rtems_bsdnet.h
1
6 #ifndef _RTEMS_BSDNET_H
7 #define _RTEMS_BSDNET_H
8
9 #ifdef __cplusplus
10 extern "C" {
11 #endif
12
13 #include <rtems.h>
14 #include <sys/cpuset.h>
15
16 /*
17  * If this file is included from inside the Network Stack proper or
18  * a device driver, then __INSIDE_RTEMS_BSD_TCPIP_STACK__ should be
19  * defined. This triggers a number of internally used definitions.
20  */
21
22 #if defined(__INSIDE_RTEMS_BSD_TCPIP_STACK__)
23 #undef _KERNEL
24 #undef INET
25 #undef NFS
26 #undef DIAGNOSTIC
27 #undef BOOTP_COMPAT
28 #undef __BSD_VISIBLE
29
30 #define _KERNEL
31 #define INET
32 #define NFS
33 #define DIAGNOSTIC
34 #define BOOTP_COMPAT
35 #define __BSD_VISIBLE 1
36 #endif
37
38 /*
39  * Values that may be obtained by BOOTP
40  */
41 extern struct in_addr rtems_bsdnet_bootp_server_address;
42 extern char *rtems_bsdnet_bootp_server_name;
43 extern char *rtems_bsdnet_bootp_boot_file_name;
44 extern char *rtems_bsdnet_bootp_cmdline;
45 extern int32_t rtems_bsdnet_timeoffset;
46
47 /*
48  * Manipulate routing tables
49  */
50 struct sockaddr;
51 struct rtentry;
52 int rtems_bsdnet_rtrequest (
53  int req,
54  struct sockaddr *dst,
55  struct sockaddr *gateway,
56  struct sockaddr *netmask,
57  int flags,
58  struct rtentry **net_nrt);
59
60 /*
61  * Diagnostics
62  */
63 void rtems_bsdnet_show_inet_routes (void);
64 void rtems_bsdnet_show_mbuf_stats (void);
65 void rtems_bsdnet_show_if_stats (void);
66 void rtems_bsdnet_show_ip_stats (void);
67 void rtems_bsdnet_show_icmp_stats (void);
68 void rtems_bsdnet_show_udp_stats (void);
69 void rtems_bsdnet_show_tcp_stats (void);
70
71 /*
72  * Network configuration
73  */
75  /*
76  * These three entries must be supplied for each interface.
77  */
78  char *name;
79
80  /*
81  * This function now handles attaching and detaching an interface.
82  * The parameter attaching indicates the operation being invoked.
83  * For older attach functions which do not have the extra parameter
84  * it will be ignored.
85  */
86  int (*attach)(struct rtems_bsdnet_ifconfig *conf, int attaching);
87
88  /*
89  * Link to next interface
90  */
91  struct rtems_bsdnet_ifconfig *next;
92
93  /*
94  * The following entries may be obtained
95  * from BOOTP or explicitily supplied.
96  */
97  char *ip_address;
98  char *ip_netmask;
99  void *hardware_address;
100
101  /*
102  * The driver assigns defaults values to the following
103  * entries if they are not explicitly supplied.
104  */
105  int ignore_broadcast;
106  int mtu;
107  int rbuf_count;
108  int xbuf_count;
109
110  /*
111  * For external ethernet controller board the following
112  * parameters are needed
113  */
114  unsigned int port; /* port of the board */
115  unsigned int irno; /* irq of the board */
116  unsigned int bpar; /* memory of the board */
117
118  /*
119  * Driver control block pointer. Typcially this points to the driver's
120  * controlling structure. You set this when you have the structure allocated
121  * externally to the driver.
122  */
123  void *drv_ctrl;
124
125 };
126
128  /*
129  * This entry points to the head of the ifconfig chain.
130  */
131  struct rtems_bsdnet_ifconfig *ifconfig;
132
133  /*
134  * This entry should be rtems_bsdnet_do_bootp if BOOTP
135  * is being used to configure the network, and NULL
136  * if BOOTP is not being used.
137  */
138  void (*bootp)(void);
139
140  /*
141  * The remaining items can be initialized to 0, in
142  * which case the default value will be used.
143  */
144  rtems_task_priority network_task_priority; /* 100 */
145  unsigned long mbuf_bytecount; /* 64 kbytes */
146  unsigned long mbuf_cluster_bytecount; /* 128 kbytes */
147  char *hostname; /* BOOTP */
148  char *domainname; /* BOOTP */
149  char *gateway; /* BOOTP */
150  char *log_host; /* BOOTP */
151  char *name_server[3]; /* BOOTP */
152  char *ntp_server[3]; /* BOOTP */
153  /*
154  * Default "multiplier" on buffer size. This is
155  * claimed by the TCP/IP implementation to be for
156  * efficiency but you will have to measure the
157  * benefit for buffering beyond double buffering
158  * in your own application.
159  *
160  * The default value is 2.
161  *
162  * See kern/uipc_socket2.c for details.
163  */
164  unsigned long sb_efficiency;
165  /*
166  * Default UDP buffer sizes PER SOCKET!!
167  *
168  * TX = 9216 -- max datagram size
169  * RX = 40 * (1024 + sizeof(struct sockaddr_in))
170  *
171  * See netinet/udp_usrreq.c for details
172  */
173  unsigned long udp_tx_buf_size;
174  unsigned long udp_rx_buf_size;
175  /*
176  * Default UDP buffer sizes PER SOCKET!!
