RTEMS 5.2
threaddispatch.h
1
9/*
10 * COPYRIGHT (c) 1989-2009.
11 * On-Line Applications Research Corporation (OAR).
12 *
13 * The license and distribution terms for this file may be
14 * found in the file LICENSE in this distribution or at
15 * http://www.rtems.org/license/LICENSE.
16 */
17
18#ifndef _RTEMS_SCORE_THREADDISPATCH_H
19#define _RTEMS_SCORE_THREADDISPATCH_H
20
21#include <rtems/score/percpu.h>
22#include <rtems/score/isrlock.h>
24
25#ifdef __cplusplus
26extern "C" {
27#endif /* __cplusplus */
28
35#if defined(RTEMS_SMP) || ( CPU_ENABLE_ROBUST_THREAD_DISPATCH == TRUE )
44#define RTEMS_SCORE_ROBUST_THREAD_DISPATCH
45#endif
46
56{
57 bool enabled;
58
59#if defined(RTEMS_SMP)
60 ISR_Level level;
61
62 _ISR_Local_disable( level );
63#endif
64
65 enabled = _Thread_Dispatch_disable_level == 0;
66
67#if defined(RTEMS_SMP)
68 _ISR_Local_enable( level );
69#endif
70
71 return enabled;
72}
73
80{
81 return _Thread_Dispatch_disable_level;
82}
83
90{
91 _Thread_Dispatch_disable_level = 1;
92}
93
111void _Thread_Dispatch( void );
112
126
140void _Thread_Do_dispatch( Per_CPU_Control *cpu_self, ISR_Level level );
141
153 Per_CPU_Control *cpu_self,
154 const ISR_lock_Context *lock_context
155)
156{
157 uint32_t disable_level;
158
159 disable_level = cpu_self->thread_dispatch_disable_level;
160 _Profiling_Thread_dispatch_disable_critical(
161 cpu_self,
162 disable_level,
163 lock_context
164 );
165 cpu_self->thread_dispatch_disable_level = disable_level + 1;
166
167 return cpu_self;
168}
169
180 const ISR_lock_Context *lock_context
181)
182{
183 return _Thread_Dispatch_disable_with_CPU( _Per_CPU_Get(), lock_context );
184}
185
192{
193 Per_CPU_Control *cpu_self;
194 ISR_lock_Context lock_context;
195
196#if defined( RTEMS_SMP ) || defined( RTEMS_PROFILING )
197 _ISR_lock_ISR_disable( &lock_context );
198#endif
199
200 cpu_self = _Thread_Dispatch_disable_critical( &lock_context );
201
202#if defined( RTEMS_SMP ) || defined( RTEMS_PROFILING )
203 _ISR_lock_ISR_enable( &lock_context );
204#endif
205
206 return cpu_self;
207}
208
217
224{
225 _Assert( cpu_self->thread_dispatch_disable_level > 0 );
227}
228
236 Per_CPU_Control *cpu_self,
237 Per_CPU_Control *cpu_target
238)
239{
240#if defined( RTEMS_SMP )
241 if ( cpu_self == cpu_target ) {
242 cpu_self->dispatch_necessary = true;
243 } else {
244 _Atomic_Fetch_or_ulong( &cpu_target->message, 0, ATOMIC_ORDER_RELEASE );
245 _CPU_SMP_Send_interrupt( _Per_CPU_Get_index( cpu_target ) );
246 }
247#else
248 cpu_self->dispatch_necessary = true;
249 (void) cpu_target;
250#endif
251}
252
255#ifdef __cplusplus
256}
257#endif /* __cplusplus */
258
259#endif /* _RTEMS_SCORE_THREADDISPATCH_H */
#define _Assert(_e)
Assertion similar to assert() controlled via RTEMS_DEBUG instead of NDEBUG.
Definition: assert.h:100
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
#define _ISR_lock_ISR_enable(_context)
Restores the saved interrupt state of the ISR lock context.
Definition: isrlock.h:419
#define _ISR_lock_ISR_disable(_context)
Disables interrupts and saves the previous interrupt state in the ISR lock context.
Definition: isrlock.h:398
#define _ISR_Local_disable(_level)
Disables interrupts on this processor.
Definition: isrlevel.h:57
#define _ISR_Local_enable(_level)
Enables interrupts on this processor.
Definition: isrlevel.h:74
uint32_t ISR_Level
Definition: isrlevel.h:41
RTEMS_INLINE_ROUTINE Per_CPU_Control * _Thread_Dispatch_disable_with_CPU(Per_CPU_Control *cpu_self, const ISR_lock_Context *lock_context)
Disables thread dispatching inside a critical section (interrupts disabled) with the current processo...
Definition: threaddispatch.h:152
RTEMS_INLINE_ROUTINE Per_CPU_Control * _Thread_Dispatch_disable(void)
Disables thread dispatching.
Definition: threaddispatch.h:191
void _Thread_Dispatch(void)
Performs a thread dispatch if necessary.
Definition: threaddispatch.c:331
RTEMS_INLINE_ROUTINE void _Thread_Dispatch_request(Per_CPU_Control *cpu_self, Per_CPU_Control *cpu_target)
Requests a thread dispatch on the target processor.
Definition: threaddispatch.h:235
RTEMS_INLINE_ROUTINE uint32_t _Thread_Dispatch_get_disable_level(void)
Gets thread dispatch disable level.
Definition: threaddispatch.h:79
RTEMS_INLINE_ROUTINE Per_CPU_Control * _Thread_Dispatch_disable_critical(const ISR_lock_Context *lock_context)
Disables thread dispatching inside a critical section (interrupts disabled).
Definition: threaddispatch.h:179
RTEMS_INLINE_ROUTINE void _Thread_Dispatch_unnest(Per_CPU_Control *cpu_self)
Unnests thread dispatching.
Definition: threaddispatch.h:223
RTEMS_INLINE_ROUTINE bool _Thread_Dispatch_is_enabled(void)
Indicates if the executing thread is inside a thread dispatch critical section.
Definition: threaddispatch.h:55
void _Thread_Dispatch_enable(Per_CPU_Control *cpu_self)
Enables thread dispatching.
Definition: threaddispatch.c:362
void _Thread_Dispatch_direct(Per_CPU_Control *cpu_self)
Directly do a thread dispatch.
Definition: threaddispatch.c:350
RTEMS_INLINE_ROUTINE void _Thread_Dispatch_initialization(void)
Thread dispatch initialization.
Definition: threaddispatch.h:89
void _Thread_Do_dispatch(Per_CPU_Control *cpu_self, ISR_Level level)
Performs a thread dispatch on the current processor.
Definition: threaddispatch.c:259
ISR Locks.
Profiling Support API.
Local ISR lock context for acquire and release pairs.
Definition: isrlock.h:65
Per CPU Core Structure.
Definition: percpu.h:347
volatile uint32_t thread_dispatch_disable_level
The thread dispatch critical section nesting counter which is used to prevent context switches at ino...
Definition: percpu.h:385
volatile bool dispatch_necessary
This is set to true when this processor needs to run the thread dispatcher.
Definition: percpu.h:400
