RTEMS 5.2
bsp.h
1
9/*
10 * uC5282 BSP header file
11 *
12 * Author: W. Eric Norum <norume@aps.anl.gov>
13 *
14 * COPYRIGHT (c) 2005.
15 * On-Line Applications Research Corporation (OAR).
16 *
17 * The license and distribution terms for this file may be
18 * found in the file LICENSE in this distribution or at
19 * http://www.rtems.org/license/LICENSE.
20 */
21
22#ifndef LIBBSP_M68K_UC5282_BSP_H
23#define LIBBSP_M68K_UC5282_BSP_H
24
35#include <bspopts.h>
37
38#include <rtems.h>
39#include <rtems/bspIo.h>
40
41#ifdef __cplusplus
42extern "C" {
43#endif
44
45/***************************************************************************/
47/*
48 * Uncomment to use instruction/data cache
49 * Leave commented to use instruction-only cache
50 */
51#define RTEMS_MCF5282_BSP_ENABLE_DATA_CACHE
52
53/***************************************************************************/
55#include <mcf5282/mcf5282.h> /* internal MCF5282 modules */
56
57/***************************************************************************/
59struct rtems_bsdnet_ifconfig;
60extern int rtems_fec_driver_attach (struct rtems_bsdnet_ifconfig *config, int attaching );
61#define RTEMS_BSP_NETWORK_DRIVER_NAME "fs1"
62#define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_fec_driver_attach
63
64/***************************************************************************/
67/* define which port the console should use - all other ports are then defined as general purpose */
68#define CONSOLE_PORT 0
69
70/* functions */
71
72typedef struct {
73 unsigned int l;
74 void *v;
76
77#define RTEMS_BSP_PGM_ERASE_FIRST 0x1
78#define RTEMS_BSP_PGM_RESET_AFTER 0x2
79#define RTEMS_BSP_PGM_EXEC_AFTER 0x4
80#define RTEMS_BSP_PGM_HALT_AFTER 0x8
81
82uint32_t bsp_get_CPU_clock_speed(void);
83rtems_status_code bsp_allocate_interrupt(int level, int priority);
84int bsp_sysReset(int flags);
85int bsp_program(bsp_mnode_t *chain, int flags);
86unsigned const char *bsp_gethwaddr(int a);
87const char *bsp_getbenv(const char *a);
88int bsp_flash_erase_range(volatile unsigned short *flashptr, int start, int end);
89int bsp_flash_write_range(volatile unsigned short *flashptr, bsp_mnode_t *chain, int offset);
90
91rtems_isr_entry set_vector(
92 rtems_isr_entry handler,
94 int type
95);
96
97/*
98 * Interrupt assignments
99 * Highest-priority listed first
100 */
101#define FEC_IRQ_LEVEL 4
102#define FEC_IRQ_RX_PRIORITY 7
103#define FEC_IRQ_TX_PRIORITY 6
104
105#define PIT3_IRQ_LEVEL 4
106#define PIT3_IRQ_PRIORITY 0
107
108#define UART0_IRQ_LEVEL 3
109#define UART0_IRQ_PRIORITY 7
110#define UART1_IRQ_LEVEL 3
111#define UART1_IRQ_PRIORITY 6
112#define UART2_IRQ_LEVEL 3
113#define UART2_IRQ_PRIORITY 5
114
115/*
116 * Fake VME support
117 * This makes it easier to use EPICS driver support on this BSP.
118 */
119#define VME_AM_STD_SUP_ASCENDING 0x3f
120#define VME_AM_STD_SUP_PGM 0x3e
121#define VME_AM_STD_USR_ASCENDING 0x3b
122#define VME_AM_STD_USR_PGM 0x3a
123#define VME_AM_STD_SUP_DATA 0x3d
124#define VME_AM_STD_USR_DATA 0x39
125#define VME_AM_EXT_SUP_ASCENDING 0x0f
126#define VME_AM_EXT_SUP_PGM 0x0e
127#define VME_AM_EXT_USR_ASCENDING 0x0b
128#define VME_AM_EXT_USR_PGM 0x0a
129#define VME_AM_EXT_SUP_DATA 0x0d
130#define VME_AM_EXT_USR_DATA 0x09
131#define VME_AM_SUP_SHORT_IO 0x2d
132#define VME_AM_USR_SHORT_IO 0x29
133
134/*
135 * 'Extended' BSP support
136 */
137rtems_status_code bspExtInit(void);
138typedef void (*BSP_VME_ISR_t)(void *usrArg, unsigned long vector);
139BSP_VME_ISR_t BSP_getVME_isr(unsigned long vector, void **parg);
140int BSP_installVME_isr(unsigned long vector, BSP_VME_ISR_t handler, void *usrArg);
141int BSP_removeVME_isr(unsigned long vector, BSP_VME_ISR_t handler, void *usrArg);
142int BSP_enableVME_int_lvl(unsigned int level);
143int BSP_disableVME_int_lvl(unsigned int level);
144int BSP_vme2local_adrs(unsigned am, unsigned long vmeaddr, unsigned long *plocaladdr);
145
146/*
147 * This BSP provides its own IDLE task to override the RTEMS one.
148 * So we prototype it and define the constant confdefs.h expects
149 * to configure a BSP specific one.
150 */
151void *bsp_idle_thread( uintptr_t ignored );
152#define BSP_IDLE_TASK_BODY bsp_idle_thread
153
154/*
155 * The custom IDLE task keeps some idle statistics.
156 */
157int bsp_cpu_load_percentage(void);
158
159/*
160 * This is a helper method to determine the cause of a reset.
161 */
162void bsp_reset_cause(char *buf, size_t capacity);
163
164/*
165 * SRAM. The BSP uses SRAM for maintaining some clock-driver data
166 * and for ethernet descriptors (and the initial stack during
167 * early boot).
168 */
169
170typedef struct mcf5282BufferDescriptor_ {
171 volatile uint16_t status;
172 uint16_t length;
173 volatile void *buffer;
175
176extern struct {
177 uint32_t idle_counter;
178 uint32_t filtered_idle;
179 uint32_t max_idle_count;
180 uint32_t pitc_per_tick;
181 uint32_t nsec_per_pitc;
182 uint32_t pad[3]; /* align to 16-bytes for descriptors */
183 mcf5282BufferDescriptor_t fec_descriptors[];
184 /* buffer descriptors are allocated from here */
185
186 /* initial stack is at top of SRAM (start.S) */
187} __SRAMBASE;
188
189#ifdef __cplusplus
190}
191#endif
192
195#endif
Interface to Kernel Print Methods.
DEFAULT_INITIAL_EXTENSION Support.
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
rtems_status_code
Classic API Status.
Definition: status.h:43
void * bsp_idle_thread(uintptr_t ignored)
Optimized idle task.
Definition: bspidle.c:26
rtems_isr_entry set_vector(rtems_isr_entry handler, rtems_vector_number vector, int type)
Install an interrupt handler.
Definition: setvec.c:28
Definition: bsp.h:72
Definition: deflate.c:115
Definition: network.c:75
unsigned v
Definition: tte.h:0
unsigned l
Definition: tte.h:13
