◆ AllocationUnitSize
| __IO uint8_t HAL_SD_CardStatusTypeDef::AllocationUnitSize |
Carries information about the card's allocation unit size
◆ CardType
| __IO uint16_t HAL_SD_CardStatusTypeDef::CardType |
Carries information about card type
◆ DataBusWidth
| __IO uint8_t HAL_SD_CardStatusTypeDef::DataBusWidth |
Shows the currently defined data bus width
◆ EraseOffset
| __IO uint8_t HAL_SD_CardStatusTypeDef::EraseOffset |
Carries information about the erase offset
◆ EraseSize
| __IO uint16_t HAL_SD_CardStatusTypeDef::EraseSize |
Determines the number of AUs to be erased in one operation
◆ EraseTimeout
| __IO uint8_t HAL_SD_CardStatusTypeDef::EraseTimeout |
Determines the timeout for any number of AU erase
◆ PerformanceMove
| __IO uint8_t HAL_SD_CardStatusTypeDef::PerformanceMove |
Carries information about the card's performance move
◆ ProtectedAreaSize
| __IO uint32_t HAL_SD_CardStatusTypeDef::ProtectedAreaSize |
Carries information about the capacity of protected area
◆ SecuredMode
| __IO uint8_t HAL_SD_CardStatusTypeDef::SecuredMode |
Card is in secured mode of operation
◆ SpeedClass
| __IO uint8_t HAL_SD_CardStatusTypeDef::SpeedClass |
Carries information about the speed class of the card
◆ UhsAllocationUnitSize
| __IO uint8_t HAL_SD_CardStatusTypeDef::UhsAllocationUnitSize |
Carries information about the UHS card's allocation unit size
◆ UhsSpeedGrade
| __IO uint8_t HAL_SD_CardStatusTypeDef::UhsSpeedGrade |
Carries information about the speed grade of UHS card
◆ VideoSpeedClass
| __IO uint8_t HAL_SD_CardStatusTypeDef::VideoSpeedClass |
Carries information about the Video Speed Class of UHS card
