libnetworking
net
netisr.h
1
2
* Copyright (c) 1980, 1986, 1989, 1993
3
* The Regents of the University of California. All rights reserved.
4
5
6
* modification, are permitted provided that the following conditions
7
* are met:
8
* 1. Redistributions of source code must retain the above copyright
9
* notice, this list of conditions and the following disclaimer.
10
* 2. Redistributions in binary form must reproduce the above copyright
11
* notice, this list of conditions and the following disclaimer in the
12
* documentation and/or other materials provided with the distribution.
13
* 4. Neither the name of the University nor the names of its contributors
14
* may be used to endorse or promote products derived from this software
15
* without specific prior written permission.
16
17
* THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
18
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20
* ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
21
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
22
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
23
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
24
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
25
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
26
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
27
* SUCH DAMAGE.
28
29
* @(#)netisr.h 8.1 (Berkeley) 6/10/93
30
* $FreeBSD: src/sys/net/netisr.h,v 1.33 2005/01/07 01:45:35 imp Exp $
31
32
33
34
#ifndef _NET_NETISR_H_
35
#define _NET_NETISR_H_
36
37
38
* The networking code runs off software interrupts.
39
40
* You can switch into the network by doing splnet() and return by splx().
41
* The software interrupt level for the network is higher than the software
42
* level for the clock (so you can enter the network in routines called
43
* at timeout time).
44
45
46
47
* Each ``pup-level-1'' input queue has a bit in a ``netisr'' status
48
* word which is used to de-multiplex a single software
49
* interrupt used for scheduling the network code to calls
50
* on the lowest level routine of each protocol.
51
52
#define NETISR_RAW 0
/* same as AF_UNSPEC */
53
#define NETISR_IP 2
/* same as AF_INET */
54
#define NETISR_IMP 3
/* same as AF_IMPLINK */
55
#define NETISR_ISO 7
/* same as AF_ISO */
56
#define NETISR_CCITT 10
/* same as AF_CCITT */
57
#define NETISR_ATALK 16
/* same as AF_APPLETALK */
58
#define NETISR_ARP 18
/* same as AF_LINK */
59
#define NETISR_IPX 23
/* same as AF_IPX */
60
#define NETISR_USB 25
/* USB soft interrupt */
61
#define NETISR_PPP 26
/* PPP soft interrupt */
62
63
#ifndef LOCORE
64
#ifdef _KERNEL
65
66
#define NETISR_SET(num, isr)
/* FIXME: dummy, should be removed */
67
68
extern
volatile
unsigned
int
netisr;
/* scheduling bits for network */
69
#define schednetisr(anisr) rtems_bsdnet_schednetisr(anisr)
70
71
#endif
72
#endif
73
74
#endif
