| #define | HAL_SD_CARD_READY 0x00000001U |
| #define | HAL_SD_CARD_IDENTIFICATION 0x00000002U |
| #define | HAL_SD_CARD_STANDBY 0x00000003U |
| #define | HAL_SD_CARD_TRANSFER 0x00000004U |
| #define | HAL_SD_CARD_SENDING 0x00000005U |
| #define | HAL_SD_CARD_RECEIVING 0x00000006U |
| #define | HAL_SD_CARD_PROGRAMMING 0x00000007U |
| #define | HAL_SD_CARD_DISCONNECTED 0x00000008U |
| #define | HAL_SD_CARD_ERROR 0x000000FFU |
#define | SD_InitTypeDef SDMMC_InitTypeDef |
#define | SD_TypeDef SDMMC_TypeDef |
| #define | BLOCKSIZE ((uint32_t)512U) |
| #define | HAL_SD_ERROR_NONE SDMMC_ERROR_NONE |
| #define | HAL_SD_ERROR_CMD_CRC_FAIL SDMMC_ERROR_CMD_CRC_FAIL |
| #define | HAL_SD_ERROR_DATA_CRC_FAIL SDMMC_ERROR_DATA_CRC_FAIL |
| #define | HAL_SD_ERROR_CMD_RSP_TIMEOUT SDMMC_ERROR_CMD_RSP_TIMEOUT |
| #define | HAL_SD_ERROR_DATA_TIMEOUT SDMMC_ERROR_DATA_TIMEOUT |
| #define | HAL_SD_ERROR_TX_UNDERRUN SDMMC_ERROR_TX_UNDERRUN |
| #define | HAL_SD_ERROR_RX_OVERRUN SDMMC_ERROR_RX_OVERRUN |
| #define | HAL_SD_ERROR_ADDR_MISALIGNED SDMMC_ERROR_ADDR_MISALIGNED |
| #define | HAL_SD_ERROR_BLOCK_LEN_ERR SDMMC_ERROR_BLOCK_LEN_ERR |
| #define | HAL_SD_ERROR_ERASE_SEQ_ERR SDMMC_ERROR_ERASE_SEQ_ERR |
| #define | HAL_SD_ERROR_BAD_ERASE_PARAM SDMMC_ERROR_BAD_ERASE_PARAM |
| #define | HAL_SD_ERROR_WRITE_PROT_VIOLATION SDMMC_ERROR_WRITE_PROT_VIOLATION |
| #define | HAL_SD_ERROR_LOCK_UNLOCK_FAILED SDMMC_ERROR_LOCK_UNLOCK_FAILED |
| #define | HAL_SD_ERROR_COM_CRC_FAILED SDMMC_ERROR_COM_CRC_FAILED |
| #define | HAL_SD_ERROR_ILLEGAL_CMD SDMMC_ERROR_ILLEGAL_CMD |
| #define | HAL_SD_ERROR_CARD_ECC_FAILED SDMMC_ERROR_CARD_ECC_FAILED |
| #define | HAL_SD_ERROR_CC_ERR SDMMC_ERROR_CC_ERR |
| #define | HAL_SD_ERROR_GENERAL_UNKNOWN_ERR SDMMC_ERROR_GENERAL_UNKNOWN_ERR |
| #define | HAL_SD_ERROR_STREAM_READ_UNDERRUN SDMMC_ERROR_STREAM_READ_UNDERRUN |
| #define | HAL_SD_ERROR_STREAM_WRITE_OVERRUN SDMMC_ERROR_STREAM_WRITE_OVERRUN |
| #define | HAL_SD_ERROR_CID_CSD_OVERWRITE SDMMC_ERROR_CID_CSD_OVERWRITE |
| #define | HAL_SD_ERROR_WP_ERASE_SKIP SDMMC_ERROR_WP_ERASE_SKIP |
| #define | HAL_SD_ERROR_CARD_ECC_DISABLED SDMMC_ERROR_CARD_ECC_DISABLED |
| #define | HAL_SD_ERROR_ERASE_RESET SDMMC_ERROR_ERASE_RESET |
| #define | HAL_SD_ERROR_AKE_SEQ_ERR SDMMC_ERROR_AKE_SEQ_ERR |
| #define | HAL_SD_ERROR_INVALID_VOLTRANGE SDMMC_ERROR_INVALID_VOLTRANGE |
