RTEMS 6.1
stm32h7xx_ll_sdmmc.h File Reference
Header file of SDMMC HAL module. More...
#include "stm32h7xx_hal_def.h"
struct  SDMMC_InitTypeDef
 SDMMC Configuration Structure definition. More...
struct  SDMMC_CmdInitTypeDef
 SDMMC Command Control structure. More...
struct  SDMMC_DataInitTypeDef
 SDMMC Data Control structure. More...
#define SDMMC_ERROR_NONE   ((uint32_t)0x00000000U)
#define SDMMC_ERROR_CMD_CRC_FAIL   ((uint32_t)0x00000001U)
#define SDMMC_ERROR_DATA_CRC_FAIL   ((uint32_t)0x00000002U)
#define SDMMC_ERROR_CMD_RSP_TIMEOUT   ((uint32_t)0x00000004U)
#define SDMMC_ERROR_DATA_TIMEOUT   ((uint32_t)0x00000008U)
#define SDMMC_ERROR_TX_UNDERRUN   ((uint32_t)0x00000010U)
#define SDMMC_ERROR_RX_OVERRUN   ((uint32_t)0x00000020U)
#define SDMMC_ERROR_ADDR_MISALIGNED   ((uint32_t)0x00000040U)
#define SDMMC_ERROR_BLOCK_LEN_ERR   ((uint32_t)0x00000080U)
#define SDMMC_ERROR_ERASE_SEQ_ERR   ((uint32_t)0x00000100U)
#define SDMMC_ERROR_BAD_ERASE_PARAM   ((uint32_t)0x00000200U)
#define SDMMC_ERROR_WRITE_PROT_VIOLATION   ((uint32_t)0x00000400U)
#define SDMMC_ERROR_LOCK_UNLOCK_FAILED   ((uint32_t)0x00000800U)
#define SDMMC_ERROR_COM_CRC_FAILED   ((uint32_t)0x00001000U)
#define SDMMC_ERROR_ILLEGAL_CMD   ((uint32_t)0x00002000U)
#define SDMMC_ERROR_CARD_ECC_FAILED   ((uint32_t)0x00004000U)
#define SDMMC_ERROR_CC_ERR   ((uint32_t)0x00008000U)
#define SDMMC_ERROR_GENERAL_UNKNOWN_ERR   ((uint32_t)0x00010000U)
#define SDMMC_ERROR_STREAM_READ_UNDERRUN   ((uint32_t)0x00020000U)
#define SDMMC_ERROR_STREAM_WRITE_OVERRUN   ((uint32_t)0x00040000U)
#define SDMMC_ERROR_CID_CSD_OVERWRITE   ((uint32_t)0x00080000U)
#define SDMMC_ERROR_WP_ERASE_SKIP   ((uint32_t)0x00100000U)
#define SDMMC_ERROR_CARD_ECC_DISABLED   ((uint32_t)0x00200000U)
#define SDMMC_ERROR_ERASE_RESET   ((uint32_t)0x00400000U)
#define SDMMC_ERROR_AKE_SEQ_ERR   ((uint32_t)0x00800000U)
#define SDMMC_ERROR_INVALID_VOLTRANGE   ((uint32_t)0x01000000U)
#define SDMMC_ERROR_ADDR_OUT_OF_RANGE   ((uint32_t)0x02000000U)
#define SDMMC_ERROR_REQUEST_NOT_APPLICABLE   ((uint32_t)0x04000000U)
#define SDMMC_ERROR_INVALID_PARAMETER   ((uint32_t)0x08000000U)
#define SDMMC_ERROR_UNSUPPORTED_FEATURE   ((uint32_t)0x10000000U)
#define SDMMC_ERROR_BUSY   ((uint32_t)0x20000000U)
#define SDMMC_ERROR_DMA   ((uint32_t)0x40000000U)
#define SDMMC_ERROR_TIMEOUT   ((uint32_t)0x80000000U)
#define SDMMC_CMD_GO_IDLE_STATE   ((uint8_t)0U)
 SDMMC Commands Index.
