RTEMS 6.1
stm32h7xx_hal_sd.h
1
19/* Define to prevent recursive inclusion -------------------------------------*/
20#ifndef STM32H7xx_HAL_SD_H
21#define STM32H7xx_HAL_SD_H
22
23#ifdef __cplusplus
24extern "C" {
25#endif
26
27/* Includes ------------------------------------------------------------------*/
28#include "stm32h7xx_ll_sdmmc.h"
29#if defined (DLYB_SDMMC1) || defined (DLYB_SDMMC2) || defined (DLYB_SDMMC3)
31#endif /* (DLYB_SDMMC1) || (DLYB_SDMMC2) */
32
43/* Exported types ------------------------------------------------------------*/
53typedef enum
54{
55 HAL_SD_STATE_RESET = ((uint32_t)0x00000000U),
56 HAL_SD_STATE_READY = ((uint32_t)0x00000001U),
57 HAL_SD_STATE_TIMEOUT = ((uint32_t)0x00000002U),
58 HAL_SD_STATE_BUSY = ((uint32_t)0x00000003U),
59 HAL_SD_STATE_PROGRAMMING = ((uint32_t)0x00000004U),
60 HAL_SD_STATE_RECEIVING = ((uint32_t)0x00000005U),
61 HAL_SD_STATE_TRANSFER = ((uint32_t)0x00000006U),
62 HAL_SD_STATE_ERROR = ((uint32_t)0x0000000FU)
72typedef uint32_t HAL_SD_CardStateTypeDef;
73
74#define HAL_SD_CARD_READY 0x00000001U
75#define HAL_SD_CARD_IDENTIFICATION 0x00000002U
76#define HAL_SD_CARD_STANDBY 0x00000003U
77#define HAL_SD_CARD_TRANSFER 0x00000004U
78#define HAL_SD_CARD_SENDING 0x00000005U
79#define HAL_SD_CARD_RECEIVING 0x00000006U
80#define HAL_SD_CARD_PROGRAMMING 0x00000007U
81#define HAL_SD_CARD_DISCONNECTED 0x00000008U
82#define HAL_SD_CARD_ERROR 0x000000FFU
91#define SD_InitTypeDef SDMMC_InitTypeDef
92#define SD_TypeDef SDMMC_TypeDef
93
97typedef struct
98{
99 uint32_t CardType;
101 uint32_t CardVersion;
103 uint32_t Class;
105 uint32_t RelCardAdd;
107 uint32_t BlockNbr;
109 uint32_t BlockSize;
111 uint32_t LogBlockNbr;
113 uint32_t LogBlockSize;
115 uint32_t CardSpeed;
118
122#if defined (USE_HAL_SD_REGISTER_CALLBACKS) && (USE_HAL_SD_REGISTER_CALLBACKS == 1U)
123typedef struct __SD_HandleTypeDef
124#else
125typedef struct
126#endif /* USE_HAL_SD_REGISTER_CALLBACKS */
127{
128 SD_TypeDef *Instance;
130 SD_InitTypeDef Init;
134 const uint8_t *pTxBuffPtr;
136 uint32_t TxXferSize;
138 uint8_t *pRxBuffPtr;
140 uint32_t RxXferSize;
142 __IO uint32_t Context;
146 __IO uint32_t ErrorCode;
150 uint32_t CSD[4];
152 uint32_t CID[4];
154#if defined (USE_HAL_SD_REGISTER_CALLBACKS) && (USE_HAL_SD_REGISTER_CALLBACKS == 1U)
155 void (* TxCpltCallback)(struct __SD_HandleTypeDef *hsd);
156 void (* RxCpltCallback)(struct __SD_HandleTypeDef *hsd);
157 void (* ErrorCallback)(struct __SD_HandleTypeDef *hsd);
158 void (* AbortCpltCallback)(struct __SD_HandleTypeDef *hsd);
159 void (* Read_DMADblBuf0CpltCallback)(struct __SD_HandleTypeDef *hsd);
160 void (* Read_DMADblBuf1CpltCallback)(struct __SD_HandleTypeDef *hsd);
