RTEMS 5.2
cpu.h
1
10/*
11 *
12 *
13 * COPYRIGHT (c) 1989-2006. On-Line Applications Research Corporation (OAR).
14 *
15 * This file is based on the SPARC cpu.h file. Modifications are made
16 * to support the SPARC64 processor.
17 * COPYRIGHT (c) 2010. Gedare Bloom.
18 *
19 * The license and distribution terms for this file may be
20 * found in the file LICENSE in this distribution or at
21 * http://www.rtems.org/license/LICENSE.
22 */
23
24#ifndef _RTEMS_SCORE_CPU_H
25#define _RTEMS_SCORE_CPU_H
26
27#ifdef __cplusplus
28extern "C" {
29#endif
30
32#include <rtems/score/sparc64.h>
33
34/* conditional compilation parameters */
35
36/*
37 * Does the CPU follow the simple vectored interrupt model?
38 *
39 * If TRUE, then RTEMS allocates the vector table it internally manages.
40 * If FALSE, then the BSP is assumed to allocate and manage the vector
41 * table
42 *
43 * SPARC Specific Information:
44 *
45 * XXX document implementation including references if appropriate
46 */
47#define CPU_SIMPLE_VECTORED_INTERRUPTS TRUE
48
49/*
50 * Does the RTEMS invoke the user's ISR with the vector number and
51 * a pointer to the saved interrupt frame (1) or just the vector
52 * number (0)?
53 */
54
55#define CPU_ISR_PASSES_FRAME_POINTER FALSE
56
57/*
58 * Does the CPU have hardware floating point?
59 *
60 * If TRUE, then the FLOATING_POINT task attribute is supported.
61 * If FALSE, then the FLOATING_POINT task attribute is ignored.
62 */
63
64#if ( SPARC_HAS_FPU == 1 )
65#define CPU_HARDWARE_FP TRUE
66#else
67#define CPU_HARDWARE_FP FALSE
68#endif
69#define CPU_SOFTWARE_FP FALSE
70
71/*
72 * Are all tasks FLOATING_POINT tasks implicitly?
73 *
74 * If TRUE, then the FLOATING_POINT task attribute is assumed.
75 * If FALSE, then the FLOATING_POINT task attribute is followed.
76 */
77
78#define CPU_ALL_TASKS_ARE_FP FALSE
79
80/*
81 * Should the IDLE task have a floating point context?
82 *
83 * If TRUE, then the IDLE task is created as a FLOATING_POINT task
84 * and it has a floating point context which is switched in and out.
85 * If FALSE, then the IDLE task does not have a floating point context.
86 */
87
88#define CPU_IDLE_TASK_IS_FP FALSE
89
90/*
91 * Should the saving of the floating point registers be deferred
92 * until a context switch is made to another different floating point
93 * task?
94 *
95 * If TRUE, then the floating point context will not be stored until
96 * necessary. It will remain in the floating point registers and not
97 * disturned until another floating point task is switched to.
98 *
99 * If FALSE, then the floating point context is saved when a floating
100 * point task is switched out and restored when the next floating point
101 * task is restored. The state of the floating point registers between
102 * those two operations is not specified.
103 */
104
105#define CPU_USE_DEFERRED_FP_SWITCH TRUE
106
107#define CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE
108
109/*
110 * Does the stack grow up (toward higher addresses) or down
111 * (toward lower addresses)?
112 *
113 * If TRUE, then the grows upward.
114 * If FALSE, then the grows toward smaller addresses.
115 *
116 * The stack grows to lower addresses on the SPARC.
117 */
118
119#define CPU_STACK_GROWS_UP FALSE
120
121/* FIXME: Is this the right value? */
122#define CPU_CACHE_LINE_BYTES 32
123
124/*
125 * The following is the variable attribute used to force alignment
126 * of critical data structures. On some processors it may make
127 * sense to have these aligned on tighter boundaries than
128 * the minimum requirements of the compiler in order to have as
129 * much of the critical data area as possible in a cache line.
130 *
131 * The SPARC does not appear to have particularly strict alignment
132 * requirements. This value (16) was chosen to take advantages of caches.
133 *
134 * SPARC 64 requirements on floating point alignment is at least 8,
135 * and is 16 if quad-word fp instructions are available (e.g. LDQF).