#define SDMMC_CMD_SEND_OP_COND   ((uint8_t)1U)
#define SDMMC_CMD_ALL_SEND_CID   ((uint8_t)2U)
#define SDMMC_CMD_SET_REL_ADDR   ((uint8_t)3U)
#define SDMMC_CMD_SET_DSR   ((uint8_t)4U)
#define SDMMC_CMD_SDMMC_SEN_OP_COND   ((uint8_t)5U)
#define SDMMC_CMD_HS_SWITCH   ((uint8_t)6U)
#define SDMMC_CMD_SEL_DESEL_CARD   ((uint8_t)7U)
#define SDMMC_CMD_HS_SEND_EXT_CSD   ((uint8_t)8U)
#define SDMMC_CMD_SEND_CSD   ((uint8_t)9U)
#define SDMMC_CMD_SEND_CID   ((uint8_t)10U)
#define SDMMC_CMD_VOLTAGE_SWITCH   ((uint8_t)11U)
#define SDMMC_CMD_STOP_TRANSMISSION   ((uint8_t)12U)
#define SDMMC_CMD_SEND_STATUS   ((uint8_t)13U)
#define SDMMC_CMD_HS_BUSTEST_READ   ((uint8_t)14U)
#define SDMMC_CMD_GO_INACTIVE_STATE   ((uint8_t)15U)
#define SDMMC_CMD_SET_BLOCKLEN   ((uint8_t)16U)
#define SDMMC_CMD_READ_SINGLE_BLOCK   ((uint8_t)17U)
#define SDMMC_CMD_READ_MULT_BLOCK   ((uint8_t)18U)
#define SDMMC_CMD_HS_BUSTEST_WRITE   ((uint8_t)19U)
#define SDMMC_CMD_WRITE_DAT_UNTIL_STOP   ((uint8_t)20U)
#define SDMMC_CMD_SET_BLOCK_COUNT   ((uint8_t)23U)
#define SDMMC_CMD_WRITE_SINGLE_BLOCK   ((uint8_t)24U)
#define SDMMC_CMD_WRITE_MULT_BLOCK   ((uint8_t)25U)
#define SDMMC_CMD_PROG_CID   ((uint8_t)26U)
#define SDMMC_CMD_PROG_CSD   ((uint8_t)27U)
#define SDMMC_CMD_SET_WRITE_PROT   ((uint8_t)28U)
#define SDMMC_CMD_CLR_WRITE_PROT   ((uint8_t)29U)
#define SDMMC_CMD_SEND_WRITE_PROT   ((uint8_t)30U)
#define SDMMC_CMD_SD_ERASE_GRP_START   ((uint8_t)32U)
#define SDMMC_CMD_SD_ERASE_GRP_END   ((uint8_t)33U)
#define SDMMC_CMD_ERASE_GRP_START   ((uint8_t)35U)
#define SDMMC_CMD_ERASE_GRP_END   ((uint8_t)36U)
#define SDMMC_CMD_ERASE   ((uint8_t)38U)
#define SDMMC_CMD_FAST_IO   ((uint8_t)39U)
#define SDMMC_CMD_GO_IRQ_STATE   ((uint8_t)40U)
#define SDMMC_CMD_LOCK_UNLOCK   ((uint8_t)42U)
#define SDMMC_CMD_APP_CMD   ((uint8_t)55U)
#define SDMMC_CMD_GEN_CMD   ((uint8_t)56U)
#define SDMMC_CMD_NO_CMD   ((uint8_t)64U)
#define SDMMC_CMD_APP_SD_SET_BUSWIDTH   ((uint8_t)6U)
 Following commands are SD Card Specific commands. SDMMC_APP_CMD should be sent before sending these commands.
#define SDMMC_CMD_SD_APP_STATUS   ((uint8_t)13U)
#define SDMMC_CMD_SD_APP_SEND_NUM_WRITE_BLOCKS   ((uint8_t)22U)
#define SDMMC_CMD_SD_APP_OP_COND   ((uint8_t)41U)
#define SDMMC_CMD_SD_APP_SET_CLR_CARD_DETECT   ((uint8_t)42U)
#define SDMMC_CMD_SD_APP_SEND_SCR   ((uint8_t)51U)
#define SDMMC_CMD_SDMMC_RW_DIRECT   ((uint8_t)52U)
#define SDMMC_CMD_SDMMC_RW_EXTENDED   ((uint8_t)53U)
#define SDMMC_CMD_MMC_SLEEP_AWAKE   ((uint8_t)5U)
 Following commands are MMC Specific commands.
#define SDMMC_CMD_SD_APP_GET_MKB   ((uint8_t)43U)
 Following commands are SD Card Specific security commands. SDMMC_CMD_APP_CMD should be sent before sending these commands.
