RTEMS 5.2
chainimpl.h
1
9/*
10 * Copyright (c) 2010 embedded brains GmbH.
11 *
12 * COPYRIGHT (c) 1989-2014.
13 * On-Line Applications Research Corporation (OAR).
14 *
15 * The license and distribution terms for this file may be
16 * found in the file LICENSE in this distribution or at
17 * http://www.rtems.org/license/LICENSE.
18 */
19
20#ifndef _RTEMS_SCORE_CHAINIMPL_H
21#define _RTEMS_SCORE_CHAINIMPL_H
22
23#include <rtems/score/chain.h>
24#include <rtems/score/assert.h>
25
26#ifdef __cplusplus
27extern "C" {
28#endif
29
39#define CHAIN_INITIALIZER_EMPTY(name) \
40 { { { &(name).Tail.Node, NULL }, &(name).Head.Node } }
41
47#define CHAIN_INITIALIZER_ONE_NODE( node ) \
48 { { { (node), NULL }, (node) } }
49
55#define CHAIN_NODE_INITIALIZER_ONE_NODE_CHAIN( chain ) \
56 { &(chain)->Tail.Node, &(chain)->Head.Node }
57
61#define CHAIN_DEFINE_EMPTY(name) \
62 Chain_Control name = CHAIN_INITIALIZER_EMPTY(name)
63
78 Chain_Control *the_chain,
79 void *starting_address,
80 size_t number_nodes,
81 size_t node_size
82);
83
94size_t _Chain_Node_count_unprotected( const Chain_Control *chain );
95
105 Chain_Node *node
106)
107{
108 node->next = NULL;
109#if defined(RTEMS_DEBUG)
110 node->previous = NULL;
111#endif
112}
113
123{
124#if defined(RTEMS_DEBUG)
125 _Chain_Set_off_chain( the_node );
126#else
127 (void) the_node;
128#endif
129}
130
143 const Chain_Node *node
144)
145{
146 return node->next == NULL;
147}
148
162 const Chain_Node *left,
163 const Chain_Node *right
164)
165{
166 return left == right;
167}
168
180 const Chain_Node *the_node
181)
182{
183 return (the_node == NULL);
184}
185
196 Chain_Control *the_chain
197)
198{
199 return &the_chain->Head.Node;
200}
201
212 const Chain_Control *the_chain
213)
214{
215 return &the_chain->Head.Node;
216}
217
228 Chain_Control *the_chain
229)
230{
231 return &the_chain->Tail.Node;
232}
233
244 const Chain_Control *the_chain
245)
246{
247 return &the_chain->Tail.Node;
248}
249
261 const Chain_Control *the_chain
262)
263{
264 return _Chain_Immutable_head( the_chain )->next;
265}
266
278 const Chain_Control *the_chain
279)
280{
281 return _Chain_Immutable_head( the_chain )->next;
282}
283
295 const Chain_Control *the_chain
296)
297{
298 return _Chain_Immutable_tail( the_chain )->previous;
299}
300
312 const Chain_Control *the_chain
313)
314{
315 return _Chain_Immutable_tail( the_chain )->previous;
316}
317
328 const Chain_Node *the_node
329)
330{
331 return the_node->next;
332}
333
344 const Chain_Node *the_node
345)
346{
347 return the_node->next;
348}
349
360 const Chain_Node *the_node
361)
362{
363 return the_node->previous;
364}
365
376 const Chain_Node *the_node
377)
378{
379 return the_node->previous;
380}
381
394 const Chain_Control *the_chain
395)
396{
397 return _Chain_Immutable_first( the_chain )
398 == _Chain_Immutable_tail( the_chain );
399}
400
414 const Chain_Node *the_node
415)
416{
417 return (the_node->previous->previous == NULL);
418}
419
433 const Chain_Node *the_node
434)
435{
436 return (the_node->next->next == NULL);
437}
438
451 const Chain_Control *the_chain
452)
453{
454 return _Chain_Immutable_first( the_chain )
455 == _Chain_Immutable_last( the_chain );
456}
457
471 const Chain_Control *the_chain,
472 const Chain_Node *the_node
473)
474{
475 return (the_node == _Chain_Immutable_head( the_chain ));
476}
477
491 const Chain_Control *the_chain,
492 const Chain_Node *the_node
493)
494{
495 return (the_node == _Chain_Immutable_tail( the_chain ));
496}
497
506 Chain_Control *the_chain
507)
508{
509 Chain_Node *head;
510 Chain_Node *tail;
511
512 _Assert( the_chain != NULL );