136 */
137
138#define CPU_STRUCTURE_ALIGNMENT RTEMS_ALIGNED( 16 )
139
140/*
141 * The following defines the number of bits actually used in the
142 * interrupt field of the task mode. How those bits map to the
143 * CPU interrupt levels is defined by the routine _CPU_ISR_Set_level().
144 *
145 * The SPARC v9 has 16 interrupt levels in the PIL field of the PSR.
146 */
147
148#define CPU_MODES_INTERRUPT_MASK 0x0000000F
149
150#define CPU_MAXIMUM_PROCESSORS 32
151
152/*
153 * This structure represents the organization of the minimum stack frame
154 * for the SPARC. More framing information is required in certain situaions
155 * such as when there are a large number of out parameters or when the callee
156 * must save floating point registers.
157 */
158
159#ifndef ASM
160
161typedef struct {
162 uint64_t l0;
163 uint64_t l1;
164 uint64_t l2;
165 uint64_t l3;
166 uint64_t l4;
167 uint64_t l5;
168 uint64_t l6;
169 uint64_t l7;
170 uint64_t i0;
171 uint64_t i1;
172 uint64_t i2;
173 uint64_t i3;
174 uint64_t i4;
175 uint64_t i5;
176 uint64_t i6_fp;
177 uint64_t i7;
178 void *structure_return_address;
179 /*
180 * The following are for the callee to save the register arguments in
181 * should this be necessary.
182 */
183 uint64_t saved_arg0;
184 uint64_t saved_arg1;
185 uint64_t saved_arg2;
186 uint64_t saved_arg3;
187 uint64_t saved_arg4;
188 uint64_t saved_arg5;
189 uint64_t pad0;
191
192#endif /* !ASM */
193
194#define CPU_STACK_FRAME_L0_OFFSET 0x00
195#define CPU_STACK_FRAME_L1_OFFSET 0x08
196#define CPU_STACK_FRAME_L2_OFFSET 0x10
197#define CPU_STACK_FRAME_L3_OFFSET 0x18
198#define CPU_STACK_FRAME_L4_OFFSET 0x20
199#define CPU_STACK_FRAME_L5_OFFSET 0x28
200#define CPU_STACK_FRAME_L6_OFFSET 0x30
201#define CPU_STACK_FRAME_L7_OFFSET 0x38
202#define CPU_STACK_FRAME_I0_OFFSET 0x40
203#define CPU_STACK_FRAME_I1_OFFSET 0x48
204#define CPU_STACK_FRAME_I2_OFFSET 0x50
205#define CPU_STACK_FRAME_I3_OFFSET 0x58
206#define CPU_STACK_FRAME_I4_OFFSET 0x60
207#define CPU_STACK_FRAME_I5_OFFSET 0x68
208#define CPU_STACK_FRAME_I6_FP_OFFSET 0x70
209#define CPU_STACK_FRAME_I7_OFFSET 0x78
210#define CPU_STRUCTURE_RETURN_ADDRESS_OFFSET 0x80
211#define CPU_STACK_FRAME_SAVED_ARG0_OFFSET 0x88
212#define CPU_STACK_FRAME_SAVED_ARG1_OFFSET 0x90
213#define CPU_STACK_FRAME_SAVED_ARG2_OFFSET 0x98
214#define CPU_STACK_FRAME_SAVED_ARG3_OFFSET 0xA0
215#define CPU_STACK_FRAME_SAVED_ARG4_OFFSET 0xA8
216#define CPU_STACK_FRAME_SAVED_ARG5_OFFSET 0xB0
217#define CPU_STACK_FRAME_PAD0_OFFSET 0xB8
218
219#define SPARC64_MINIMUM_STACK_FRAME_SIZE 0xC0
220
221/*
222 * Contexts
223 *
224 * Generally there are 2 types of context to save.
225 * 1. Interrupt registers to save
226 * 2. Task level registers to save
227 *
228 * This means we have the following 3 context items:
229 * 1. task level context stuff:: Context_Control
230 * 2. floating point task stuff:: Context_Control_fp
231 * 3. special interrupt level context :: Context_Control_interrupt
232 *
233 * On the SPARC, we are relatively conservative in that we save most
234 * of the CPU state in the context area. The ET (enable trap) bit and
235 * the CWP (current window pointer) fields of the PSR are considered
236 * system wide resources and are not maintained on a per-thread basis.