161 void (* Write_DMADblBuf0CpltCallback)(struct __SD_HandleTypeDef *hsd);
162 void (* Write_DMADblBuf1CpltCallback)(struct __SD_HandleTypeDef *hsd);
163#if (USE_SD_TRANSCEIVER != 0U)
164 void (* DriveTransceiver_1_8V_Callback)(FlagStatus status);
165#endif /* USE_SD_TRANSCEIVER */
166
167 void (* MspInitCallback)(struct __SD_HandleTypeDef *hsd);
168 void (* MspDeInitCallback)(struct __SD_HandleTypeDef *hsd);
169#endif /* USE_HAL_SD_REGISTER_CALLBACKS */
171
180typedef struct
181{
182 __IO uint8_t CSDStruct;
184 __IO uint8_t Reserved1;
185 __IO uint8_t TAAC;
186 __IO uint8_t NSAC;
189 __IO uint8_t RdBlockLen;
193 __IO uint8_t DSRImpl;
194 __IO uint8_t Reserved2;
195 __IO uint32_t DeviceSize;
202 __IO uint8_t EraseGrMul;
205 __IO uint8_t ManDeflECC;
209 __IO uint8_t Reserved3;
212 __IO uint8_t CopyFlag;
215 __IO uint8_t FileFormat;
216 __IO uint8_t ECC;
217 __IO uint8_t CSD_CRC;
218 __IO uint8_t Reserved4;
228typedef struct
229{
231 __IO uint16_t OEM_AppliID;
232 __IO uint32_t ProdName1;
233 __IO uint8_t ProdName2;
234 __IO uint8_t ProdRev;
235 __IO uint32_t ProdSN;
236 __IO uint8_t Reserved1;
238 __IO uint8_t CID_CRC;
239 __IO uint8_t Reserved2;
250typedef struct
251{
254 __IO uint16_t CardType;
256 __IO uint8_t SpeedClass;
259 __IO uint16_t EraseSize;
270#if defined (USE_HAL_SD_REGISTER_CALLBACKS) && (USE_HAL_SD_REGISTER_CALLBACKS == 1U)
275typedef enum
276{
277 HAL_SD_TX_CPLT_CB_ID = 0x00U,
278 HAL_SD_RX_CPLT_CB_ID = 0x01U,
279 HAL_SD_ERROR_CB_ID = 0x02U,
280 HAL_SD_ABORT_CB_ID = 0x03U,
281 HAL_SD_READ_DMA_DBL_BUF0_CPLT_CB_ID = 0x04U,
282 HAL_SD_READ_DMA_DBL_BUF1_CPLT_CB_ID = 0x05U,
283 HAL_SD_WRITE_DMA_DBL_BUF0_CPLT_CB_ID = 0x06U,
284 HAL_SD_WRITE_DMA_DBL_BUF1_CPLT_CB_ID = 0x07U,
286 HAL_SD_MSP_INIT_CB_ID = 0x10U,
287 HAL_SD_MSP_DEINIT_CB_ID = 0x11U
288} HAL_SD_CallbackIDTypeDef;
297typedef void (*pSD_CallbackTypeDef)(SD_HandleTypeDef *hsd);
298#if (USE_SD_TRANSCEIVER != 0U)
299typedef void (*pSD_TransceiverCallbackTypeDef)(FlagStatus status);
300#endif /* USE_SD_TRANSCEIVER */
304#endif /* USE_HAL_SD_REGISTER_CALLBACKS */
309/* Exported constants --------------------------------------------------------*/
315#define BLOCKSIZE ((uint32_t)512U)
321#define HAL_SD_ERROR_NONE SDMMC_ERROR_NONE
322#define HAL_SD_ERROR_CMD_CRC_FAIL SDMMC_ERROR_CMD_CRC_FAIL
323#define HAL_SD_ERROR_DATA_CRC_FAIL SDMMC_ERROR_DATA_CRC_FAIL
324#define HAL_SD_ERROR_CMD_RSP_TIMEOUT SDMMC_ERROR_CMD_RSP_TIMEOUT
325#define HAL_SD_ERROR_DATA_TIMEOUT SDMMC_ERROR_DATA_TIMEOUT
326#define HAL_SD_ERROR_TX_UNDERRUN SDMMC_ERROR_TX_UNDERRUN
327#define HAL_SD_ERROR_RX_OVERRUN SDMMC_ERROR_RX_OVERRUN
328#define HAL_SD_ERROR_ADDR_MISALIGNED SDMMC_ERROR_ADDR_MISALIGNED