#define SDMMC_CMD_SD_APP_GET_MID   ((uint8_t)44U)
#define SDMMC_CMD_SD_APP_SET_CER_RN1   ((uint8_t)45U)
#define SDMMC_CMD_SD_APP_GET_CER_RN2   ((uint8_t)46U)
#define SDMMC_CMD_SD_APP_SET_CER_RES2   ((uint8_t)47U)
#define SDMMC_CMD_SD_APP_GET_CER_RES1   ((uint8_t)48U)
#define SDMMC_CMD_SD_APP_SECURE_READ_MULTIPLE_BLOCK   ((uint8_t)18U)
#define SDMMC_CMD_SD_APP_SECURE_WRITE_MULTIPLE_BLOCK   ((uint8_t)25U)
#define SDMMC_CMD_SD_APP_SECURE_ERASE   ((uint8_t)38U)
#define SDMMC_CMD_SD_APP_CHANGE_SECURE_AREA   ((uint8_t)49U)
#define SDMMC_CMD_SD_APP_SECURE_WRITE_MKB   ((uint8_t)48U)
#define SDMMC_OCR_ADDR_OUT_OF_RANGE   ((uint32_t)0x80000000U)
 Masks for errors Card Status R1 (OCR Register)
#define SDMMC_OCR_ADDR_MISALIGNED   ((uint32_t)0x40000000U)
#define SDMMC_OCR_BLOCK_LEN_ERR   ((uint32_t)0x20000000U)
#define SDMMC_OCR_ERASE_SEQ_ERR   ((uint32_t)0x10000000U)
#define SDMMC_OCR_BAD_ERASE_PARAM   ((uint32_t)0x08000000U)
#define SDMMC_OCR_WRITE_PROT_VIOLATION   ((uint32_t)0x04000000U)
#define SDMMC_OCR_LOCK_UNLOCK_FAILED   ((uint32_t)0x01000000U)
#define SDMMC_OCR_COM_CRC_FAILED   ((uint32_t)0x00800000U)
#define SDMMC_OCR_ILLEGAL_CMD   ((uint32_t)0x00400000U)
#define SDMMC_OCR_CARD_ECC_FAILED   ((uint32_t)0x00200000U)
#define SDMMC_OCR_CC_ERROR   ((uint32_t)0x00100000U)
#define SDMMC_OCR_GENERAL_UNKNOWN_ERROR   ((uint32_t)0x00080000U)
#define SDMMC_OCR_STREAM_READ_UNDERRUN   ((uint32_t)0x00040000U)
#define SDMMC_OCR_STREAM_WRITE_OVERRUN   ((uint32_t)0x00020000U)
#define SDMMC_OCR_CID_CSD_OVERWRITE   ((uint32_t)0x00010000U)
#define SDMMC_OCR_WP_ERASE_SKIP   ((uint32_t)0x00008000U)
#define SDMMC_OCR_CARD_ECC_DISABLED   ((uint32_t)0x00004000U)
#define SDMMC_OCR_ERASE_RESET   ((uint32_t)0x00002000U)
#define SDMMC_OCR_AKE_SEQ_ERROR   ((uint32_t)0x00000008U)
#define SDMMC_OCR_ERRORBITS   ((uint32_t)0xFDFFE008U)
#define SDMMC_R6_GENERAL_UNKNOWN_ERROR   ((uint32_t)0x00002000U)
 Masks for R6 Response.
#define SDMMC_R6_ILLEGAL_CMD   ((uint32_t)0x00004000U)
#define SDMMC_R6_COM_CRC_FAILED   ((uint32_t)0x00008000U)
#define SDMMC_VOLTAGE_WINDOW_SD   ((uint32_t)0x80100000U)
#define SDMMC_HIGH_CAPACITY   ((uint32_t)0x40000000U)
#define SDMMC_STD_CAPACITY   ((uint32_t)0x00000000U)
#define SDMMC_CHECK_PATTERN   ((uint32_t)0x000001AAU)
#define SD_SWITCH_1_8V_CAPACITY   ((uint32_t)0x01000000U)
#define SDMMC_DDR50_SWITCH_PATTERN   ((uint32_t)0x80FFFF04U)
#define SDMMC_SDR104_SWITCH_PATTERN   ((uint32_t)0x80FF1F03U)
#define SDMMC_SDR50_SWITCH_PATTERN   ((uint32_t)0x80FF1F02U)
#define SDMMC_SDR25_SWITCH_PATTERN   ((uint32_t)0x80FFFF01U)
#define SDMMC_SDR12_SWITCH_PATTERN   ((uint32_t)0x80FFFF00U)
#define SDMMC_MAX_VOLT_TRIAL   ((uint32_t)0x0000FFFFU)
#define SDMMC_MAX_TRIAL   ((uint32_t)0x0000FFFFU)
#define SDMMC_ALLZERO   ((uint32_t)0x00000000U)
#define SDMMC_WIDE_BUS_SUPPORT   ((uint32_t)0x00040000U)
#define SDMMC_SINGLE_BUS_SUPPORT   ((uint32_t)0x00010000U)
#define SDMMC_CARD_LOCKED   ((uint32_t)0x02000000U)
#define SDMMC_DATATIMEOUT   ((uint32_t)0xFFFFFFFFU)
#define SDMMC_0TO7BITS   ((uint32_t)0x000000FFU)
#define SDMMC_8TO15BITS   ((uint32_t)0x0000FF00U)
#define SDMMC_16TO23BITS   ((uint32_t)0x00FF0000U)
#define SDMMC_24TO31BITS   ((uint32_t)0xFF000000U)
#define SDMMC_MAX_DATA_LENGTH   ((uint32_t)0x01FFFFFFU)
#define SDMMC_HALFFIFO   ((uint32_t)0x00000008U)
#define SDMMC_HALFFIFOBYTES   ((uint32_t)0x00000020U)
#define SDMMC_CCCC_ERASE   ((uint32_t)0x00000020U)
 Command Class supported.