237 */
238
239#ifndef ASM
240
241typedef struct {
242 uint64_t g1;
243 uint64_t g2;
244 uint64_t g3;
245 uint64_t g4;
246 uint64_t g5;
247 uint64_t g6;
248 uint64_t g7;
249
250 uint64_t l0;
251 uint64_t l1;
252 uint64_t l2;
253 uint64_t l3;
254 uint64_t l4;
255 uint64_t l5;
256 uint64_t l6;
257 uint64_t l7;
258
259 uint64_t i0;
260 uint64_t i1;
261 uint64_t i2;
262 uint64_t i3;
263 uint64_t i4;
264 uint64_t i5;
265 uint64_t i6_fp;
266 uint64_t i7;
267
268 uint64_t o0;
269 uint64_t o1;
270 uint64_t o2;
271 uint64_t o3;
272 uint64_t o4;
273 uint64_t o5;
274 uint64_t o6_sp;
275 uint64_t o7;
276
277 uint32_t isr_dispatch_disable;
278 uint32_t pad;
280
281#define _CPU_Context_Get_SP( _context ) \
282 (_context)->o6_sp
283
284#endif /* ASM */
285
286/*
287 * Offsets of fields with Context_Control for assembly routines.
288 */
289
290#define G1_OFFSET 0x00
291#define G2_OFFSET 0x08
292#define G3_OFFSET 0x10
293#define G4_OFFSET 0x18
294#define G5_OFFSET 0x20
295#define G6_OFFSET 0x28
296#define G7_OFFSET 0x30
297
298#define L0_OFFSET 0x38
299#define L1_OFFSET 0x40
300#define L2_OFFSET 0x48
301#define L3_OFFSET 0x50
302#define L4_OFFSET 0x58
303#define L5_OFFSET 0x60
304#define L6_OFFSET 0x68
305#define L7_OFFSET 0x70
306
307#define I0_OFFSET 0x78
308#define I1_OFFSET 0x80
309#define I2_OFFSET 0x88
310#define I3_OFFSET 0x90
311#define I4_OFFSET 0x98
312#define I5_OFFSET 0xA0
313#define I6_FP_OFFSET 0xA8
314#define I7_OFFSET 0xB0
315
316#define O0_OFFSET 0xB8
317#define O1_OFFSET 0xC0
318#define O2_OFFSET 0xC8
319#define O3_OFFSET 0xD0
320#define O4_OFFSET 0xD8
321#define O5_OFFSET 0xE0
322#define O6_SP_OFFSET 0xE8
323#define O7_OFFSET 0xF0
324
325#define ISR_DISPATCH_DISABLE_STACK_OFFSET 0xF8
326#define ISR_PAD_OFFSET 0xFC
327
328/*
329 * The floating point context area.
330 */
331
332#ifndef ASM
333
334typedef struct {
335 double f0; /* f0-f1 */
336 double f2; /* f2-f3 */
337 double f4; /* f4-f5 */
338 double f6; /* f6-f7 */
339 double f8; /* f8-f9 */
340 double f10; /* f10-f11 */
341 double f12; /* f12-f13 */
342 double f14; /* f14-f15 */
343 double f16; /* f16-f17 */
344 double f18; /* f18-f19 */
345 double f20; /* f20-f21 */
346 double f22; /* f22-f23 */
347 double f24; /* f24-f25 */
348 double f26; /* f26-f27 */
349 double f28; /* f28-f29 */
350 double f30; /* f30-f31 */
351 double f32;
352 double f34;
353 double f36;
354 double f38;
355 double f40;
356 double f42;
357 double f44;
358 double f46;
359 double f48;
360 double f50;
361 double f52;
362 double f54;
363 double f56;
364 double f58;
365 double f60;
366 double f62;
367 uint64_t fsr;
369
370#endif /* !ASM */
371
372/*
373 * Offsets of fields with Context_Control_fp for assembly routines.
