RTEMS 6.1
SDMMC Data Control structure. More...
#include <stm32h7xx_ll_sdmmc.h>
Data Fields | |
| uint32_t | DataTimeOut |
| uint32_t | DataLength |
| uint32_t | DataBlockSize |
| uint32_t | TransferDir |
| uint32_t | TransferMode |
| uint32_t | DPSM |
| uint32_t SDMMC_DataInitTypeDef::DataBlockSize |
Specifies the data block size for block transfer. This parameter can be a value of Data Block Size
| uint32_t SDMMC_DataInitTypeDef::DataLength |
Specifies the number of data bytes to be transferred.
| uint32_t SDMMC_DataInitTypeDef::DataTimeOut |
Specifies the data timeout period in card bus clock periods.
| uint32_t SDMMC_DataInitTypeDef::DPSM |
Specifies whether SDMMC Data path state machine (DPSM) is enabled or disabled. This parameter can be a value of DPSM State
| uint32_t SDMMC_DataInitTypeDef::TransferDir |
Specifies the data transfer direction, whether the transfer is a read or write. This parameter can be a value of Transfer Direction
| uint32_t SDMMC_DataInitTypeDef::TransferMode |
Specifies whether data transfer is in stream or block mode. This parameter can be a value of Transfer Type
