RTEMS 5.2
Constants and Structures Related with Thread Dispatch. More...
| #define | RTEMS_SCORE_ROBUST_THREAD_DISPATCH |
| Enables a robust thread dispatch. More... | |
| RTEMS_INLINE_ROUTINE bool | _Thread_Dispatch_is_enabled (void) |
| Indicates if the executing thread is inside a thread dispatch critical section. More... | |
| RTEMS_INLINE_ROUTINE uint32_t | _Thread_Dispatch_get_disable_level (void) |
| Gets thread dispatch disable level. More... | |
| RTEMS_INLINE_ROUTINE void | _Thread_Dispatch_initialization (void) |
| Thread dispatch initialization. More... | |
| void | _Thread_Dispatch (void) |
| Performs a thread dispatch if necessary. More... | |
| void | _Thread_Dispatch_direct (Per_CPU_Control *cpu_self) |
| Directly do a thread dispatch. More... | |
| void | _Thread_Do_dispatch (Per_CPU_Control *cpu_self, ISR_Level level) |
| Performs a thread dispatch on the current processor. More... | |
| RTEMS_INLINE_ROUTINE Per_CPU_Control * | _Thread_Dispatch_disable_with_CPU (Per_CPU_Control *cpu_self, const ISR_lock_Context *lock_context) |
| Disables thread dispatching inside a critical section (interrupts disabled) with the current processor. More... | |
| RTEMS_INLINE_ROUTINE Per_CPU_Control * | _Thread_Dispatch_disable_critical (const ISR_lock_Context *lock_context) |
| Disables thread dispatching inside a critical section (interrupts disabled). More... | |
| RTEMS_INLINE_ROUTINE Per_CPU_Control * | _Thread_Dispatch_disable (void) |
| Disables thread dispatching. More... | |
| void | _Thread_Dispatch_enable (Per_CPU_Control *cpu_self) |
| Enables thread dispatching. More... | |
| RTEMS_INLINE_ROUTINE void | _Thread_Dispatch_unnest (Per_CPU_Control *cpu_self) |
| Unnests thread dispatching. More... | |
| RTEMS_INLINE_ROUTINE void | _Thread_Dispatch_request (Per_CPU_Control *cpu_self, Per_CPU_Control *cpu_target) |
| Requests a thread dispatch on the target processor. More... | |
