RTEMS 6.1
__IO uint8_t ManufacturerID
__IO uint16_t OEM_AppliID
__IO uint32_t ProdName1
__IO uint8_t ProdName2
__IO uint8_t ProdRev
__IO uint32_t ProdSN
__IO uint8_t Reserved1
__IO uint16_t ManufactDate
__IO uint8_t CID_CRC
__IO uint8_t Reserved2
Field Documentation
◆ CID_CRC
__IO uint8_t HAL_SD_CardCIDTypeDef::CID_CRC
CID CRC
◆ ManufactDate
__IO uint16_t HAL_SD_CardCIDTypeDef::ManufactDate
Manufacturing Date
◆ ManufacturerID
__IO uint8_t HAL_SD_CardCIDTypeDef::ManufacturerID
Manufacturer ID
◆ OEM_AppliID
__IO uint16_t HAL_SD_CardCIDTypeDef::OEM_AppliID
OEM/Application ID
◆ ProdName1
__IO uint32_t HAL_SD_CardCIDTypeDef::ProdName1
Product Name part1
◆ ProdName2
__IO uint8_t HAL_SD_CardCIDTypeDef::ProdName2
Product Name part2
◆ ProdRev
__IO uint8_t HAL_SD_CardCIDTypeDef::ProdRev
Product Revision
◆ ProdSN
__IO uint32_t HAL_SD_CardCIDTypeDef::ProdSN
Product Serial Number
◆ Reserved1
__IO uint8_t HAL_SD_CardCIDTypeDef::Reserved1
Reserved1
◆ Reserved2
__IO uint8_t HAL_SD_CardCIDTypeDef::Reserved2
Always 1