513
514 head = _Chain_Head( the_chain );
515 tail = _Chain_Tail( the_chain );
516
517 head->next = tail;
518 head->previous = NULL;
519 tail->previous = head;
520}
521
529 Chain_Control *the_chain,
530 Chain_Node *the_node
531)
532{
533 Chain_Node *head;
534 Chain_Node *tail;
535
536 _Assert( _Chain_Is_node_off_chain( the_node ) );
537
538 head = _Chain_Head( the_chain );
539 tail = _Chain_Tail( the_chain );
540
541 the_node->next = tail;
542 the_node->previous = head;
543
544 head->next = the_node;
545 head->previous = NULL;
546 tail->previous = the_node;
547}
548
559 Chain_Node *the_node
560)
561{
562 Chain_Node *next;
563 Chain_Node *previous;
564
565 _Assert( !_Chain_Is_node_off_chain( the_node ) );
566
567 next = the_node->next;
568 previous = the_node->previous;
569 next->previous = previous;
570 previous->next = next;
571
572#if defined(RTEMS_DEBUG)
573 _Chain_Set_off_chain( the_node );
574#endif
575}
576
593 Chain_Control *the_chain
594)
595{
596 Chain_Node *head;
597 Chain_Node *old_first;
598 Chain_Node *new_first;
599
600 _Assert( !_Chain_Is_empty( the_chain ) );
601
602 head = _Chain_Head( the_chain );
603 old_first = head->next;
604 new_first = old_first->next;
605
606 head->next = new_first;
607 new_first->previous = head;
608
609#if defined(RTEMS_DEBUG)
610 _Chain_Set_off_chain( old_first );
611#endif
612
613 return old_first;
614}
615
631 Chain_Control *the_chain
632)
633{
634 if ( !_Chain_Is_empty(the_chain))
635 return _Chain_Get_first_unprotected(the_chain);
636 else
637 return NULL;
638}
639
654 Chain_Node *after_node,
655 Chain_Node *the_node
656)
657{
658 Chain_Node *before_node;
659
660 _Assert( _Chain_Is_node_off_chain( the_node ) );
661
662 the_node->previous = after_node;
663 before_node = after_node->next;
664 after_node->next = the_node;
665 the_node->next = before_node;
666 before_node->previous = the_node;
667}
668
681 Chain_Control *the_chain,
682 Chain_Node *the_node
683)
684{
685 Chain_Node *tail;
686 Chain_Node *old_last;
687
688 _Assert( _Chain_Is_node_off_chain( the_node ) );
689
690 tail = _Chain_Tail( the_chain );
691 old_last = tail->previous;
692
693 the_node->next = tail;
694 tail->previous = the_node;
695 old_last->next = the_node;
696 the_node->previous = old_last;
697}
698
712 Chain_Control *the_chain,
713 Chain_Node *the_node
714)
715{
716 if ( _Chain_Is_node_off_chain( the_node ) ) {
717 _Chain_Append_unprotected( the_chain, the_node );
718 }
719}
720
733 Chain_Control *the_chain,
734 Chain_Node *the_node
735)
736{
737 _Chain_Insert_unprotected(_Chain_Head(the_chain), the_node);
738}
739
755 Chain_Control *the_chain,
756 Chain_Node *the_node
757)
758{
759 bool was_empty = _Chain_Is_empty( the_chain );
760
761 _Chain_Append_unprotected( the_chain, the_node );
762
763 return was_empty;
764}
765
781 Chain_Control *the_chain,
782 Chain_Node *the_node
783)
784{
785 bool was_empty = _Chain_Is_empty( the_chain );
786
787 _Chain_Prepend_unprotected( the_chain, the_node );
788
789 return was_empty;
790}
791
811 Chain_Control *the_chain,
812 Chain_Node **the_node
813)
814{
815 bool is_empty_now = true;
816 Chain_Node *head = _Chain_Head( the_chain );
817 Chain_Node *tail = _Chain_Tail( the_chain );
818 Chain_Node *old_first = head->next;
819
820 if ( old_first != tail ) {
821 Chain_Node *new_first = old_first->next;
822
823 head->next = new_first;
824 new_first->previous = head;
825
826 *the_node = old_first;
827
828 is_empty_now = new_first == tail;
829 } else
830 *the_node = NULL;
831
832 return is_empty_now;
833}
834
844typedef bool ( *Chain_Node_order )(
845 const void *left,
846 const Chain_Node *right