374 */
375
376#define FO_OFFSET 0x00
377#define F2_OFFSET 0x08
378#define F4_OFFSET 0x10
379#define F6_OFFSET 0x18
380#define F8_OFFSET 0x20
381#define F1O_OFFSET 0x28
382#define F12_OFFSET 0x30
383#define F14_OFFSET 0x38
384#define F16_OFFSET 0x40
385#define F18_OFFSET 0x48
386#define F2O_OFFSET 0x50
387#define F22_OFFSET 0x58
388#define F24_OFFSET 0x60
389#define F26_OFFSET 0x68
390#define F28_OFFSET 0x70
391#define F3O_OFFSET 0x78
392#define F32_OFFSET 0x80
393#define F34_OFFSET 0x88
394#define F36_OFFSET 0x90
395#define F38_OFFSET 0x98
396#define F4O_OFFSET 0xA0
397#define F42_OFFSET 0xA8
398#define F44_OFFSET 0xB0
399#define F46_OFFSET 0xB8
400#define F48_OFFSET 0xC0
401#define F5O_OFFSET 0xC8
402#define F52_OFFSET 0xD0
403#define F54_OFFSET 0xD8
404#define F56_OFFSET 0xE0
405#define F58_OFFSET 0xE8
406#define F6O_OFFSET 0xF0
407#define F62_OFFSET 0xF8
408#define FSR_OFFSET 0x100
409
410#define CONTEXT_CONTROL_FP_SIZE 0x108
411
412#ifndef ASM
413
414/*
415 * Context saved on stack for an interrupt.
416 *
417 * NOTE: The tstate, tpc, and tnpc are saved in this structure
418 * to allow resetting the TL while still being able to return
419 * from a trap later. The PIL is saved because
420 * if this is an external interrupt, we will mask lower
421 * priority interrupts until finishing. Even though the y register
422 * is deprecated, gcc still uses it.
423 */
424
425typedef struct {
426 SPARC64_Minimum_stack_frame Stack_frame;
427 uint64_t tstate;
428 uint64_t tpc;
429 uint64_t tnpc;
430 uint64_t pil;
431 uint64_t y;
432 uint64_t g1;
433 uint64_t g2;
434 uint64_t g3;
435 uint64_t g4;
436 uint64_t g5;
437 uint64_t g6;
438 uint64_t g7;
439 uint64_t o0;
440 uint64_t o1;
441 uint64_t o2;
442 uint64_t o3;
443 uint64_t o4;
444 uint64_t o5;
445 uint64_t o6_sp;
446 uint64_t o7;
447 uint64_t tvec;
449
450#endif /* ASM */
451
452/*
453 * Offsets of fields with CPU_Interrupt_frame for assembly routines.
454 */
455
456#define ISF_TSTATE_OFFSET SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x00
457#define ISF_TPC_OFFSET SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x08
458#define ISF_TNPC_OFFSET SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x10
459#define ISF_PIL_OFFSET SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x18
460#define ISF_Y_OFFSET SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x20
461#define ISF_G1_OFFSET SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x28
462#define ISF_G2_OFFSET SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x30
463#define ISF_G3_OFFSET SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x38
464#define ISF_G4_OFFSET SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x40
465#define ISF_G5_OFFSET SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x48
466#define ISF_G6_OFFSET SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x50
467#define ISF_G7_OFFSET SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x58
468#define ISF_O0_OFFSET SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x60
469#define ISF_O1_OFFSET SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x68
470#define ISF_O2_OFFSET SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x70
471#define ISF_O3_OFFSET SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x78
472#define ISF_O4_OFFSET SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x80
473#define ISF_O5_OFFSET SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x88
474#define ISF_O6_SP_OFFSET SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x90
475#define ISF_O7_OFFSET SPARC64_MINIMUM_STACK_FRAME_SIZE + 0x98
476#define ISF_TVEC_OFFSET SPARC64_MINIMUM_STACK_FRAME_SIZE + 0xA0
477
478#define CONTEXT_CONTROL_INTERRUPT_FRAME_SIZE SPARC64_MINIMUM_STACK_FRAME_SIZE + 0xA8
479#ifndef ASM
480/*
481 * This variable is contains the initialize context for the FP unit.
482 * It is filled in by _CPU_Initialize and copied into the task's FP
483 * context area during _CPU_Context_Initialize.
484 */
485
487
488/*
489 * This flag is context switched with each thread. It indicates
490 * that THIS thread has an interrupt stack frame on its stack.
491 * By using this flag, we can avoid nesting more interrupt dispatching
492 * attempts on a previously interrupted thread's stack.
493 */
494
495extern volatile uint32_t _CPU_ISR_Dispatch_disable;
496
497/*
498 * The following type defines an entry in the SPARC's trap table.