329#define HAL_SD_ERROR_BLOCK_LEN_ERR SDMMC_ERROR_BLOCK_LEN_ERR
331#define HAL_SD_ERROR_ERASE_SEQ_ERR SDMMC_ERROR_ERASE_SEQ_ERR
332#define HAL_SD_ERROR_BAD_ERASE_PARAM SDMMC_ERROR_BAD_ERASE_PARAM
333#define HAL_SD_ERROR_WRITE_PROT_VIOLATION SDMMC_ERROR_WRITE_PROT_VIOLATION
334#define HAL_SD_ERROR_LOCK_UNLOCK_FAILED SDMMC_ERROR_LOCK_UNLOCK_FAILED
336#define HAL_SD_ERROR_COM_CRC_FAILED SDMMC_ERROR_COM_CRC_FAILED
337#define HAL_SD_ERROR_ILLEGAL_CMD SDMMC_ERROR_ILLEGAL_CMD
338#define HAL_SD_ERROR_CARD_ECC_FAILED SDMMC_ERROR_CARD_ECC_FAILED
339#define HAL_SD_ERROR_CC_ERR SDMMC_ERROR_CC_ERR
340#define HAL_SD_ERROR_GENERAL_UNKNOWN_ERR SDMMC_ERROR_GENERAL_UNKNOWN_ERR
341#define HAL_SD_ERROR_STREAM_READ_UNDERRUN SDMMC_ERROR_STREAM_READ_UNDERRUN
342#define HAL_SD_ERROR_STREAM_WRITE_OVERRUN SDMMC_ERROR_STREAM_WRITE_OVERRUN
343#define HAL_SD_ERROR_CID_CSD_OVERWRITE SDMMC_ERROR_CID_CSD_OVERWRITE
344#define HAL_SD_ERROR_WP_ERASE_SKIP SDMMC_ERROR_WP_ERASE_SKIP
345#define HAL_SD_ERROR_CARD_ECC_DISABLED SDMMC_ERROR_CARD_ECC_DISABLED
346#define HAL_SD_ERROR_ERASE_RESET SDMMC_ERROR_ERASE_RESET
348#define HAL_SD_ERROR_AKE_SEQ_ERR SDMMC_ERROR_AKE_SEQ_ERR
349#define HAL_SD_ERROR_INVALID_VOLTRANGE SDMMC_ERROR_INVALID_VOLTRANGE
350#define HAL_SD_ERROR_ADDR_OUT_OF_RANGE SDMMC_ERROR_ADDR_OUT_OF_RANGE
351#define HAL_SD_ERROR_REQUEST_NOT_APPLICABLE SDMMC_ERROR_REQUEST_NOT_APPLICABLE
352#define HAL_SD_ERROR_PARAM SDMMC_ERROR_INVALID_PARAMETER
353#define HAL_SD_ERROR_UNSUPPORTED_FEATURE SDMMC_ERROR_UNSUPPORTED_FEATURE
354#define HAL_SD_ERROR_BUSY SDMMC_ERROR_BUSY
355#define HAL_SD_ERROR_DMA SDMMC_ERROR_DMA
356#define HAL_SD_ERROR_TIMEOUT SDMMC_ERROR_TIMEOUT
358#if defined (USE_HAL_SD_REGISTER_CALLBACKS) && (USE_HAL_SD_REGISTER_CALLBACKS == 1U)
359#define HAL_SD_ERROR_INVALID_CALLBACK SDMMC_ERROR_INVALID_PARAMETER
360#endif /* USE_HAL_SD_REGISTER_CALLBACKS */
369#define SD_CONTEXT_NONE ((uint32_t)0x00000000U)
370#define SD_CONTEXT_READ_SINGLE_BLOCK ((uint32_t)0x00000001U)
371#define SD_CONTEXT_READ_MULTIPLE_BLOCK ((uint32_t)0x00000002U)
372#define SD_CONTEXT_WRITE_SINGLE_BLOCK ((uint32_t)0x00000010U)
373#define SD_CONTEXT_WRITE_MULTIPLE_BLOCK ((uint32_t)0x00000020U)
374#define SD_CONTEXT_IT ((uint32_t)0x00000008U)
375#define SD_CONTEXT_DMA ((uint32_t)0x00000080U)
385#define CARD_NORMAL_SPEED ((uint32_t)0x00000000U)
386#define CARD_HIGH_SPEED ((uint32_t)0x00000100U)
387#define CARD_ULTRA_HIGH_SPEED ((uint32_t)0x00000200U)
390#define CARD_SDSC ((uint32_t)0x00000000U)
391#define CARD_SDHC_SDXC ((uint32_t)0x00000001U)
392#define CARD_SECURED ((uint32_t)0x00000003U)
393
402#define CARD_V1_X ((uint32_t)0x00000000U)
403#define CARD_V2_X ((uint32_t)0x00000001U)
