inet.h
1 /*
2  * ++Copyright++ 1983, 1993
3  * -
4  * Copyright (c) 1983, 1993
5  * The Regents of the University of California. All rights reserved.
6  *
7  * Redistribution and use in source and binary forms, with or without
8  * modification, are permitted provided that the following conditions
9  * are met:
10  * 1. Redistributions of source code must retain the above copyright
11  * notice, this list of conditions and the following disclaimer.
12  * 2. Redistributions in binary form must reproduce the above copyright
13  * notice, this list of conditions and the following disclaimer in the
14  * documentation and/or other materials provided with the distribution.
15  * 3. Neither the name of the University nor the names of its contributors
16  * may be used to endorse or promote products derived from this software
17  * without specific prior written permission.
18  *
19  * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
20  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
21  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
22  * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
23  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
24  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
25  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
26  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
27  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
28  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
29  * SUCH DAMAGE.
30  * -
31  * Portions Copyright (c) 1993 by Digital Equipment Corporation.
32  *
33  * Permission to use, copy, modify, and distribute this software for any
34  * purpose with or without fee is hereby granted, provided that the above
35  * copyright notice and this permission notice appear in all copies, and that
36  * the name of Digital Equipment Corporation not be used in advertising or
37  * publicity pertaining to distribution of the document or software without
38  * specific, written prior permission.
39  *
40  * THE SOFTWARE IS PROVIDED "AS IS" AND DIGITAL EQUIPMENT CORP. DISCLAIMS ALL
41  * WARRANTIES WITH REGARD TO THIS SOFTWARE, INCLUDING ALL IMPLIED WARRANTIES
42  * OF MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL DIGITAL EQUIPMENT
43  * CORPORATION BE LIABLE FOR ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL
44  * DAMAGES OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR
45  * PROFITS, WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS
46  * ACTION, ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS
47  * SOFTWARE.
48  * -
49  * --Copyright--
50  */
51
52 /*%
53  * @(#)inet.h 8.1 (Berkeley) 6/2/93
54  * $FreeBSD: src/include/arpa/inet.h,v 1.33 2010/07/06 03:48:46 maxim Exp $
55  */
56
57
58 #ifndef _ARPA_INET_H_
59 #define _ARPA_INET_H_
60
61 /* External definitions for functions in inet(3). */
62
63 #include <sys/cdefs.h>
64 #include <rtems/bsdnet/_types.h>
65
66 /* Required for byteorder(3) functions. */
67 #include <rtems/endian.h>
68
69 #define INET_ADDRSTRLEN 16
70 #define INET6_ADDRSTRLEN 46
71
72 #ifndef _IN_ADDR_T_DECLARED
73 typedef uint32_t in_addr_t;
74 #define _IN_ADDR_T_DECLARED
75 #endif
76
77 #ifndef _IN_PORT_T_DECLARED
78 typedef uint16_t in_port_t;
79 #define _IN_PORT_T_DECLARED
80 #endif
81
82 /*
83  * XXX socklen_t is used by a POSIX.1-2001 interface, but not required by
84  * POSIX.1-2001.
85  */
86 #ifndef _SOCKLEN_T_DECLARED
87 typedef __socklen_t socklen_t;
88 #define _SOCKLEN_T_DECLARED
89 #endif
90
91 #ifndef _STRUCT_IN_ADDR_DECLARED
92 struct in_addr {
93  in_addr_t s_addr;
94 };
95 #define _STRUCT_IN_ADDR_DECLARED
96 #endif
97
98 #if !defined(__rtems__) /* RTEMS -- Why rename these? */
99 /* XXX all new diversions!! argh!! */
100 #if __BSD_VISIBLE
101 #define inet_addr __inet_addr
102 #define inet_aton __inet_aton
103 #define inet_lnaof __inet_lnaof
104 #define inet_makeaddr __inet_makeaddr
105 #define inet_neta __inet_neta
106 #define inet_netof __inet_netof
107 #define inet_network __inet_network
108 #define inet_net_ntop __inet_net_ntop
109 #define inet_net_pton __inet_net_pton
110 #define inet_cidr_ntop __inet_cidr_ntop
111 #define inet_cidr_pton __inet_cidr_pton
112 #define inet_ntoa __inet_ntoa
113 #define inet_ntoa_r __inet_ntoa_r
114 #define inet_pton __inet_pton
115 #define inet_ntop __inet_ntop
116 #define inet_nsap_addr __inet_nsap_addr
117 #define inet_nsap_ntoa __inet_nsap_ntoa
118 #endif /* __BSD_VISIBLE */
119 #endif /* __rtems__ */
120
121 __BEGIN_DECLS
122 in_addr_t inet_addr(const char *);
123 char *inet_ntoa(struct in_addr);
124 const char *inet_ntop(int, const void * __restrict, char * __restrict,
125  socklen_t);
126 int inet_pton(int, const char * __restrict, void * __restrict);
127
128 #if __BSD_VISIBLE
129 int inet_aton(const char *, struct in_addr *);
130 in_addr_t inet_lnaof(struct in_addr);
131 struct in_addr inet_makeaddr(in_addr_t, in_addr_t);
132 char * inet_neta(in_addr_t, char *, size_t);
133 in_addr_t inet_netof(struct in_addr);
134 in_addr_t inet_network(const char *);
135 char *inet_net_ntop(int, const void *, int, char *, size_t);
136 int inet_net_pton(int, const char *, void *, size_t);
137 unsigned inet_nsap_addr(const char *, unsigned char *, int);
138 char *inet_nsap_ntoa(int, const unsigned char *, char *);
139 #endif /* __BSD_VISIBLE */
140 __END_DECLS
141
142 #endif /* !_ARPA_INET_H_ */
This include file provides endian information about the target.
Definition: inet.h:93
