#include <stdarg.h>
#include <rtems/libio.h>
#include <rtems/error.h>
#include <sys/types.h>
#include <sys/param.h>
#include <sys/domain.h>
#include <sys/mbuf.h>
#include <sys/socketvar.h>
#include <sys/socket.h>
#include <sys/sockio.h>
#include <sys/callout.h>
#include <sys/proc.h>
#include <sys/ioctl.h>
#include <net/if.h>
#include <net/route.h>
#include <netinet/in.h>
#include <vm/vm.h>
#include <arpa/inet.h>
#include <net/netisr.h>
#include "loop.h"
struct | newtask |
void | sysctl_register_all (void *arg) |
uint32_t | rtems_bsdnet_semaphore_release_recursive (void) |
void | rtems_bsdnet_semaphore_obtain_recursive (uint32_t nest_count) |
void * | malloc (size_t) |
void | free (void *) |
void * | rtems_bsdnet_malloc (size_t size, int type, int flags) |
void | rtems_bsdnet_free (void *addr, int type) |
void | rtems_set_udp_buffer_sizes (u_long, u_long) |
void | rtems_set_tcp_buffer_sizes (u_long, u_long) |
void | rtems_set_sb_efficiency (u_long) |
void | rtems_bsdnet_semaphore_obtain (void) |
void | rtems_bsdnet_semaphore_release (void) |
int | sbwait (struct sockbuf *sb) |
void | sowakeup (struct socket *so, struct sockbuf *sb) |
int | sb_lock (struct sockbuf *sb) |
void | wakeup (void *p) |
int | soconnsleep (struct socket *so) |
void | soconnwakeup (struct socket *so) |
void | rtems_bsdnet_schednetisr (int n) |
rtems_id | rtems_bsdnet_newproc (char *name, int stacksize, void(*entry)(void *), void *arg) |
rtems_status_code | rtems_bsdnet_event_receive (rtems_event_set event_in, rtems_option option_set, rtems_interval ticks, rtems_event_set *event_out) |
unsigned long | rtems_bsdnet_random (void) |
void | rtems_bsdnet_timeout (void(*ftn)(void *), void *arg, int ticks) |
int | hzto (struct timeval *tv) |
void | rtems_bsdnet_log (int priority, const char *fmt,...) |
u_int | in_cksum_hdr (const void *ip) |
int | rtems_bsdnet_rtrequest (int req, struct sockaddr *dst, struct sockaddr *gateway, struct sockaddr *netmask, int flags, struct rtentry **net_nrt) |
int | rtems_bsdnet_initialize_network (void) |
void | rtems_bsdnet_attach (struct rtems_bsdnet_ifconfig *ifp) |
void | rtems_bsdnet_detach (struct rtems_bsdnet_ifconfig *ifp) |
int | rtems_bsdnet_ifconfig (const char *ifname, uint32_t cmd, void *param) |
int | rtems_bsdnet_parse_driver_name (const struct rtems_bsdnet_ifconfig *config, char **namep) |
Splits a network interface name with interface configuration config into the unit name and number parts. More... | |
int | m_mballoc (int nmb, int nowait) |
int | m_clalloc (int ncl, int nowait) |
uint32_t | nmbclusters = (128L * 1024L) / MCLBYTES |
Semaphore_Control * | the_networkSemaphore |
int | rtems_bsdnet_ticks_per_second |
int | rtems_bsdnet_microseconds_per_tick |
struct callout * | callfree = NULL |
struct callout | calltodo |
int | nfs_diskless_valid |
struct in_addr | rtems_bsdnet_log_host_address = {0} |
struct in_addr | rtems_bsdnet_bootp_server_address = {0} |
char * | rtems_bsdnet_bootp_boot_file_name = 0 |
char * | rtems_bsdnet_bootp_server_name = 0 |
char * | rtems_bsdnet_domain_name = 0 |
char * | rtems_bsdnet_bootp_cmdline = 0 |
struct in_addr * | rtems_bsdnet_nameserver = _rtems_bsdnet_nameserver |
int | rtems_bsdnet_nameserver_count = 0 |
struct in_addr * | rtems_bsdnet_ntpserver = _rtems_bsdnet_ntpserver |
int | rtems_bsdnet_ntpserver_count = 0 |
int32_t | rtems_bsdnet_timeoffset = 0 |
struct domain | routedomain |
struct domain | inetdomain |
int | rtems_bsdnet_log_priority |
int rtems_bsdnet_parse_driver_name | ( | const struct rtems_bsdnet_ifconfig * | config, |
char ** | namep | ||
Memory for the unit name will be allocated from the heap and copied to namep. If namep is NULL nothing will be allocated and copied.
Returns the unit number or -1 on error.
