libnetworking
vm
vm.h
1
2
* Copyright (c) 1991, 1993
3
* The Regents of the University of California. All rights reserved.
4
5
6
* modification, are permitted provided that the following conditions
7
* are met:
8
* 1. Redistributions of source code must retain the above copyright
9
* notice, this list of conditions and the following disclaimer.
10
* 2. Redistributions in binary form must reproduce the above copyright
11
* notice, this list of conditions and the following disclaimer in the
12
* documentation and/or other materials provided with the distribution.
13
* 4. Neither the name of the University nor the names of its contributors
14
* may be used to endorse or promote products derived from this software
15
* without specific prior written permission.
16
17
* THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
18
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20
* ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
21
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
22
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
23
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
24
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
25
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
26
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
27
* SUCH DAMAGE.
28
29
* @(#)vm.h 8.2 (Berkeley) 12/13/93
30
* @(#)vm_prot.h 8.1 (Berkeley) 6/11/93
31
* @(#)vm_inherit.h 8.1 (Berkeley) 6/11/93
32
33
* Copyright (c) 1987, 1990 Carnegie-Mellon University.
34
* All rights reserved.
35
36
* Authors: Avadis Tevanian, Jr., Michael Wayne Young
37
38
* Permission to use, copy, modify and distribute this software and
39
* its documentation is hereby granted, provided that both the copyright
40
* notice and this permission notice appear in all copies of the
41
* software, derivative works or modified versions, and any portions
42
* thereof, and that both notices appear in supporting documentation.
43
44
* CARNEGIE MELLON ALLOWS FREE USE OF THIS SOFTWARE IN ITS "AS IS"
45
* CONDITION. CARNEGIE MELLON DISCLAIMS ANY LIABILITY OF ANY KIND
46
* FOR ANY DAMAGES WHATSOEVER RESULTING FROM THE USE OF THIS SOFTWARE.
47
48
* Carnegie Mellon requests users of this software to return to
49
50
* Software Distribution Coordinator or Software.Distribution@CS.CMU.EDU
51
* School of Computer Science
52
* Carnegie Mellon University
53
* Pittsburgh PA 15213-3890
54
55
* any improvements or extensions that they make and grant Carnegie the
56
* rights to redistribute these changes.
57
58
* $FreeBSD: src/sys/vm/vm.h,v 1.28 2007/12/27 17:08:11 alc Exp $
59
60
61
#ifndef VM_H
62
#define VM_H
63
64
typedef
char
vm_inherit_t;
/* XXX: inheritance codes */
65
typedef
u_char vm_prot_t;
/* protection codes */
66
67
union
vm_map_object;
68
typedef
union
vm_map_object vm_map_object_t;
69
70
struct
vm_map_entry;
71
typedef
struct
vm_map_entry *vm_map_entry_t;
72
73
struct
vm_map;
74
typedef
struct
vm_map *vm_map_t;
75
76
struct
vm_object;
77
typedef
struct
vm_object *vm_object_t;
78
79
#ifndef _KERNEL
80
81
* This is defined in <sys/types.h> for the kernel so that non-vm kernel
82
* sources (mainly Mach-derived ones such as ddb) don't have to include
83
* vm stuff. Defining it there for applications might break things.
84
* Define it here for "applications" that include vm headers (e.g.,
85
* genassym).
86
87
typedef
int
boolean_t;
88
89
90
* This is defined in <sys/types.h> for the kernel so that vnode_if.h
91
* doesn't have to include <vm/vm.h>.
92
93
struct
vm_page;
94
typedef
struct
vm_page *vm_page_t;
95
#endif
/* _KERNEL */
96
97
#endif
/* VM_H */