#define SDMMC_CMDTIMEOUT   ((uint32_t)5000U) /* Command send and response timeout */
#define SDMMC_MAXERASETIMEOUT   ((uint32_t)63000U) /* Max erase Timeout 63 s */
#define SDMMC_STOPTRANSFERTIMEOUT   ((uint32_t)100000000U) /* Timeout for STOP TRANSMISSION command */
#define SDMMC_CLOCK_EDGE_RISING   ((uint32_t)0x00000000U)
#define SDMMC_CLOCK_EDGE_FALLING   SDMMC_CLKCR_NEGEDGE
#define IS_SDMMC_CLOCK_EDGE(EDGE)
#define SDMMC_CLOCK_POWER_SAVE_DISABLE   ((uint32_t)0x00000000U)
#define SDMMC_CLOCK_POWER_SAVE_ENABLE   SDMMC_CLKCR_PWRSAV
#define IS_SDMMC_CLOCK_POWER_SAVE(SAVE)
#define SDMMC_BUS_WIDE_1B   ((uint32_t)0x00000000U)
#define SDMMC_BUS_WIDE_4B   SDMMC_CLKCR_WIDBUS_0
#define SDMMC_BUS_WIDE_8B   SDMMC_CLKCR_WIDBUS_1
#define IS_SDMMC_BUS_WIDE(WIDE)
#define SDMMC_SPEED_MODE_AUTO   ((uint32_t)0x00000000U)
#define SDMMC_SPEED_MODE_DEFAULT   ((uint32_t)0x00000001U)
#define SDMMC_SPEED_MODE_HIGH   ((uint32_t)0x00000002U)
#define SDMMC_SPEED_MODE_ULTRA   ((uint32_t)0x00000003U)
#define SDMMC_SPEED_MODE_ULTRA_SDR104   SDMMC_SPEED_MODE_ULTRA
#define SDMMC_SPEED_MODE_DDR   ((uint32_t)0x00000004U)
#define SDMMC_SPEED_MODE_ULTRA_SDR50   ((uint32_t)0x00000005U)
#define IS_SDMMC_SPEED_MODE(MODE)
#define SDMMC_HARDWARE_FLOW_CONTROL_DISABLE   ((uint32_t)0x00000000U)
#define SDMMC_HARDWARE_FLOW_CONTROL_ENABLE   SDMMC_CLKCR_HWFC_EN
#define IS_SDMMC_HARDWARE_FLOW_CONTROL(CONTROL)
#define IS_SDMMC_CLKDIV(DIV)   ((DIV) < 0x400U)
#define SDMMC_TRANSCEIVER_UNKNOWN   ((uint32_t)0x00000000U)
#define SDMMC_TRANSCEIVER_NOT_PRESENT   ((uint32_t)0x00000001U)
#define SDMMC_TRANSCEIVER_PRESENT   ((uint32_t)0x00000002U)
#define IS_SDMMC_CMD_INDEX(INDEX)   ((INDEX) < 0x40U)
#define SDMMC_RESPONSE_NO   ((uint32_t)0x00000000U)
#define SDMMC_RESPONSE_SHORT   SDMMC_CMD_WAITRESP_0
#define SDMMC_RESPONSE_LONG   SDMMC_CMD_WAITRESP
#define IS_SDMMC_RESPONSE(RESPONSE)
#define SDMMC_WAIT_NO   ((uint32_t)0x00000000U)
#define SDMMC_WAIT_IT   SDMMC_CMD_WAITINT
#define SDMMC_WAIT_PEND   SDMMC_CMD_WAITPEND
#define IS_SDMMC_WAIT(WAIT)
#define SDMMC_CPSM_DISABLE   ((uint32_t)0x00000000U)
#define SDMMC_CPSM_ENABLE   SDMMC_CMD_CPSMEN
#define IS_SDMMC_CPSM(CPSM)
#define SDMMC_RESP1   ((uint32_t)0x00000000U)
#define SDMMC_RESP2   ((uint32_t)0x00000004U)
#define SDMMC_RESP3   ((uint32_t)0x00000008U)
#define SDMMC_RESP4   ((uint32_t)0x0000000CU)
#define IS_SDMMC_RESP(RESP)
#define SDMMC_DISABLE_IDMA   ((uint32_t)0x00000000)
#define SDMMC_ENABLE_IDMA_SINGLE_BUFF   (SDMMC_IDMA_IDMAEN)