| #define | HAL_SD_ERROR_ADDR_OUT_OF_RANGE SDMMC_ERROR_ADDR_OUT_OF_RANGE |
| #define | HAL_SD_ERROR_REQUEST_NOT_APPLICABLE SDMMC_ERROR_REQUEST_NOT_APPLICABLE |
| #define | HAL_SD_ERROR_PARAM SDMMC_ERROR_INVALID_PARAMETER |
| #define | HAL_SD_ERROR_UNSUPPORTED_FEATURE SDMMC_ERROR_UNSUPPORTED_FEATURE |
| #define | HAL_SD_ERROR_BUSY SDMMC_ERROR_BUSY |
| #define | HAL_SD_ERROR_DMA SDMMC_ERROR_DMA |
| #define | HAL_SD_ERROR_TIMEOUT SDMMC_ERROR_TIMEOUT |
| #define | SD_CONTEXT_NONE ((uint32_t)0x00000000U) |
| #define | SD_CONTEXT_READ_SINGLE_BLOCK ((uint32_t)0x00000001U) |
| #define | SD_CONTEXT_READ_MULTIPLE_BLOCK ((uint32_t)0x00000002U) |
| #define | SD_CONTEXT_WRITE_SINGLE_BLOCK ((uint32_t)0x00000010U) |
| #define | SD_CONTEXT_WRITE_MULTIPLE_BLOCK ((uint32_t)0x00000020U) |
| #define | SD_CONTEXT_IT ((uint32_t)0x00000008U) |
| #define | SD_CONTEXT_DMA ((uint32_t)0x00000080U) |
| #define | CARD_NORMAL_SPEED ((uint32_t)0x00000000U) |
| #define | CARD_HIGH_SPEED ((uint32_t)0x00000100U) |
| #define | CARD_ULTRA_HIGH_SPEED ((uint32_t)0x00000200U) |
| #define | CARD_SDSC ((uint32_t)0x00000000U) |
| #define | CARD_SDHC_SDXC ((uint32_t)0x00000001U) |
#define | CARD_SECURED ((uint32_t)0x00000003U) |
#define | CARD_V1_X ((uint32_t)0x00000000U) |
#define | CARD_V2_X ((uint32_t)0x00000001U) |
| #define | __HAL_SD_RESET_HANDLE_STATE(__HANDLE__) ((__HANDLE__)->State = HAL_SD_STATE_RESET) |
| | Reset SD handle state.
| #define | __HAL_SD_ENABLE_IT(__HANDLE__, __INTERRUPT__) __SDMMC_ENABLE_IT((__HANDLE__)->Instance, (__INTERRUPT__)) |
| | Enable the SD device interrupt.
| #define | __HAL_SD_DISABLE_IT(__HANDLE__, __INTERRUPT__) __SDMMC_DISABLE_IT((__HANDLE__)->Instance, (__INTERRUPT__)) |
| | Disable the SD device interrupt.
| #define | __HAL_SD_GET_FLAG(__HANDLE__, __FLAG__) __SDMMC_GET_FLAG((__HANDLE__)->Instance, (__FLAG__)) |
| | Check whether the specified SD flag is set or not.
| #define | __HAL_SD_CLEAR_FLAG(__HANDLE__, __FLAG__) __SDMMC_CLEAR_FLAG((__HANDLE__)->Instance, (__FLAG__)) |
| | Clear the SD's pending flags.
| #define | __HAL_SD_GET_IT(__HANDLE__, __INTERRUPT__) __SDMMC_GET_IT((__HANDLE__)->Instance, (__INTERRUPT__)) |
| | Check whether the specified SD interrupt has occurred or not.
| #define | __HAL_SD_CLEAR_IT(__HANDLE__, __INTERRUPT__) __SDMMC_CLEAR_IT((__HANDLE__)->Instance, (__INTERRUPT__)) |
| | Clear the SD's interrupt pending bits.