412/* Exported macro ------------------------------------------------------------*/
422#if defined (USE_HAL_SD_REGISTER_CALLBACKS) && (USE_HAL_SD_REGISTER_CALLBACKS == 1U)
423#define __HAL_SD_RESET_HANDLE_STATE(__HANDLE__) do { \
424 (__HANDLE__)->State = HAL_SD_STATE_RESET; \
425 (__HANDLE__)->MspInitCallback = NULL; \
426 (__HANDLE__)->MspDeInitCallback = NULL; \
427 } while(0)
428#else
429#define __HAL_SD_RESET_HANDLE_STATE(__HANDLE__) ((__HANDLE__)->State = HAL_SD_STATE_RESET)
430#endif /* USE_HAL_SD_REGISTER_CALLBACKS */
431
462#define __HAL_SD_ENABLE_IT(__HANDLE__, __INTERRUPT__) __SDMMC_ENABLE_IT((__HANDLE__)->Instance, (__INTERRUPT__))
463
494#define __HAL_SD_DISABLE_IT(__HANDLE__, __INTERRUPT__) __SDMMC_DISABLE_IT((__HANDLE__)->Instance, (__INTERRUPT__))
495
532#define __HAL_SD_GET_FLAG(__HANDLE__, __FLAG__) __SDMMC_GET_FLAG((__HANDLE__)->Instance, (__FLAG__))
533
561#define __HAL_SD_CLEAR_FLAG(__HANDLE__, __FLAG__) __SDMMC_CLEAR_FLAG((__HANDLE__)->Instance, (__FLAG__))
562
593#define __HAL_SD_GET_IT(__HANDLE__, __INTERRUPT__) __SDMMC_GET_IT((__HANDLE__)->Instance, (__INTERRUPT__))
594
621#define __HAL_SD_CLEAR_IT(__HANDLE__, __INTERRUPT__) __SDMMC_CLEAR_IT((__HANDLE__)->Instance, (__INTERRUPT__))
622
627/* Include SD HAL Extension module */
628#include "stm32h7xx_hal_sd_ex.h"
629
630/* Exported functions --------------------------------------------------------*/
640HAL_StatusTypeDef HAL_SD_Init(SD_HandleTypeDef *hsd);
641HAL_StatusTypeDef HAL_SD_InitCard(SD_HandleTypeDef *hsd);
642HAL_StatusTypeDef HAL_SD_DeInit(SD_HandleTypeDef *hsd);
643void HAL_SD_MspInit(SD_HandleTypeDef *hsd);
644void HAL_SD_MspDeInit(SD_HandleTypeDef *hsd);
653/* Blocking mode: Polling */
654HAL_StatusTypeDef HAL_SD_ReadBlocks(SD_HandleTypeDef *hsd, uint8_t *pData, uint32_t BlockAdd, uint32_t NumberOfBlocks,
655 uint32_t Timeout);
656HAL_StatusTypeDef HAL_SD_WriteBlocks(SD_HandleTypeDef *hsd, const uint8_t *pData, uint32_t BlockAdd,
657 uint32_t NumberOfBlocks, uint32_t Timeout);
658HAL_StatusTypeDef HAL_SD_Erase(SD_HandleTypeDef *hsd, uint32_t BlockStartAdd, uint32_t BlockEndAdd);
659/* Non-Blocking mode: IT */
660HAL_StatusTypeDef HAL_SD_ReadBlocks_IT(SD_HandleTypeDef *hsd, uint8_t *pData, uint32_t BlockAdd,
661 uint32_t NumberOfBlocks);
662HAL_StatusTypeDef HAL_SD_WriteBlocks_IT(SD_HandleTypeDef *hsd, const uint8_t *pData, uint32_t BlockAdd,
663 uint32_t NumberOfBlocks);
664/* Non-Blocking mode: DMA */
665HAL_StatusTypeDef HAL_SD_ReadBlocks_DMA(SD_HandleTypeDef *hsd, uint8_t *pData, uint32_t BlockAdd,
666 uint32_t NumberOfBlocks);
667HAL_StatusTypeDef HAL_SD_WriteBlocks_DMA(SD_HandleTypeDef *hsd, const uint8_t *pData, uint32_t BlockAdd,
