RTEMS 5.2
Functions | Variables
Data Associated with the Manipulation of Global RTEMS Objects. More...
void _Objects_MP_Handler_initialization (void)
 Intializes the inactive global object chain based on the maximum number of global objects configured. More...
void _Objects_MP_Handler_early_initialization (void)
 Intializes the global object node number used in the ID field of all objects. More...
void _Objects_MP_Open (Objects_Information *information, Objects_MP_Control *the_global_object, uint32_t the_name, Objects_Id the_id)
 Place the specified global object in the specified information table. More...
bool _Objects_MP_Allocate_and_open (Objects_Information *information, uint32_t the_name, Objects_Id the_id, bool is_fatal_error)
 Allocates a global object control block and places it in the specified information table. More...
void _Objects_MP_Close (Objects_Information *information, Objects_Id the_id)
 Removes a global object from the specified information table. More...
Objects_Name_or_id_lookup_errors _Objects_MP_Global_name_search (Objects_Information *information, Objects_Name the_name, uint32_t nodes_to_search, Objects_Id *the_id)
 Looks for the object with the_name in the global object tables indicated by information. More...
bool _Objects_MP_Is_remote (Objects_Id id, const Objects_Information *information)
 Checks if the object identifier is in the global object identifier cache of the specified object information. More...
Objects_MP_Control * _Objects_MP_Allocate_global_object (void)
 This function allocates a Global Object control block.
void _Objects_MP_Free_global_object (Objects_MP_Control *the_object)
 This routine deallocates a Global Object control block. More...
RTEMS_INLINE_ROUTINE bool _Objects_MP_Is_null_global_object (Objects_MP_Control *the_object)
 Checks if the global object is NULL or not. More...
uint32_t _Objects_MP_Maximum_global_objects
This include file contains all the constants and structures associated with the manipulation of Global RTEMS Objects.