HAL_StatusTypeDef | HAL_SD_Init (SD_HandleTypeDef *hsd) |
HAL_StatusTypeDef | HAL_SD_InitCard (SD_HandleTypeDef *hsd) |
HAL_StatusTypeDef | HAL_SD_DeInit (SD_HandleTypeDef *hsd) |
void | HAL_SD_MspInit (SD_HandleTypeDef *hsd) |
void | HAL_SD_MspDeInit (SD_HandleTypeDef *hsd) |
HAL_StatusTypeDef | HAL_SD_ReadBlocks (SD_HandleTypeDef *hsd, uint8_t *pData, uint32_t BlockAdd, uint32_t NumberOfBlocks, uint32_t Timeout) |
HAL_StatusTypeDef | HAL_SD_WriteBlocks (SD_HandleTypeDef *hsd, const uint8_t *pData, uint32_t BlockAdd, uint32_t NumberOfBlocks, uint32_t Timeout) |
HAL_StatusTypeDef | HAL_SD_Erase (SD_HandleTypeDef *hsd, uint32_t BlockStartAdd, uint32_t BlockEndAdd) |
HAL_StatusTypeDef | HAL_SD_ReadBlocks_IT (SD_HandleTypeDef *hsd, uint8_t *pData, uint32_t BlockAdd, uint32_t NumberOfBlocks) |
HAL_StatusTypeDef | HAL_SD_WriteBlocks_IT (SD_HandleTypeDef *hsd, const uint8_t *pData, uint32_t BlockAdd, uint32_t NumberOfBlocks) |
HAL_StatusTypeDef | HAL_SD_ReadBlocks_DMA (SD_HandleTypeDef *hsd, uint8_t *pData, uint32_t BlockAdd, uint32_t NumberOfBlocks) |
HAL_StatusTypeDef | HAL_SD_WriteBlocks_DMA (SD_HandleTypeDef *hsd, const uint8_t *pData, uint32_t BlockAdd, uint32_t NumberOfBlocks) |
void | HAL_SD_IRQHandler (SD_HandleTypeDef *hsd) |
void | HAL_SD_TxCpltCallback (SD_HandleTypeDef *hsd) |
void | HAL_SD_RxCpltCallback (SD_HandleTypeDef *hsd) |
void | HAL_SD_ErrorCallback (SD_HandleTypeDef *hsd) |
void | HAL_SD_AbortCallback (SD_HandleTypeDef *hsd) |
HAL_StatusTypeDef | HAL_SD_ConfigWideBusOperation (SD_HandleTypeDef *hsd, uint32_t WideMode) |
HAL_StatusTypeDef | HAL_SD_ConfigSpeedBusOperation (SD_HandleTypeDef *hsd, uint32_t SpeedMode) |
HAL_SD_CardStateTypeDef | HAL_SD_GetCardState (SD_HandleTypeDef *hsd) |
HAL_StatusTypeDef | HAL_SD_GetCardCID (SD_HandleTypeDef *hsd, HAL_SD_CardCIDTypeDef *pCID) |
HAL_StatusTypeDef | HAL_SD_GetCardCSD (SD_HandleTypeDef *hsd, HAL_SD_CardCSDTypeDef *pCSD) |
HAL_StatusTypeDef | HAL_SD_GetCardStatus (SD_HandleTypeDef *hsd, HAL_SD_CardStatusTypeDef *pStatus) |
HAL_StatusTypeDef | HAL_SD_GetCardInfo (SD_HandleTypeDef *hsd, HAL_SD_CardInfoTypeDef *pCardInfo) |
HAL_SD_StateTypeDef | HAL_SD_GetState (SD_HandleTypeDef *hsd) |
uint32_t | HAL_SD_GetError (SD_HandleTypeDef *hsd) |
HAL_StatusTypeDef | HAL_SD_Abort (SD_HandleTypeDef *hsd) |
HAL_StatusTypeDef | HAL_SD_Abort_IT (SD_HandleTypeDef *hsd) |
Header file of SD HAL module.
- Author
- MCD Application Team
- Attention