177  *
178  * TX = 16 * 1024
179  * RX = 16 * 1024
180  *
181  * See netinet/tcp_usrreq.c for details
182  */
183  unsigned long tcp_tx_buf_size;
184  unsigned long tcp_rx_buf_size;
185
186  /*
187  * Default Network Tasks CPU Affinity
188  */
189 #ifdef RTEMS_SMP
190  const cpu_set_t *network_task_cpuset;
191  size_t network_task_cpuset_size;
192 #endif
193 };
194
195 /*
196  * Default global device configuration structure. This is scanned
197  * by the initialize network function. Check the network demo's for
198  * an example of the structure. Like the RTEMS configuration tables,
199  * they are not part of RTEMS but part of your application or bsp
200  * code.
201  */
202 extern struct rtems_bsdnet_config rtems_bsdnet_config;
203
204 /*
205  * Initialise the BSD stack, attach and `up' interfaces
206  * in the `rtems_bsdnet_config'. RTEMS must already be initialised.
207  */
208 int rtems_bsdnet_initialize_network (void);
209
210 /*
211  * Dynamic interface control. Drivers must free any resources such as
212  * memory, interrupts, io regions claimed during the `attach' and/or
213  * `up' operations when asked to `detach'.
214  * You must configure the interface after attaching it.
215  */
216 void rtems_bsdnet_attach (struct rtems_bsdnet_ifconfig *ifconfig);
217 void rtems_bsdnet_detach (struct rtems_bsdnet_ifconfig *ifconfig);
218
219 /*
220  * Interface configuration. The commands are listed in `sys/sockio.h'.
221  */
222 int rtems_bsdnet_ifconfig (const char *ifname, uint32_t cmd, void *param);
223
224 void rtems_bsdnet_do_bootp (void);
225 void rtems_bsdnet_do_bootp_and_rootfs (void);
226
227 /* NTP tuning parameters */
228 extern int rtems_bsdnet_ntp_retry_count;
229 extern int rtems_bsdnet_ntp_timeout_secs;
230 extern int rtems_bsdnet_ntp_bcast_timeout_secs;
231
232
233 struct timestamp {
234  uint32_t integer;
235  uint32_t fraction;
236 };
237
238 /* Data is passed in network byte order */
240  uint8_t li_vn_mode;
241  uint8_t stratum;
242  int8_t poll_interval;
243  int8_t precision;
244  int32_t root_delay;
245  int32_t root_dispersion;
246  char reference_identifier[4];
247  struct timestamp reference_timestamp;
248  struct timestamp originate_timestamp;
249  struct timestamp receive_timestamp;
250  struct timestamp transmit_timestamp;
251 };
252
253 /* NOTE: packet data is *only* accessible from the callback
254  *
255  * 'callback' is invoked twice, once prior to sending a request
256  * to the server and one more time after receiving a valid reply.
257  * This allows for the user to measure round-trip times.
258  *
259  * Semantics of the 'state' parameter:
260  *
261  * state == 1: 1st call, just prior to sending request. The
262  * packet has been set up already but may be
263  * modified by the callback (e.g. to set the originate
264  * timestamp).
265  * state == -1: 1st call - no request will be sent but we'll
266  * wait for a reply from a broadcast server. The
267  * packet has not been set up.
268  * state == 0: 2nd call. The user is responsible for keeping track
269  * of the 'state' during the first call in order to
270  * know if it makes sense to calculate 'round-trip' times.
271  *
272  * RETURN VALUE: the callback should return 0 if processing the packet was
273  * successful and -1 on error in which case rtems_bsdnet_get_ntp()
274  * may try another server.
275  */
276 typedef int (*rtems_bsdnet_ntp_callback_t)(
277  struct ntpPacketSmall *packet,
278  int state,
279  void *usr_data);
280
281 /* Obtain time from a NTP server and call user callback to process data;
282  * socket parameter may be -1 to request the routine to open and close its own socket.
283  * Networking parameters as configured are used...
284  *
285  * It is legal to pass a NULL callback pointer. In this case, a default callback
286  * is used which determines the current time by contacting an NTP server. The current
287  * time is converted to a 'struct timespec' (seconds/nanoseconds) and passed into *usr_data.
288  * The caller is responsible for providing a memory area >= sizeof(struct timespec).
289  *
290  * RETURNS: 0 on success, -1 on failure.
291  */
292 int rtems_bsdnet_get_ntp(int socket, rtems_bsdnet_ntp_callback_t callback, void *usr_data);
293
294 int rtems_bsdnet_synchronize_ntp (int interval, rtems_task_priority priority);
295
296 /*
297  * Callback to report BSD malloc starvation.
298  * The default implementation just prints a message but an application
299  * can provide its own version.
300  */
301 void rtems_bsdnet_malloc_starvation(void);
302
303 /*
304  * mbuf malloc interface to enable custom allocation of mbuf's
305  *
306  * May be declared in user code. If not, then the default is to
307  * malloc.
308  */
309 void* rtems_bsdnet_malloc_mbuf(size_t size, int type);
310
311 /*
312  * Possible values of the type parameter to rtems_bsdnet_malloc_mbuf to assist
313  * in allocation of the structure.
314  */
315 #define MBUF_MALLOC_NMBCLUSTERS (0)
316 #define MBUF_MALLOC_MCLREFCNT (1)
317 #define MBUF_MALLOC_MBUF (2)
318
319 #ifdef __cplusplus
320 }
321 #endif
322
323 #endif /* _RTEMS_BSDNET_H */
Definition: socketvar.h:49
Definition: rtems_bsdnet.h:239
Priority_Control rtems_task_priority
Define the type for an RTEMS API task priority.
Definition: tasks.h:79
Definition: demand.c:56
Definition: socket.h:180
Definition: inet.h:93
Definition: rtems_bsdnet.h:74
Definition: rtems_bsdnet.h:127
Definition: rtems_bsdnet.h:233
Definition: route.h:104