847);
848
865 Chain_Control *the_chain,
866 Chain_Node *to_insert,
867 const void *left,
868 Chain_Node_order order
869)
870{
871 const Chain_Node *tail = _Chain_Immutable_tail( the_chain );
872 Chain_Node *next = _Chain_First( the_chain );
873
874 while ( next != tail && !( *order )( left, next ) ) {
875 next = _Chain_Next( next );
876 }
877
878 _Chain_Insert_unprotected( _Chain_Previous( next ), to_insert );
879}
880
884typedef enum {
889
895
902typedef struct {
909
916
927
934typedef struct {
935 Chain_Control Iterators;
937
943#define CHAIN_ITERATOR_REGISTRY_INITIALIZER( name ) \
944 { CHAIN_INITIALIZER_EMPTY( name.Iterators ) }
945
952 Chain_Iterator_registry *the_registry
953)
954{
955 _Chain_Initialize_empty( &the_registry->Iterators );
956}
957
971 Chain_Iterator_registry *the_registry,
972 Chain_Node *the_node_to_extract
973)
974{
975 Chain_Node *iter_node;
976 Chain_Node *iter_tail;
977
978 iter_node = _Chain_Head( &the_registry->Iterators );
979 iter_tail = _Chain_Tail( &the_registry->Iterators );
980
981 while ( ( iter_node = _Chain_Next( iter_node ) ) != iter_tail ) {
982 Chain_Iterator *iter;
983
984 iter = (Chain_Iterator *) iter_node;
985
986 if ( iter->position == the_node_to_extract ) {
987 if ( iter->direction == CHAIN_ITERATOR_FORWARD ) {
988 iter->position = _Chain_Previous( the_node_to_extract );
989 } else {
990 iter->position = _Chain_Next( the_node_to_extract );
991 }
992 }
993 }
994}
995
1058 Chain_Control *the_chain,
1059 Chain_Iterator_registry *the_registry,
1060 Chain_Iterator *the_iterator,
1061 Chain_Iterator_direction direction
1062)
1063{
1064 _Chain_Initialize_node( &the_iterator->Registry_node );
1066 &the_registry->Iterators,
1067 &the_iterator->Registry_node
1068 );
1069
1070 the_iterator->direction = direction;
1071
1072 if ( direction == CHAIN_ITERATOR_FORWARD ) {
1073 the_iterator->position = _Chain_Head( the_chain );
1074 } else {
1075 the_iterator->position = _Chain_Tail( the_chain );
1076 }
1077}
1078
1090 const Chain_Iterator *the_iterator
1091)
1092{
1093 if ( the_iterator->direction == CHAIN_ITERATOR_FORWARD ) {
1094 return _Chain_Next( the_iterator->position );
1095 } else {
1096 return _Chain_Previous( the_iterator->position );
1097 }
1098}
1099
1107 Chain_Iterator *the_iterator,
1108 Chain_Node *the_node
1109)
1110{
1111 the_iterator->position = the_node;
1112}
1113
1122 Chain_Iterator *the_iterator
1123)
1124{
1125 _Chain_Extract_unprotected( &the_iterator->Registry_node );
1126}
1127
1130#ifdef __cplusplus
1131}
1132#endif
1133
1134#endif
1135/* end of include file */
Information for the Assert Handler.
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
#define _Assert(_e)
Assertion similar to assert() controlled via RTEMS_DEBUG instead of NDEBUG.
Definition: assert.h:100
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
RTEMS_INLINE_ROUTINE Chain_Node * _Chain_Get_unprotected(Chain_Control *the_chain)
Gets the first node (unprotected).
Definition: chainimpl.h:630
RTEMS_INLINE_ROUTINE void _Chain_Initialize_one(Chain_Control *the_chain, Chain_Node *the_node)
Initializes this chain to contain exactly the specified node.
Definition: chainimpl.h:528
RTEMS_INLINE_ROUTINE void _Chain_Insert_unprotected(Chain_Node *after_node, Chain_Node *the_node)
Inserts a node (unprotected).
Definition: chainimpl.h:653
RTEMS_INLINE_ROUTINE Chain_Node * _Chain_Last(const Chain_Control *the_chain)
Returns pointer to chain's last node.
Definition: chainimpl.h:294
RTEMS_INLINE_ROUTINE const Chain_Node * _Chain_Immutable_head(const Chain_Control *the_chain)
Returns pointer to immutable chain head.