668 uint32_t NumberOfBlocks);
669
670void HAL_SD_IRQHandler(SD_HandleTypeDef *hsd);
671
672/* Callback in non blocking modes (DMA) */
673void HAL_SD_TxCpltCallback(SD_HandleTypeDef *hsd);
674void HAL_SD_RxCpltCallback(SD_HandleTypeDef *hsd);
675void HAL_SD_ErrorCallback(SD_HandleTypeDef *hsd);
676void HAL_SD_AbortCallback(SD_HandleTypeDef *hsd);
677
678#if (USE_SD_TRANSCEIVER != 0U)
679/* Callback to switch in 1.8V mode */
680void HAL_SD_DriveTransceiver_1_8V_Callback(FlagStatus status);
681#endif /* USE_SD_TRANSCEIVER */
682
683#if defined (USE_HAL_SD_REGISTER_CALLBACKS) && (USE_HAL_SD_REGISTER_CALLBACKS == 1U)
684/* SD callback registering/unregistering */
685HAL_StatusTypeDef HAL_SD_RegisterCallback(SD_HandleTypeDef *hsd, HAL_SD_CallbackIDTypeDef CallbackID,
686 pSD_CallbackTypeDef pCallback);
687HAL_StatusTypeDef HAL_SD_UnRegisterCallback(SD_HandleTypeDef *hsd, HAL_SD_CallbackIDTypeDef CallbackID);
688
689#if (USE_SD_TRANSCEIVER != 0U)
690HAL_StatusTypeDef HAL_SD_RegisterTransceiverCallback(SD_HandleTypeDef *hsd, pSD_TransceiverCallbackTypeDef pCallback);
691HAL_StatusTypeDef HAL_SD_UnRegisterTransceiverCallback(SD_HandleTypeDef *hsd);
692#endif /* USE_SD_TRANSCEIVER */
693#endif /* USE_HAL_SD_REGISTER_CALLBACKS */
694
703HAL_StatusTypeDef HAL_SD_ConfigWideBusOperation(SD_HandleTypeDef *hsd, uint32_t WideMode);
704HAL_StatusTypeDef HAL_SD_ConfigSpeedBusOperation(SD_HandleTypeDef *hsd, uint32_t SpeedMode);
713HAL_SD_CardStateTypeDef HAL_SD_GetCardState(SD_HandleTypeDef *hsd);
714HAL_StatusTypeDef HAL_SD_GetCardCID(SD_HandleTypeDef *hsd, HAL_SD_CardCIDTypeDef *pCID);
715HAL_StatusTypeDef HAL_SD_GetCardCSD(SD_HandleTypeDef *hsd, HAL_SD_CardCSDTypeDef *pCSD);
716HAL_StatusTypeDef HAL_SD_GetCardStatus(SD_HandleTypeDef *hsd, HAL_SD_CardStatusTypeDef *pStatus);
717HAL_StatusTypeDef HAL_SD_GetCardInfo(SD_HandleTypeDef *hsd, HAL_SD_CardInfoTypeDef *pCardInfo);
726HAL_SD_StateTypeDef HAL_SD_GetState(SD_HandleTypeDef *hsd);
727uint32_t HAL_SD_GetError(SD_HandleTypeDef *hsd);
736HAL_StatusTypeDef HAL_SD_Abort(SD_HandleTypeDef *hsd);
737HAL_StatusTypeDef HAL_SD_Abort_IT(SD_HandleTypeDef *hsd);
742/* Private types -------------------------------------------------------------*/
752/* Private defines -----------------------------------------------------------*/
762/* Private variables ---------------------------------------------------------*/
772/* Private constants ---------------------------------------------------------*/
782/* Private macros ------------------------------------------------------------*/
792/* Private functions prototypes ----------------------------------------------*/
