RTEMS 5.2
objectmp.h
1
12/*
13 * COPYRIGHT (c) 1989-2009.
14 * On-Line Applications Research Corporation (OAR).
15 *
16 * The license and distribution terms for this file may be
17 * found in the file LICENSE in this distribution or at
18 * http://www.rtems.org/license/LICENSE.
19 */
20
21#ifndef _RTEMS_SCORE_OBJECTMP_H
22#define _RTEMS_SCORE_OBJECTMP_H
23
24#ifndef _RTEMS_SCORE_OBJECTIMPL_H
25# error "Never use <rtems/rtems/objectmp.h> directly; include <rtems/rtems/objectimpl.h> instead."
26#endif
27
29
30#ifdef __cplusplus
31extern "C" {
32#endif
33
56
65
83 Objects_Information *information,
84 Objects_MP_Control *the_global_object,
85 uint32_t the_name,
86 Objects_Id the_id
87);
88
112 Objects_Information *information,
113 uint32_t the_name,
114 Objects_Id the_id,
115 bool is_fatal_error
116);
117
129 Objects_Information *information,
130 Objects_Id the_id
131);
132
153 Objects_Information *information,
154 Objects_Name the_name,
155 uint32_t nodes_to_search,
156 Objects_Id *the_id
157);
158
172 Objects_Id id,
173 const Objects_Information *information
174);
175
180
184Objects_MP_Control *_Objects_MP_Allocate_global_object( void );
185
191void _Objects_MP_Free_global_object( Objects_MP_Control *the_object );
192
202 Objects_MP_Control *the_object
203)
204{
205 return( the_object == NULL );
206}
207
210#ifdef __cplusplus
211}
212#endif
213
214#endif
215/* end of include file */
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
Chain Handler API.
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
void _Objects_MP_Handler_initialization(void)
Intializes the inactive global object chain based on the maximum number of global objects configured.
Definition: objectmp.c:173
uint32_t _Objects_MP_Maximum_global_objects
Definition: objectmp.c:41
RTEMS_INLINE_ROUTINE bool _Objects_MP_Is_null_global_object(Objects_MP_Control *the_object)
Checks if the global object is NULL or not.
Definition: objectmp.h:201
void _Objects_MP_Free_global_object(Objects_MP_Control *the_object)
This routine deallocates a Global Object control block.
Definition: objectmp.c:375
void _Objects_MP_Handler_early_initialization(void)
Intializes the global object node number used in the ID field of all objects.
Definition: objectmp.c:158
Objects_MP_Control * _Objects_MP_Allocate_global_object(void)
This function allocates a Global Object control block.
Definition: objectmp.c:361
Objects_Name_or_id_lookup_errors _Objects_MP_Global_name_search(Objects_Information *information, Objects_Name the_name, uint32_t nodes_to_search, Objects_Id *the_id)
Looks for the object with the_name in the global object tables indicated by information.
Definition: objectmp.c:286
void _Objects_MP_Open(Objects_Information *information, Objects_MP_Control *the_global_object, uint32_t the_name, Objects_Id the_id)
Place the specified global object in the specified information table.
Definition: objectmp.c:193
void _Objects_MP_Close(Objects_Information *information, Objects_Id the_id)
Removes a global object from the specified information table.
Definition: objectmp.c:250
bool _Objects_MP_Is_remote(Objects_Id id, const Objects_Information *information)
Checks if the object identifier is in the global object identifier cache of the specified object info...
Definition: objectmp.c:338
bool _Objects_MP_Allocate_and_open(Objects_Information *information, uint32_t the_name, Objects_Id the_id, bool is_fatal_error)
Allocates a global object control block and places it in the specified information table.
Definition: objectmp.c:227
uint32_t Objects_Id
Definition: object.h:80
Definition: objectimpl.h:203
The information structure used to manage each API class of objects.
Definition: objectdata.h:176
Definition: object.h:64