#define SDMMC_ENABLE_IDMA_DOUBLE_BUFF0   (SDMMC_IDMA_IDMAEN | SDMMC_IDMA_IDMABMODE)
#define SDMMC_ENABLE_IDMA_DOUBLE_BUFF1   (SDMMC_IDMA_IDMAEN | SDMMC_IDMA_IDMABMODE | SDMMC_IDMA_IDMABACT)
#define IS_SDMMC_DATA_LENGTH(LENGTH)   ((LENGTH) <= 0x01FFFFFFU)
#define SDMMC_DATABLOCK_SIZE_1B   ((uint32_t)0x00000000U)
#define SDMMC_DATABLOCK_SIZE_2B   SDMMC_DCTRL_DBLOCKSIZE_0
#define SDMMC_DATABLOCK_SIZE_4B   SDMMC_DCTRL_DBLOCKSIZE_1
#define SDMMC_DATABLOCK_SIZE_8B   (SDMMC_DCTRL_DBLOCKSIZE_0|SDMMC_DCTRL_DBLOCKSIZE_1)
#define SDMMC_DATABLOCK_SIZE_16B   SDMMC_DCTRL_DBLOCKSIZE_2
#define SDMMC_DATABLOCK_SIZE_32B   (SDMMC_DCTRL_DBLOCKSIZE_0|SDMMC_DCTRL_DBLOCKSIZE_2)
#define SDMMC_DATABLOCK_SIZE_64B   (SDMMC_DCTRL_DBLOCKSIZE_1|SDMMC_DCTRL_DBLOCKSIZE_2)
#define SDMMC_DATABLOCK_SIZE_128B
#define SDMMC_DATABLOCK_SIZE_256B   SDMMC_DCTRL_DBLOCKSIZE_3
#define SDMMC_DATABLOCK_SIZE_512B   (SDMMC_DCTRL_DBLOCKSIZE_0|SDMMC_DCTRL_DBLOCKSIZE_3)
#define SDMMC_DATABLOCK_SIZE_1024B   (SDMMC_DCTRL_DBLOCKSIZE_1|SDMMC_DCTRL_DBLOCKSIZE_3)
#define SDMMC_DATABLOCK_SIZE_2048B
#define SDMMC_DATABLOCK_SIZE_4096B   (SDMMC_DCTRL_DBLOCKSIZE_2|SDMMC_DCTRL_DBLOCKSIZE_3)
#define SDMMC_DATABLOCK_SIZE_8192B
#define SDMMC_DATABLOCK_SIZE_16384B
#define IS_SDMMC_BLOCK_SIZE(SIZE)
#define SDMMC_TRANSFER_DIR_TO_CARD   ((uint32_t)0x00000000U)
#define SDMMC_TRANSFER_DIR_TO_SDMMC   SDMMC_DCTRL_DTDIR
#define IS_SDMMC_TRANSFER_DIR(DIR)
#define SDMMC_TRANSFER_MODE_BLOCK   ((uint32_t)0x00000000U)
#define SDMMC_TRANSFER_MODE_STREAM   SDMMC_DCTRL_DTMODE_1
#define IS_SDMMC_TRANSFER_MODE(MODE)
#define SDMMC_DPSM_DISABLE   ((uint32_t)0x00000000U)
#define SDMMC_DPSM_ENABLE   SDMMC_DCTRL_DTEN
#define IS_SDMMC_DPSM(DPSM)
#define SDMMC_READ_WAIT_MODE_DATA2   ((uint32_t)0x00000000U)
#define SDMMC_READ_WAIT_MODE_CLK   (SDMMC_DCTRL_RWMOD)
#define IS_SDMMC_READWAIT_MODE(MODE)
#define SDMMC_IT_CCRCFAIL   SDMMC_MASK_CCRCFAILIE
#define SDMMC_IT_DCRCFAIL   SDMMC_MASK_DCRCFAILIE
#define SDMMC_IT_CTIMEOUT   SDMMC_MASK_CTIMEOUTIE
#define SDMMC_IT_DTIMEOUT   SDMMC_MASK_DTIMEOUTIE
#define SDMMC_IT_TXUNDERR   SDMMC_MASK_TXUNDERRIE
#define SDMMC_IT_RXOVERR   SDMMC_MASK_RXOVERRIE
#define SDMMC_IT_CMDREND   SDMMC_MASK_CMDRENDIE
#define SDMMC_IT_CMDSENT   SDMMC_MASK_CMDSENTIE
#define SDMMC_IT_DATAEND   SDMMC_MASK_DATAENDIE
#define SDMMC_IT_DHOLD   SDMMC_MASK_DHOLDIE
#define SDMMC_IT_DBCKEND   SDMMC_MASK_DBCKENDIE
#define SDMMC_IT_DABORT   SDMMC_MASK_DABORTIE
