition: threadq.h:198
The enqueue callout for _Thread_queue_Enqueue().
Definition: threadq.h:221
struct Thread_queue_Context::@3986 Priority
Block to manage thread priority changes due to a thread queue operation.
Invoked in case of a detected deadlock.
Definition: threadq.h:304
const void * arg
The timeout argument, e.g. pointer to struct timespec.
Definition: threadq.h:237
size_t update_count
Count of threads to update the priority via _Thread_Priority_update().
Definition: threadq.h:284
Thread_queue_Lock_context Lock_context
The lock context for the thread queue acquire and release operations.
Definition: threadq.h:203
The timeout in ticks.
Definition: threadq.h:232
The thread state for _Thread_queue_Enqueue().
Definition: threadq.h:208
Thread_Control * update[2]
Threads to update the priority via _Thread_Priority_update().
Definition: threadq.h:293
union Thread_queue_Context::@3985 Timeout
Interval to wait.
Definition: threadq.h:553
Thread_queue_Queue Queue
The actual thread queue.
Definition: threadq.h:584
ISR_lock_Context Lock_context
Definition: threadq.h:130
Does nothing.
Definition: threadqimpl.h:1445
Thread queue operations.
Definition: threadq.h:518
Thread_queue_First_operation first
Thread queue first operation.
Definition: threadq.h:546
Priority_Aggregation Queue
The actual thread priority queue.
Definition: threadq.h:338
Definition: threadq.h:402
const char * name
The thread queue name.
Definition: threadq.h:436
Thread_queue_Heads * heads
Lock to protect this thread queue.
Definition: threadq.h:426
Thread_Control * owner
The thread queue owner.
Definition: threadq.h:431
Thread queue with a layout compatible to struct _Thread_queue_Queue defined in Newlib <sys/lock....
Definition: thread.h:732
Thread queue heads.
Definition: threadq.h:360
Thread_queue_Priority_queue Priority
This is the set of threads for priority discipline waiting.
Definition: threadq.h:378
Chain_Node Free_node
A chain node to add these thread queue heads to the free chain of the thread queue heads dedicated to...
Definition: threadq.h:392
Chain_Control Free_chain
A chain with free thread queue heads providing the spare thread queue heads for a thread once it is d...
Definition: threadq.h:386
Constants and Structures Related with Thread Dispatch.
Constants and Structures Needed to Declare a Thread Queue.
Definition: chain.h:86