499 *
500 * NOTE: The instructions chosen are RTEMS dependent although one is
501 * obligated to use two of the four instructions to perform a
502 * long jump. The other instructions load one register with the
503 * trap type (a.k.a. vector) and another with the psr.
504 */
505/* For SPARC V9, we must use 6 of these instructions to perform a long
506 * jump, because the _handler value is now 64-bits. We also need to store
507 * temporary values in the global register set at this trap level. Because
508 * the handler runs at TL > 0 with GL > 0, it should be OK to use g2 and g3
509 * to pass parameters to ISR_Handler.
510 *
511 * The instruction sequence is now more like:
512 * rdpr %tstate, %g4
513 * setx _handler, %g2, %g3
514 * jmp %g3+0
515 * mov _vector, %g2
516 */
517typedef struct {
518 uint32_t rdpr_tstate_g4; /* rdpr %tstate, %g4 */
519 uint32_t sethi_of_hh_handler_to_g2; /* sethi %hh(_handler), %g2 */
520 uint32_t or_g2_hm_handler_to_g2; /* or %l3, %hm(_handler), %g2 */
521 uint32_t sllx_g2_by_32_to_g2; /* sllx %g2, 32, %g2 */
522 uint32_t sethi_of_handler_to_g3; /* sethi %hi(_handler), %g3 */
523 uint32_t or_g3_g2_to_g3; /* or %g3, %g2, %g3 */
524 uint32_t jmp_to_low_of_handler_plus_g3; /* jmp %g3 + %lo(_handler) */
525 uint32_t mov_vector_g2; /* mov _vector, %g2 */
527
528/*
529 * This is the set of opcodes for the instructions loaded into a trap
530 * table entry. The routine which installs a handler is responsible
531 * for filling in the fields for the _handler address and the _vector
532 * trap type.
533 *
534 * The constants following this structure are masks for the fields which
535 * must be filled in when the handler is installed.
536 */
537
539
540/*
541 * The size of the floating point context area.
542 */
543
544#define CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp )
545
546#endif
547
548/*
549 * Amount of extra stack (above minimum stack size) required by
550 * MPCI receive server thread. Remember that in a multiprocessor
551 * system this thread must exist and be able to process all directives.
552 */
553
554#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 1024
555
556/*
557 * This defines the number of entries in the ISR_Vector_table managed
558 * by the executive.
559 *
560 * On the SPARC, there are really only 256 vectors. However, the executive
561 * has no easy, fast, reliable way to determine which traps are synchronous
562 * and which are asynchronous. By default, synchronous traps return to the
563 * instruction which caused the interrupt. So if you install a software
564 * trap handler as an executive interrupt handler (which is desirable since
565 * RTEMS takes care of window and register issues), then the executive needs
566 * to know that the return address is to the trap rather than the instruction
567 * following the trap.
568 *
569 * So vectors 0 through 255 are treated as regular asynchronous traps which
570 * provide the "correct" return address. Vectors 256 through 512 are assumed
571 * by the executive to be synchronous and to require that the return address
572 * be fudged.
573 *
574 * If you use this mechanism to install a trap handler which must reexecute
575 * the instruction which caused the trap, then it should be installed as
576 * an asynchronous trap. This will avoid the executive changing the return
577 * address.
578 */
579/* On SPARC v9, there are 512 vectors. The same philosophy applies to
580 * vector installation and use, we just provide a larger table.
581 */
582#define CPU_INTERRUPT_NUMBER_OF_VECTORS 512
583#define CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER 1023
584
585#define SPARC_SYNCHRONOUS_TRAP_BIT_MASK 0x200
586#define SPARC_ASYNCHRONOUS_TRAP( _trap ) (_trap)
587#define SPARC_SYNCHRONOUS_TRAP( _trap ) ((_trap) + 512 )
588
589#define SPARC_REAL_TRAP_NUMBER( _trap ) ((_trap) % 512)
590
591/*
592 * This is defined if the port has a special way to report the ISR nesting
593 * level. Most ports maintain the variable _ISR_Nest_level.
594 */
595
596#define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
597
598/*
599 * Should be large enough to run all tests. This ensures
600 * that a "reasonable" small application should not have any problems.
601 *
602 * This appears to be a fairly generous number for the SPARC since
603 * represents a call depth of about 20 routines based on the minimum
604 * stack frame.