#define SDMMC_IT_TXFIFOHE   SDMMC_MASK_TXFIFOHEIE
#define SDMMC_IT_RXFIFOHF   SDMMC_MASK_RXFIFOHFIE
#define SDMMC_IT_RXFIFOF   SDMMC_MASK_RXFIFOFIE
#define SDMMC_IT_TXFIFOE   SDMMC_MASK_TXFIFOEIE
#define SDMMC_IT_BUSYD0END   SDMMC_MASK_BUSYD0ENDIE
#define SDMMC_IT_SDIOIT   SDMMC_MASK_SDIOITIE
#define SDMMC_IT_ACKFAIL   SDMMC_MASK_ACKFAILIE
#define SDMMC_IT_ACKTIMEOUT   SDMMC_MASK_ACKTIMEOUTIE
#define SDMMC_IT_VSWEND   SDMMC_MASK_VSWENDIE
#define SDMMC_IT_CKSTOP   SDMMC_MASK_CKSTOPIE
#define SDMMC_IT_IDMABTC   SDMMC_MASK_IDMABTCIE
#define SDMMC_FLAG_CCRCFAIL   SDMMC_STA_CCRCFAIL
#define SDMMC_FLAG_DCRCFAIL   SDMMC_STA_DCRCFAIL
#define SDMMC_FLAG_CTIMEOUT   SDMMC_STA_CTIMEOUT
#define SDMMC_FLAG_DTIMEOUT   SDMMC_STA_DTIMEOUT
#define SDMMC_FLAG_TXUNDERR   SDMMC_STA_TXUNDERR
#define SDMMC_FLAG_RXOVERR   SDMMC_STA_RXOVERR
#define SDMMC_FLAG_CMDREND   SDMMC_STA_CMDREND
#define SDMMC_FLAG_CMDSENT   SDMMC_STA_CMDSENT
#define SDMMC_FLAG_DATAEND   SDMMC_STA_DATAEND
#define SDMMC_FLAG_DHOLD   SDMMC_STA_DHOLD
#define SDMMC_FLAG_DBCKEND   SDMMC_STA_DBCKEND
#define SDMMC_FLAG_DABORT   SDMMC_STA_DABORT
#define SDMMC_FLAG_DPSMACT   SDMMC_STA_DPSMACT
#define SDMMC_FLAG_CMDACT   SDMMC_STA_CPSMACT
#define SDMMC_FLAG_TXFIFOHE   SDMMC_STA_TXFIFOHE
#define SDMMC_FLAG_RXFIFOHF   SDMMC_STA_RXFIFOHF
#define SDMMC_FLAG_TXFIFOF   SDMMC_STA_TXFIFOF
#define SDMMC_FLAG_RXFIFOF   SDMMC_STA_RXFIFOF
#define SDMMC_FLAG_TXFIFOE   SDMMC_STA_TXFIFOE
#define SDMMC_FLAG_RXFIFOE   SDMMC_STA_RXFIFOE
#define SDMMC_FLAG_BUSYD0   SDMMC_STA_BUSYD0
#define SDMMC_FLAG_BUSYD0END   SDMMC_STA_BUSYD0END
#define SDMMC_FLAG_SDIOIT   SDMMC_STA_SDIOIT
#define SDMMC_FLAG_ACKFAIL   SDMMC_STA_ACKFAIL
#define SDMMC_FLAG_ACKTIMEOUT   SDMMC_STA_ACKTIMEOUT
#define SDMMC_FLAG_VSWEND   SDMMC_STA_VSWEND
#define SDMMC_FLAG_CKSTOP   SDMMC_STA_CKSTOP
#define SDMMC_FLAG_IDMATE   SDMMC_STA_IDMATE
#define SDMMC_FLAG_IDMABTC   SDMMC_STA_IDMABTC
#define SDMMC_STATIC_FLAGS
#define SDMMC_STATIC_CMD_FLAGS
#define SDMMC_STATIC_DATA_FLAGS
#define CLKCR_CLEAR_MASK
#define DCTRL_CLEAR_MASK
#define CMD_CLEAR_MASK
#define SDMMC_INIT_CLK_DIV   ((uint8_t)0xFA)
#define SDMMC_NSPEED_CLK_DIV   ((uint8_t)0x4)
#define SDMMC_HSPEED_CLK_DIV   ((uint8_t)0x2)
#define __SDMMC_ENABLE_IT(__INSTANCE__, __INTERRUPT__)   ((__INSTANCE__)->MASK |= (__INTERRUPT__))
 Enable the SDMMC device interrupt.
#define __SDMMC_DISABLE_IT(__INSTANCE__, __INTERRUPT__)   ((__INSTANCE__)->MASK &= ~(__INTERRUPT__))
 Disable the SDMMC device interrupt.