Definition: chainimpl.h:211
RTEMS_INLINE_ROUTINE bool _Chain_Has_only_one_node(const Chain_Control *the_chain)
Checks if this chain has only one node.
Definition: chainimpl.h:450
RTEMS_INLINE_ROUTINE bool _Chain_Is_head(const Chain_Control *the_chain, const Chain_Node *the_node)
Checks if this node is the chain head.
Definition: chainimpl.h:470
RTEMS_INLINE_ROUTINE bool _Chain_Is_last(const Chain_Node *the_node)
Checks if this is the last node on the chain.
Definition: chainimpl.h:432
RTEMS_INLINE_ROUTINE void _Chain_Initialize_empty(Chain_Control *the_chain)
Initializes this chain as empty.
Definition: chainimpl.h:505
RTEMS_INLINE_ROUTINE void _Chain_Append_if_is_off_chain_unprotected(Chain_Control *the_chain, Chain_Node *the_node)
Appends a node on the end of a chain if the node is in the off chain state (unprotected).
Definition: chainimpl.h:711
RTEMS_INLINE_ROUTINE Chain_Node * _Chain_Get_first_unprotected(Chain_Control *the_chain)
Definition: chainimpl.h:592
RTEMS_INLINE_ROUTINE bool _Chain_Is_first(const Chain_Node *the_node)
Checks if this is the first node on the chain.
Definition: chainimpl.h:413
RTEMS_INLINE_ROUTINE bool _Chain_Append_with_empty_check_unprotected(Chain_Control *the_chain, Chain_Node *the_node)
Appends a node and checks if the chain was empty before (unprotected).
Definition: chainimpl.h:754
size_t _Chain_Node_count_unprotected(const Chain_Control *chain)
Returns the node count of the chain.
Definition: chainnodecount.c:21
RTEMS_INLINE_ROUTINE const Chain_Node * _Chain_Immutable_first(const Chain_Control *the_chain)
Returns pointer to immutable chain's first node.
Definition: chainimpl.h:277
RTEMS_INLINE_ROUTINE bool _Chain_Are_nodes_equal(const Chain_Node *left, const Chain_Node *right)
Checks if two nodes are equal.
Definition: chainimpl.h:161
RTEMS_INLINE_ROUTINE void _Chain_Extract_unprotected(Chain_Node *the_node)
Extracts this node (unprotected).
Definition: chainimpl.h:558
void _Chain_Initialize(Chain_Control *the_chain, void *starting_address, size_t number_nodes, size_t node_size)
Initializes a chain header.
Definition: chain.c:26
RTEMS_INLINE_ROUTINE Chain_Node * _Chain_Tail(Chain_Control *the_chain)
Returns pointer to chain tail.
Definition: chainimpl.h:227
RTEMS_INLINE_ROUTINE bool _Chain_Prepend_with_empty_check_unprotected(Chain_Control *the_chain, Chain_Node *the_node)
Prepends a node and checks if the chain was empty before (unprotected).
Definition: chainimpl.h:780
RTEMS_INLINE_ROUTINE bool _Chain_Is_empty(const Chain_Control *the_chain)
Checks if the chain is empty.
Definition: chainimpl.h:393
RTEMS_INLINE_ROUTINE void _Chain_Insert_ordered_unprotected(Chain_Control *the_chain, Chain_Node *to_insert, const void *left, Chain_Node_order order)
Inserts a node into the chain according to the order relation.
Definition: chainimpl.h:864
RTEMS_INLINE_ROUTINE const Chain_Node * _Chain_Immutable_tail(const Chain_Control *the_chain)
Returns pointer to immutable chain tail.
Definition: chainimpl.h:243
RTEMS_INLINE_ROUTINE const Chain_Node * _Chain_Immutable_next(const Chain_Node *the_node)
Returns pointer to the immutable next node from this node.
Definition: chainimpl.h:343
RTEMS_INLINE_ROUTINE const Chain_Node * _Chain_Immutable_last(const Chain_Control *the_chain)
Returns pointer to immutable chain's last node.
Definition: chainimpl.h:311
RTEMS_INLINE_ROUTINE void _Chain_Iterator_set_position(Chain_Iterator *the_iterator, Chain_Node *the_node)
Sets the iterator position.
Definition: chainimpl.h:1106
RTEMS_INLINE_ROUTINE void _Chain_Prepend_unprotected(Chain_Control *the_chain, Chain_Node *the_node)
Prepends a node (unprotected).