605 */
606
607#define CPU_STACK_MINIMUM_SIZE (1024*8)
608
609#define CPU_SIZEOF_POINTER 8
610
611/*
612 * CPU's worst alignment requirement for data types on a byte boundary. This
613 * alignment does not take into account the requirements for the stack.
614 *
615 * On the SPARC, this is required for double word loads and stores.
616 *
617 * Note: quad-word loads/stores need alignment of 16, but currently supported
618 * architectures do not provide HW implemented quad-word operations.
619 */
620
621#define CPU_ALIGNMENT 8
622
623/*
624 * This number corresponds to the byte alignment requirement for the
625 * heap handler. This alignment requirement may be stricter than that
626 * for the data types alignment specified by CPU_ALIGNMENT. It is
627 * common for the heap to follow the same alignment requirement as
628 * CPU_ALIGNMENT. If the CPU_ALIGNMENT is strict enough for the heap,
629 * then this should be set to CPU_ALIGNMENT.
630 *
631 * NOTE: This does not have to be a power of 2. It does have to
632 * be greater or equal to than CPU_ALIGNMENT.
633 */
634
635#define CPU_HEAP_ALIGNMENT CPU_ALIGNMENT
636
637/*
638 * This number corresponds to the byte alignment requirement for the
639 * stack. This alignment requirement may be stricter than that for the
640 * data types alignment specified by CPU_ALIGNMENT. If the CPU_ALIGNMENT
641 * is strict enough for the stack, then this should be set to 0.
642 *
643 * NOTE: This must be a power of 2 either 0 or greater than CPU_ALIGNMENT.
644 *
645 * The alignment restrictions for the SPARC are not that strict but this
646 * should unsure that the stack is always sufficiently alignment that the
647 * window overflow, underflow, and flush routines can use double word loads
648 * and stores.
649 */
650
651#define CPU_STACK_ALIGNMENT 16
652
653#define CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES
654
655#ifndef ASM
656
657/*
658 * ISR handler macros
659 */
660
661/*
662 * Support routine to initialize the RTEMS vector table after it is allocated.
663 */
664
665#define _CPU_Initialize_vectors()
666
667/*
668 * Disable all interrupts for a critical section. The previous
669 * level is returned in _level.
670 */
671
672 #define _CPU_ISR_Disable( _level ) \
673 (_level) = sparc_disable_interrupts()
674
675/*
676 * Enable interrupts to the previous level (returned by _CPU_ISR_Disable).
677 * This indicates the end of a critical section. The parameter
678 * _level is not modified.
679 */
680
681#define _CPU_ISR_Enable( _level ) \
682 sparc_enable_interrupts( _level )
683
684/*
685 * This temporarily restores the interrupt to _level before immediately
686 * disabling them again. This is used to divide long critical
687 * sections into two or more parts. The parameter _level is not
688 * modified.
689 */
690
691#define _CPU_ISR_Flash( _level ) \
692 sparc_flash_interrupts( _level )
693
695{
696 return ( level & SPARC_PSTATE_IE_MASK ) != 0;
697}
698
699/*
700 * Map interrupt level in task mode onto the hardware that the CPU
701 * actually provides. Currently, interrupt levels which do not
702 * map onto the CPU in a straight fashion are undefined.
703 */
704
705#define _CPU_ISR_Set_level( _newlevel ) \
706 sparc_enable_interrupts( _newlevel)
707
708uint32_t _CPU_ISR_Get_level( void );
709
710/* end of ISR handler macros */
711
712/* Context handler macros */
713
714/*
715 * Initialize the context to a state suitable for starting a
716 * task after a context restore operation. Generally, this
717 * involves:
718 *
719 * - setting a starting address
720 * - preparing the stack
721 * - preparing the stack and frame pointers
722 * - setting the proper interrupt level in the context
723 * - initializing the floating point context
724 *
725 * NOTE: Implemented as a subroutine for the SPARC port.
726 */
727
729 Context_Control *the_context,
730 void *stack_base,
731 uint32_t size,
732 uint32_t new_level,
733 void *entry_point,
734 bool is_fp,
735 void *tls_area
736);
737
738/*
739 * This macro is invoked from _Thread_Handler to do whatever CPU
740 * specific magic is required that must be done in the context of
741 * the thread when it starts.
742 *
743 * On the SPARC, this is setting the frame pointer so GDB is happy.