#define __SDMMC_GET_FLAG(__INSTANCE__, __FLAG__)   (((__INSTANCE__)->STA &(__FLAG__)) != 0U)
 Checks whether the specified SDMMC flag is set or not.
#define __SDMMC_CLEAR_FLAG(__INSTANCE__, __FLAG__)   ((__INSTANCE__)->ICR = (__FLAG__))
 Clears the SDMMC pending flags.
#define __SDMMC_GET_IT(__INSTANCE__, __INTERRUPT__)   (((__INSTANCE__)->STA &(__INTERRUPT__)) == (__INTERRUPT__))
 Checks whether the specified SDMMC interrupt has occurred or not.
#define __SDMMC_CLEAR_IT(__INSTANCE__, __INTERRUPT__)   ((__INSTANCE__)->ICR = (__INTERRUPT__))
 Clears the SDMMC's interrupt pending bits.
#define __SDMMC_START_READWAIT_ENABLE(__INSTANCE__)   ((__INSTANCE__)->DCTRL |= SDMMC_DCTRL_RWSTART)
 Enable Start the SD I/O Read Wait operation.
#define __SDMMC_START_READWAIT_DISABLE(__INSTANCE__)   ((__INSTANCE__)->DCTRL &= ~SDMMC_DCTRL_RWSTART)
 Disable Start the SD I/O Read Wait operations.
#define __SDMMC_STOP_READWAIT_ENABLE(__INSTANCE__)   ((__INSTANCE__)->DCTRL |= SDMMC_DCTRL_RWSTOP)
#define __SDMMC_STOP_READWAIT_DISABLE(__INSTANCE__)   ((__INSTANCE__)->DCTRL &= ~SDMMC_DCTRL_RWSTOP)
 Disable Stop the SD I/O Read Wait operations.
#define __SDMMC_OPERATION_ENABLE(__INSTANCE__)   ((__INSTANCE__)->DCTRL |= SDMMC_DCTRL_SDIOEN)
 Enable the SD I/O Mode Operation.
#define __SDMMC_OPERATION_DISABLE(__INSTANCE__)   ((__INSTANCE__)->DCTRL &= ~SDMMC_DCTRL_SDIOEN)
 Disable the SD I/O Mode Operation.
#define __SDMMC_SUSPEND_CMD_ENABLE(__INSTANCE__)   ((__INSTANCE__)->CMD |= SDMMC_CMD_CMDSUSPEND)
 Enable the SD I/O Suspend command sending.
#define __SDMMC_SUSPEND_CMD_DISABLE(__INSTANCE__)   ((__INSTANCE__)->CMD &= ~SDMMC_CMD_CMDSUSPEND)
 Disable the SD I/O Suspend command sending.
#define __SDMMC_CMDTRANS_ENABLE(__INSTANCE__)   ((__INSTANCE__)->CMD |= SDMMC_CMD_CMDTRANS)
 Enable the CMDTRANS mode.
#define __SDMMC_CMDTRANS_DISABLE(__INSTANCE__)   ((__INSTANCE__)->CMD &= ~SDMMC_CMD_CMDTRANS)
 Disable the CMDTRANS mode.
#define __SDMMC_CMDSTOP_ENABLE(__INSTANCE__)   ((__INSTANCE__)->CMD |= SDMMC_CMD_CMDSTOP)
 Enable the CMDSTOP mode.
#define __SDMMC_CMDSTOP_DISABLE(__INSTANCE__)   ((__INSTANCE__)->CMD &= ~SDMMC_CMD_CMDSTOP)
 Disable the CMDSTOP mode.
