Files | Macros | Typedefs
Collaboration diagram for Event Set:
file  eventreceive.c
 Constant used to receive the set of currently pending events in.
#define RTEMS_ALL_EVENTS   0xFFFFFFFF
 Constant used to send or receive all events.
#define RTEMS_EVENT_0   0x00000001
 Defines the bit in the event set associated with event 0. More...
#define RTEMS_EVENT_1   0x00000002
 Defines the bit in the event set associated with event 1. More...
#define RTEMS_EVENT_2   0x00000004
 Defines the bit in the event set associated with event 2. More...
#define RTEMS_EVENT_3   0x00000008
 Defines the bit in the event set associated with event 3. More...
#define RTEMS_EVENT_4   0x00000010
 Defines the bit in the event set associated with event 4. More...
#define RTEMS_EVENT_5   0x00000020
 Defines the bit in the event set associated with event 5. More...
#define RTEMS_EVENT_6   0x00000040
 Defines the bit in the event set associated with event 6. More...
#define RTEMS_EVENT_7   0x00000080
 Defines the bit in the event set associated with event 7. More...
#define RTEMS_EVENT_8   0x00000100
 Defines the bit in the event set associated with event 8. More...
#define RTEMS_EVENT_9   0x00000200
 Defines the bit in the event set associated with event 9. More...
#define RTEMS_EVENT_10   0x00000400
 Defines the bit in the event set associated with event 10. More...
#define RTEMS_EVENT_11   0x00000800
 Defines the bit in the event set associated with event 11. More...
#define RTEMS_EVENT_12   0x00001000
 Defines the bit in the event set associated with event 12. More...
#define RTEMS_EVENT_13   0x00002000
 Defines the bit in the event set associated with event 13. More...
#define RTEMS_EVENT_14   0x00004000
 Defines the bit in the event set associated with event 14. More...
#define RTEMS_EVENT_15   0x00008000
 Defines the bit in the event set associated with event 15. More...
#define RTEMS_EVENT_16   0x00010000
 Defines the bit in the event set associated with event 16. More...
#define RTEMS_EVENT_17   0x00020000
 Defines the bit in the event set associated with event 17. More...
#define RTEMS_EVENT_18   0x00040000
 Defines the bit in the event set associated with event 18. More...
#define RTEMS_EVENT_19   0x00080000
 Defines the bit in the event set associated with event 19. More...
#define RTEMS_EVENT_20   0x00100000
 Defines the bit in the event set associated with event 20. More...
#define RTEMS_EVENT_21   0x00200000
 Defines the bit in the event set associated with event 21. More...
#define RTEMS_EVENT_22   0x00400000
 Defines the bit in the event set associated with event 22. More...
#define RTEMS_EVENT_23   0x00800000
 Defines the bit in the event set associated with event 23. More...
#define RTEMS_EVENT_24   0x01000000
 Defines the bit in the event set associated with event 24. More...
#define RTEMS_EVENT_25   0x02000000
 Defines the bit in the event set associated with event 25. More...
#define RTEMS_EVENT_26   0x04000000
 Defines the bit in the event set associated with event 26. More...
#define RTEMS_EVENT_27   0x08000000
 Defines the bit in the event set associated with event 27. More...
#define RTEMS_EVENT_28   0x10000000
 Defines the bit in the event set associated with event 29. More...
#define RTEMS_EVENT_29   0x20000000
#define RTEMS_EVENT_30   0x40000000
 Defines the bit in the event set associated with event 30. More...
#define RTEMS_EVENT_31   0x80000000
 Defines the bit in the event set associated with event 31. More...
typedef uint32_t rtems_event_set
 Integer type to hold an event set of up to 32 events represented as a bit field.
◆ RTEMS_EVENT_0
◆ RTEMS_EVENT_1
◆ RTEMS_EVENT_10
◆ RTEMS_EVENT_11
◆ RTEMS_EVENT_12
◆ RTEMS_EVENT_13
◆ RTEMS_EVENT_14
◆ RTEMS_EVENT_15
◆ RTEMS_EVENT_16
◆ RTEMS_EVENT_17
◆ RTEMS_EVENT_18
◆ RTEMS_EVENT_19
◆ RTEMS_EVENT_2
◆ RTEMS_EVENT_20
◆ RTEMS_EVENT_21
◆ RTEMS_EVENT_22
◆ RTEMS_EVENT_23
◆ RTEMS_EVENT_24
◆ RTEMS_EVENT_25
◆ RTEMS_EVENT_26
◆ RTEMS_EVENT_27
◆ RTEMS_EVENT_28
◆ RTEMS_EVENT_29
◆ RTEMS_EVENT_3
◆ RTEMS_EVENT_30
◆ RTEMS_EVENT_31
◆ RTEMS_EVENT_4
◆ RTEMS_EVENT_5
◆ RTEMS_EVENT_6
◆ RTEMS_EVENT_7
◆ RTEMS_EVENT_8
◆ RTEMS_EVENT_9