744 * Make GDB stop unwinding at _Thread_Handler, previous register window
745 * Frame pointer is 0 and calling address must be a function with starting
746 * with a SAVE instruction. If return address is leaf-function (no SAVE)
747 * GDB will not look at prev reg window fp.
748 *
749 * _Thread_Handler is known to start with SAVE.
750 */
751
752#define _CPU_Context_Initialization_at_thread_begin() \
753 do { \
754 __asm__ volatile ("set _Thread_Handler,%%i7\n"::); \
755 } while (0)
756
757/*
758 * This routine is responsible for somehow restarting the currently
759 * executing task.
760 *
761 * On the SPARC, this is is relatively painless but requires a small
762 * amount of wrapper code before using the regular restore code in
763 * of the context switch.
764 */
765
766#define _CPU_Context_Restart_self( _the_context ) \
767 _CPU_Context_restore( (_the_context) );
768
769/*
770 * This routine initializes the FP context area passed to it to.
771 *
772 * The SPARC allows us to use the simple initialization model
773 * in which an "initial" FP context was saved into _CPU_Null_fp_context
774 * at CPU initialization and it is simply copied into the destination
775 * context.
776 */
777
778#define _CPU_Context_Initialize_fp( _destination ) \
779 do { \
780 *(*(_destination)) = _CPU_Null_fp_context; \
781 } while (0)
782
783/* end of Context handler macros */
784
785/* Fatal Error manager macros */
786
787/*
788 * This routine copies _error into a known place -- typically a stack
789 * location or a register, optionally disables interrupts, and
790 * halts/stops the CPU.
791 */
792
793#define _CPU_Fatal_halt( _source, _error ) \
794 do { \
795 uint32_t level; \
796 \
797 level = sparc_disable_interrupts(); \
798 __asm__ volatile ( "mov %0, %%g1 " : "=r" (level) : "0" (level) ); \
799 while (1); /* loop forever */ \
800 } while (0)
801
802/* end of Fatal Error manager macros */
803
804/* Bitfield handler macros */
805
806/*
807 * The SPARC port uses the generic C algorithm for bitfield scan if the
808 * CPU model does not have a scan instruction.
809 */
810
811#if ( SPARC_HAS_BITSCAN == 0 )
812#define CPU_USE_GENERIC_BITFIELD_CODE TRUE
813#else
814#error "scan instruction not currently supported by RTEMS!!"
815#endif
816
817/* end of Bitfield handler macros */
818
819/* Priority handler handler macros */
820
821/*
822 * The SPARC port uses the generic C algorithm for bitfield scan if the
823 * CPU model does not have a scan instruction.
824 */
825
826#if ( SPARC_HAS_BITSCAN == 1 )
827#error "scan instruction not currently supported by RTEMS!!"
828#endif
829
830/* end of Priority handler macros */
831
832/* functions */
833
834/*
835 * _CPU_Initialize
836 *
837 * This routine performs CPU dependent initialization.
838 */
839
840void _CPU_Initialize(void);
841
842typedef void ( *CPU_ISR_raw_handler )( void );
843
845 uint32_t vector,
846 CPU_ISR_raw_handler new_handler,
847 CPU_ISR_raw_handler *old_handler
848);
849
850typedef void ( *CPU_ISR_handler )( uint32_t );
851
853 uint32_t vector,
854 CPU_ISR_handler new_handler,
855 CPU_ISR_handler *old_handler
856);
857
858void *_CPU_Thread_Idle_body( uintptr_t ignored );
859
860/*
861 * _CPU_Context_switch
862 *
863 * This routine switches from the run context to the heir context.
864 */
865
867 Context_Control *run,
868 Context_Control *heir
869);
870
871/*
872 * _CPU_Context_restore
873 *
874 * This routine is generally used only to restart self in an
875 * efficient manner.
876 */
877
879 Context_Control *new_context
881
882/*
883 * _CPU_Context_save_fp
884 *
885 * This routine saves the floating point context passed to it.
886 */
887
889 Context_Control_fp **fp_context_ptr
890);
891
892/*
893 * _CPU_Context_restore_fp
894 *
895 * This routine restores the floating point context passed to it.
896 */
897
899 Context_Control_fp **fp_context_ptr
900);
901
902/* FIXME */
904
906
907/*
908 * CPU_swap_u32
909 *
910 * The following routine swaps the endian format of an unsigned int.
911 * It must be static because it is referenced indirectly.