Definition: chainimpl.h:732
RTEMS_INLINE_ROUTINE Chain_Node * _Chain_Head(Chain_Control *the_chain)
Returns pointer to chain head.
Definition: chainimpl.h:195
bool(* Chain_Node_order)(const void *left, const Chain_Node *right)
Chain node order.
Definition: chainimpl.h:844
RTEMS_INLINE_ROUTINE bool _Chain_Get_with_empty_check_unprotected(Chain_Control *the_chain, Chain_Node **the_node)
Gets the first node and checks if the chain is empty afterwards (unprotected).
Definition: chainimpl.h:810
RTEMS_INLINE_ROUTINE bool _Chain_Is_null_node(const Chain_Node *the_node)
Checks if the chain node pointer is NULL.
Definition: chainimpl.h:179
RTEMS_INLINE_ROUTINE void _Chain_Append_unprotected(Chain_Control *the_chain, Chain_Node *the_node)
Appends a node (unprotected).
Definition: chainimpl.h:680
RTEMS_INLINE_ROUTINE Chain_Node * _Chain_Iterator_next(const Chain_Iterator *the_iterator)
Returns the next node in the iterator direction.
Definition: chainimpl.h:1089
RTEMS_INLINE_ROUTINE void _Chain_Initialize_node(Chain_Node *the_node)
Initializes a chain node.
Definition: chainimpl.h:122
RTEMS_INLINE_ROUTINE void _Chain_Iterator_registry_update(Chain_Iterator_registry *the_registry, Chain_Node *the_node_to_extract)
Updates all iterators present in the chain iterator registry in case of a node extraction.
Definition: chainimpl.h:970
RTEMS_INLINE_ROUTINE Chain_Node * _Chain_Next(const Chain_Node *the_node)
Returns pointer to the next node from this node.
Definition: chainimpl.h:327
The chain iterator direction.
Definition: chainimpl.h:884
RTEMS_INLINE_ROUTINE void _Chain_Iterator_registry_initialize(Chain_Iterator_registry *the_registry)
Initializes a chain iterator registry.
Definition: chainimpl.h:951
RTEMS_INLINE_ROUTINE bool _Chain_Is_tail(const Chain_Control *the_chain, const Chain_Node *the_node)
Checks if this node is the chain tail.
Definition: chainimpl.h:490
RTEMS_INLINE_ROUTINE bool _Chain_Is_node_off_chain(const Chain_Node *node)
Checks if the node is off chain.
Definition: chainimpl.h:142
RTEMS_INLINE_ROUTINE void _Chain_Iterator_destroy(Chain_Iterator *the_iterator)
Destroys the iterator.
Definition: chainimpl.h:1121
RTEMS_INLINE_ROUTINE Chain_Node * _Chain_Previous(const Chain_Node *the_node)
Returns pointer to the previous node from this node.
Definition: chainimpl.h:359
RTEMS_INLINE_ROUTINE void _Chain_Set_off_chain(Chain_Node *node)
Sets off chain.
Definition: chainimpl.h:104
RTEMS_INLINE_ROUTINE const Chain_Node * _Chain_Immutable_previous(const Chain_Node *the_node)
Returns pointer to the immutable previous node from this node.
Definition: chainimpl.h:375
RTEMS_INLINE_ROUTINE void _Chain_Iterator_initialize(Chain_Control *the_chain, Chain_Iterator_registry *the_registry, Chain_Iterator *the_iterator, Chain_Iterator_direction direction)
Initializes the chain iterator.
Definition: chainimpl.h:1057
RTEMS_INLINE_ROUTINE Chain_Node * _Chain_First(const Chain_Control *the_chain)
Returns pointer to chain's first node.
Definition: chainimpl.h:260
@ CHAIN_ITERATOR_BACKWARD
Iteration from tail to head.
Definition: chainimpl.h:893
@ CHAIN_ITERATOR_FORWARD
Iteration from head to tail.
Definition: chainimpl.h:888
Chain Handler API.
A registry for chain iterators.
Definition: chainimpl.h:934
A chain iterator which is updated during node extraction if it is properly registered.
Definition: chainimpl.h:902
Chain_Node * position
The current position of this iterator.
Definition: chainimpl.h:925
Chain_Node Registry_node
Node for registration.
Definition: chainimpl.h:908
The direction of this iterator.
Definition: chainimpl.h:915
Definition: chain.h:68
Chain_Node * previous
Definition: chain.h:72
Chain_Node * next
Definition: chain.h:70
Definition: chain.h:86