HAL_StatusTypeDef SDMMC_Init (SDMMC_TypeDef *SDMMCx, SDMMC_InitTypeDef Init)
uint32_t SDMMC_ReadFIFO (SDMMC_TypeDef *SDMMCx)
HAL_StatusTypeDef SDMMC_WriteFIFO (SDMMC_TypeDef *SDMMCx, uint32_t *pWriteData)
HAL_StatusTypeDef SDMMC_PowerState_ON (SDMMC_TypeDef *SDMMCx)
HAL_StatusTypeDef SDMMC_PowerState_Cycle (SDMMC_TypeDef *SDMMCx)
HAL_StatusTypeDef SDMMC_PowerState_OFF (SDMMC_TypeDef *SDMMCx)
uint32_t SDMMC_GetPowerState (SDMMC_TypeDef *SDMMCx)
HAL_StatusTypeDef SDMMC_SendCommand (SDMMC_TypeDef *SDMMCx, SDMMC_CmdInitTypeDef *Command)
uint8_t SDMMC_GetCommandResponse (SDMMC_TypeDef *SDMMCx)
uint32_t SDMMC_GetResponse (SDMMC_TypeDef *SDMMCx, uint32_t Response)
HAL_StatusTypeDef SDMMC_ConfigData (SDMMC_TypeDef *SDMMCx, SDMMC_DataInitTypeDef *Data)
uint32_t SDMMC_GetDataCounter (SDMMC_TypeDef *SDMMCx)
uint32_t SDMMC_GetFIFOCount (SDMMC_TypeDef *SDMMCx)
HAL_StatusTypeDef SDMMC_SetSDMMCReadWaitMode (SDMMC_TypeDef *SDMMCx, uint32_t SDMMC_ReadWaitMode)
uint32_t SDMMC_CmdBlockLength (SDMMC_TypeDef *SDMMCx, uint32_t BlockSize)
uint32_t SDMMC_CmdReadSingleBlock (SDMMC_TypeDef *SDMMCx, uint32_t ReadAdd)
uint32_t SDMMC_CmdReadMultiBlock (SDMMC_TypeDef *SDMMCx, uint32_t ReadAdd)
uint32_t SDMMC_CmdWriteSingleBlock (SDMMC_TypeDef *SDMMCx, uint32_t WriteAdd)
uint32_t SDMMC_CmdWriteMultiBlock (SDMMC_TypeDef *SDMMCx, uint32_t WriteAdd)
uint32_t SDMMC_CmdEraseStartAdd (SDMMC_TypeDef *SDMMCx, uint32_t StartAdd)
uint32_t SDMMC_CmdSDEraseStartAdd (SDMMC_TypeDef *SDMMCx, uint32_t StartAdd)
uint32_t SDMMC_CmdEraseEndAdd (SDMMC_TypeDef *SDMMCx, uint32_t EndAdd)
uint32_t SDMMC_CmdSDEraseEndAdd (SDMMC_TypeDef *SDMMCx, uint32_t EndAdd)
uint32_t SDMMC_CmdErase (SDMMC_TypeDef *SDMMCx, uint32_t EraseType)
uint32_t SDMMC_CmdStopTransfer (SDMMC_TypeDef *SDMMCx)
uint32_t SDMMC_CmdSelDesel (SDMMC_TypeDef *SDMMCx, uint32_t Addr)
uint32_t SDMMC_CmdGoIdleState (SDMMC_TypeDef *SDMMCx)
uint32_t SDMMC_CmdOperCond (SDMMC_TypeDef *SDMMCx)
uint32_t SDMMC_CmdAppCommand (SDMMC_TypeDef *SDMMCx, uint32_t Argument)
uint32_t SDMMC_CmdAppOperCommand (SDMMC_TypeDef *SDMMCx, uint32_t Argument)
uint32_t SDMMC_CmdBusWidth (SDMMC_TypeDef *SDMMCx, uint32_t BusWidth)
uint32_t SDMMC_CmdSendSCR (SDMMC_TypeDef *SDMMCx)
uint32_t SDMMC_CmdSendCID (SDMMC_TypeDef *SDMMCx)
uint32_t SDMMC_CmdSendCSD (SDMMC_TypeDef *SDMMCx, uint32_t Argument)
uint32_t SDMMC_CmdSetRelAdd (SDMMC_TypeDef *SDMMCx, uint16_t *pRCA)
uint32_t SDMMC_CmdSetRelAddMmc (SDMMC_TypeDef *SDMMCx, uint16_t RCA)
uint32_t SDMMC_CmdSleepMmc (SDMMC_TypeDef *SDMMCx, uint32_t Argument)
uint32_t SDMMC_CmdSendStatus (SDMMC_TypeDef *SDMMCx, uint32_t Argument)
uint32_t SDMMC_CmdStatusRegister (SDMMC_TypeDef *SDMMCx)
uint32_t SDMMC_CmdVoltageSwitch (SDMMC_TypeDef *SDMMCx)
uint32_t SDMMC_CmdOpCondition (SDMMC_TypeDef *SDMMCx, uint32_t Argument)
uint32_t SDMMC_CmdSwitch (SDMMC_TypeDef *SDMMCx, uint32_t Argument)
uint32_t SDMMC_CmdSendEXTCSD (SDMMC_TypeDef *SDMMCx, uint32_t Argument)
uint32_t SDMMC_GetCmdResp1 (SDMMC_TypeDef *SDMMCx, uint8_t SD_CMD, uint32_t Timeout)
uint32_t SDMMC_GetCmdResp2 (SDMMC_TypeDef *SDMMCx)
uint32_t SDMMC_GetCmdResp3 (SDMMC_TypeDef *SDMMCx)
uint32_t SDMMC_GetCmdResp6 (SDMMC_TypeDef *SDMMCx, uint8_t SD_CMD, uint16_t *pRCA)
uint32_t SDMMC_GetCmdResp7 (SDMMC_TypeDef *SDMMCx)
Author
MCD Application Team
Attention