912 *
913 * This version will work on any processor, but if you come across a better
914 * way for the SPARC PLEASE use it. The most common way to swap a 32-bit
915 * entity as shown below is not any more efficient on the SPARC.
916 *
917 * swap least significant two bytes with 16-bit rotate
918 * swap upper and lower 16-bits
919 * swap most significant two bytes with 16-bit rotate
920 *
921 * It is not obvious how the SPARC can do significantly better than the
922 * generic code. gcc 2.7.0 only generates about 12 instructions for the
923 * following code at optimization level four (i.e. -O4).
924 */
925
926static inline uint32_t CPU_swap_u32(
927 uint32_t value
928)
929{
930 uint32_t byte1, byte2, byte3, byte4, swapped;
931
932 byte4 = (value >> 24) & 0xff;
933 byte3 = (value >> 16) & 0xff;
934 byte2 = (value >> 8) & 0xff;
935 byte1 = value & 0xff;
936
937 swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
938 return( swapped );
939}
940
941#define CPU_swap_u16( value ) \
942 (((value&0xff) << 8) | ((value >> 8)&0xff))
943
944typedef uint32_t CPU_Counter_ticks;
945
946uint32_t _CPU_Counter_frequency( void );
947
948CPU_Counter_ticks _CPU_Counter_read( void );
949
950static inline CPU_Counter_ticks _CPU_Counter_difference(
951 CPU_Counter_ticks second,
952 CPU_Counter_ticks first
953)
954{
955 return second - first;
956}
957
959typedef uintptr_t CPU_Uint32ptr;
960
961#endif /* ASM */
962
963#ifdef __cplusplus
964}
965#endif
966
967#endif
Basic Definitions.
#define RTEMS_NO_RETURN
Definition: basedefs.h:102
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
bool _CPU_ISR_Is_enabled(uint32_t level)
Returns true if interrupts are enabled in the specified ISR level, otherwise returns false.
Definition: cpu.h:375
void * _CPU_Thread_Idle_body(uintptr_t ignored)
Definition: idle-mcf5272.c:20
CPU initialization.
Definition: cpu.c:45
Definition: cpu.h:662
RTEMS_INLINE_ROUTINE void _CPU_ISR_install_vector(uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler)
SPARC specific RTEMS ISR installer.
Definition: cpu.h:493
uint32_t _CPU_Counter_frequency(void)
Returns the current CPU counter frequency in Hz.
Definition: system-clocks.c:112
void _CPU_Context_switch(Context_Control *run, Context_Control *heir)
CPU switch context.
Definition: cpu_asm.c:91
CPU_Counter_ticks _CPU_Counter_read(void)
Returns the current CPU counter value.
Definition: system-clocks.c:117
void _CPU_Context_restore(Context_Control *new_context) RTEMS_NO_RETURN
Definition: cpu_asm.c:111
uint32_t _CPU_ISR_Get_level(void)
Definition: cpu.c:88
void _CPU_Context_Initialize(Context_Control *context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area)
Initializes the CPU context.
Definition: epiphany-context-initialize.c:40
void _CPU_Exception_frame_print(const CPU_Exception_frame *frame)
Prints the exception frame via printk().
Definition: vectorexceptions.c:45
RTEMS_INLINE_ROUTINE void _CPU_ISR_install_raw_handler(uint32_t vector, CPU_ISR_raw_handler new_handler, CPU_ISR_raw_handler *old_handler)
SPARC specific raw ISR installer.
Definition: cpu.h:649
Unsigned integer type for CPU counter values.
Definition: cpu.h:1210
Context_Control_fp _CPU_Null_fp_context
Information Required to Build RTEMS for a Particular Member of the SPARC Family.
const CPU_Trap_table_entry _CPU_Trap_slot_template
Definition: cpu.c:156
#define _CPU_Context_restore_fp(_fp_context_ptr)
Nothing to do due to the synchronous or lazy floating point switch.
Definition: cpu.h:904
#define _CPU_Context_save_fp(_fp_context_ptr)
Definition: cpu.h:898
The set of registers that specifies the complete processor state.
Definition: cpu.h:629
Interrupt stack frame (ISF).
Definition: cpu.h:191
Definition: cpu.h:627
SPARC basic context.
Definition: cpu.h:194
Thread register context.
Definition: cpu.h:161
unsigned size
Definition: tte.h:1