802/* Private functions ---------------------------------------------------------*/
825#ifdef __cplusplus
826}
827#endif
828
829
830#endif /* STM32H7xx_HAL_SD_H */
#define __IO
Definition: core_cm4.h:239
HAL_SD_StateTypeDef
Definition: stm32h7xx_hal_sd.h:54
@ HAL_SD_STATE_ERROR
Definition: stm32h7xx_hal_sd.h:62
@ HAL_SD_STATE_RECEIVING
Definition: stm32h7xx_hal_sd.h:60
@ HAL_SD_STATE_PROGRAMMING
Definition: stm32h7xx_hal_sd.h:59
@ HAL_SD_STATE_READY
Definition: stm32h7xx_hal_sd.h:56
@ HAL_SD_STATE_TIMEOUT
Definition: stm32h7xx_hal_sd.h:57
@ HAL_SD_STATE_TRANSFER
Definition: stm32h7xx_hal_sd.h:61
@ HAL_SD_STATE_RESET
Definition: stm32h7xx_hal_sd.h:55
@ HAL_SD_STATE_BUSY
Definition: stm32h7xx_hal_sd.h:58
HAL_StatusTypeDef
HAL Status structures definition.
Definition: stm32h7xx_hal_def.h:47
HAL_LockTypeDef
HAL Lock structures definition.
Definition: stm32h7xx_hal_def.h:58
Header file of SD HAL extended module.
Header file of Delay Block module.
Header file of SDMMC HAL module.
Definition: stm32h7xx_hal_sd.h:229
Definition: stm32h7xx_hal_sd.h:236
Definition: stm32h7xx_hal_sd.h:231
__IO uint8_t ManufacturerID
Definition: stm32h7xx_hal_sd.h:230
Definition: stm32h7xx_hal_sd.h:234
Definition: stm32h7xx_hal_sd.h:238
Definition: stm32h7xx_hal_sd.h:239
Definition: stm32h7xx_hal_sd.h:232
__IO uint16_t ManufactDate
Definition: stm32h7xx_hal_sd.h:237
Definition: stm32h7xx_hal_sd.h:235
Definition: stm32h7xx_hal_sd.h:233
Definition: stm32h7xx_hal_sd.h:181
__IO uint8_t WriteBlockPaPartial
Definition: stm32h7xx_hal_sd.h:208
Definition: stm32h7xx_hal_sd.h:193
__IO uint8_t MaxRdCurrentVDDMax
Definition: stm32h7xx_hal_sd.h:197
Definition: stm32h7xx_hal_sd.h:182
__IO uint8_t PartBlockRead
Definition: stm32h7xx_hal_sd.h:190
Definition: stm32h7xx_hal_sd.h:184
__IO uint8_t WrBlockMisalign
Definition: stm32h7xx_hal_sd.h:191
__IO uint8_t WrProtectGrSize
Definition: stm32h7xx_hal_sd.h:203
__IO uint8_t MaxWrBlockLen
Definition: stm32h7xx_hal_sd.h:207
Definition: stm32h7xx_hal_sd.h:194
__IO uint8_t WrProtectGrEnable
Definition: stm32h7xx_hal_sd.h:204
__IO uint8_t ContentProtectAppli
Definition: stm32h7xx_hal_sd.h:210
Definition: stm32h7xx_hal_sd.h:195
__IO uint8_t MaxWrCurrentVDDMax
Definition: stm32h7xx_hal_sd.h:199
__IO uint8_t MaxWrCurrentVDDMin
Definition: stm32h7xx_hal_sd.h:198
__IO uint8_t TempWrProtect
Definition: stm32h7xx_hal_sd.h:214
Definition: stm32h7xx_hal_sd.h:202
__IO uint16_t CardComdClasses
Definition: stm32h7xx_hal_sd.h:188
Definition: stm32h7xx_hal_sd.h:212
__IO uint8_t WrSpeedFact
Definition: stm32h7xx_hal_sd.h:206
__IO uint8_t ECC
Definition: stm32h7xx_hal_sd.h:216
__IO uint8_t RdBlockMisalign
Definition: stm32h7xx_hal_sd.h:192
Definition: stm32h7xx_hal_sd.h:215
