RTEMS 5.2
threadsup.h
1
9/*
10 * COPYRIGHT (c) 1989-2014.
11 * On-Line Applications Research Corporation (OAR).
12 *
13 * The license and distribution terms for this file may be
14 * found in the file LICENSE in this distribution or at
15 * http://www.rtems.org/license/LICENSE.
16 */
17
18#ifndef _RTEMS_POSIX_THREADSUP_H
19#define _RTEMS_POSIX_THREADSUP_H
20
21#include <rtems/score/thread.h>
23
24#include <pthread.h>
25#include <signal.h>
26
34#ifdef __cplusplus
35extern "C" {
36#endif
37
38#if defined(RTEMS_POSIX_API)
43typedef struct {
47 struct {
49 Thread_Control *thread;
50
55 Watchdog_Control Timer;
56
61 Priority_Node Low_priority;
62
66 struct timespec sched_ss_repl_period;
67
71 struct timespec sched_ss_init_budget;
72
78 int sched_ss_max_repl;
79 } Sporadic;
80
82 sigset_t signals_unblocked;
84 sigset_t signals_pending;
85
89 Thread_Action Signal_action;
90} POSIX_API_Control;
91#endif
92
95#ifdef __cplusplus
96}
97#endif
98
99#endif
100/* end of include file */
Constants and Structures Associated with Watchdog Timers.
POSIX Threads Private Support.
Constants and Structures Related with the Thread Control Block.
The priority node to build up a priority aggregation.
Definition: priority.h:98
Thread action.
Definition: thread.h:640
The control block used to manage each watchdog timer.
Definition: watchdog.h:90
Definition: thread.h:732