__IO uint8_t MaxRdCurrentVDDMin
Definition: stm32h7xx_hal_sd.h:196
Definition: stm32h7xx_hal_sd.h:205
Definition: stm32h7xx_hal_sd.h:217
__IO uint8_t SysSpecVersion
Definition: stm32h7xx_hal_sd.h:183
__IO uint8_t EraseGrSize
Definition: stm32h7xx_hal_sd.h:201
Definition: stm32h7xx_hal_sd.h:218
__IO uint8_t NSAC
Definition: stm32h7xx_hal_sd.h:186
__IO uint8_t MaxBusClkFrec
Definition: stm32h7xx_hal_sd.h:187
__IO uint8_t PermWrProtect
Definition: stm32h7xx_hal_sd.h:213
__IO uint8_t FileFormatGroup
Definition: stm32h7xx_hal_sd.h:211
Definition: stm32h7xx_hal_sd.h:189
__IO uint8_t TAAC
Definition: stm32h7xx_hal_sd.h:185
Definition: stm32h7xx_hal_sd.h:209
__IO uint8_t DeviceSizeMul
Definition: stm32h7xx_hal_sd.h:200
SD Card Information Structure definition.
Definition: stm32h7xx_hal_sd.h:98
uint32_t BlockNbr
Definition: stm32h7xx_hal_sd.h:107
Definition: stm32h7xx_hal_sd.h:111
uint32_t CardSpeed
Definition: stm32h7xx_hal_sd.h:115
Definition: stm32h7xx_hal_sd.h:101
Definition: stm32h7xx_hal_sd.h:113
uint32_t BlockSize
Definition: stm32h7xx_hal_sd.h:109
uint32_t CardType
Definition: stm32h7xx_hal_sd.h:99
uint32_t Class
Definition: stm32h7xx_hal_sd.h:103
uint32_t RelCardAdd
Definition: stm32h7xx_hal_sd.h:105
Definition: stm32h7xx_hal_sd.h:251
Definition: stm32h7xx_hal_sd.h:256
Definition: stm32h7xx_hal_sd.h:254
__IO uint8_t PerformanceMove
Definition: stm32h7xx_hal_sd.h:257
__IO uint8_t UhsAllocationUnitSize
Definition: stm32h7xx_hal_sd.h:263
__IO uint8_t VideoSpeedClass
Definition: stm32h7xx_hal_sd.h:264
__IO uint8_t EraseTimeout
Definition: stm32h7xx_hal_sd.h:260
__IO uint8_t UhsSpeedGrade
Definition: stm32h7xx_hal_sd.h:262
__IO uint8_t DataBusWidth
Definition: stm32h7xx_hal_sd.h:252
__IO uint8_t EraseOffset
Definition: stm32h7xx_hal_sd.h:261
__IO uint8_t SecuredMode
Definition: stm32h7xx_hal_sd.h:253
__IO uint32_t ProtectedAreaSize
Definition: stm32h7xx_hal_sd.h:255
Definition: stm32h7xx_hal_sd.h:259
__IO uint8_t AllocationUnitSize
Definition: stm32h7xx_hal_sd.h:258
SD handle Structure definition.
Definition: stm32h7xx_hal_sd.h:127
SD_TypeDef * Instance
Definition: stm32h7xx_hal_sd.h:128
SD_InitTypeDef Init
Definition: stm32h7xx_hal_sd.h:130
uint8_t * pRxBuffPtr
Definition: stm32h7xx_hal_sd.h:138
uint32_t TxXferSize
Definition: stm32h7xx_hal_sd.h:136
HAL_SD_CardInfoTypeDef SdCard
Definition: stm32h7xx_hal_sd.h:148
uint32_t RxXferSize
Definition: stm32h7xx_hal_sd.h:140
__IO HAL_SD_StateTypeDef State
Definition: stm32h7xx_hal_sd.h:144
Definition: stm32h7xx_hal_sd.h:142
Definition: stm32h7xx_hal_sd.h:146
const uint8_t * pTxBuffPtr
Definition: stm32h7xx_hal_sd.h:134
HAL_LockTypeDef Lock
Definition: stm32h7xx_hal_sd.h:132
