RTEMS 6.1
Modules | Macros
 Bus Width
 CPSM State
 Clock Division
 Clock Edge
 Clock Power Saving
 Command Index
 Hardware Flow Control
 Response Register
 Response Type
 SDMMC_LL Exported Macros
 SDMMC_LL_Exported_Functions
 SDMMC_LL_Speed_Mode
 Transceiver Present
 Wait Interrupt
#define SDMMC_ERROR_NONE   ((uint32_t)0x00000000U)
#define SDMMC_ERROR_CMD_CRC_FAIL   ((uint32_t)0x00000001U)
#define SDMMC_ERROR_DATA_CRC_FAIL   ((uint32_t)0x00000002U)
#define SDMMC_ERROR_CMD_RSP_TIMEOUT   ((uint32_t)0x00000004U)
#define SDMMC_ERROR_DATA_TIMEOUT   ((uint32_t)0x00000008U)
#define SDMMC_ERROR_TX_UNDERRUN   ((uint32_t)0x00000010U)
#define SDMMC_ERROR_RX_OVERRUN   ((uint32_t)0x00000020U)
#define SDMMC_ERROR_ADDR_MISALIGNED   ((uint32_t)0x00000040U)
#define SDMMC_ERROR_BLOCK_LEN_ERR   ((uint32_t)0x00000080U)
#define SDMMC_ERROR_ERASE_SEQ_ERR   ((uint32_t)0x00000100U)
#define SDMMC_ERROR_BAD_ERASE_PARAM   ((uint32_t)0x00000200U)
#define SDMMC_ERROR_WRITE_PROT_VIOLATION   ((uint32_t)0x00000400U)
#define SDMMC_ERROR_LOCK_UNLOCK_FAILED   ((uint32_t)0x00000800U)
#define SDMMC_ERROR_COM_CRC_FAILED   ((uint32_t)0x00001000U)
#define SDMMC_ERROR_ILLEGAL_CMD   ((uint32_t)0x00002000U)
#define SDMMC_ERROR_CARD_ECC_FAILED   ((uint32_t)0x00004000U)
#define SDMMC_ERROR_CC_ERR   ((uint32_t)0x00008000U)
#define SDMMC_ERROR_GENERAL_UNKNOWN_ERR   ((uint32_t)0x00010000U)
#define SDMMC_ERROR_STREAM_READ_UNDERRUN   ((uint32_t)0x00020000U)
#define SDMMC_ERROR_STREAM_WRITE_OVERRUN   ((uint32_t)0x00040000U)
#define SDMMC_ERROR_CID_CSD_OVERWRITE   ((uint32_t)0x00080000U)
#define SDMMC_ERROR_WP_ERASE_SKIP   ((uint32_t)0x00100000U)
#define SDMMC_ERROR_CARD_ECC_DISABLED   ((uint32_t)0x00200000U)
#define SDMMC_ERROR_ERASE_RESET   ((uint32_t)0x00400000U)
#define SDMMC_ERROR_AKE_SEQ_ERR   ((uint32_t)0x00800000U)
#define SDMMC_ERROR_INVALID_VOLTRANGE   ((uint32_t)0x01000000U)
#define SDMMC_ERROR_ADDR_OUT_OF_RANGE   ((uint32_t)0x02000000U)
#define SDMMC_ERROR_REQUEST_NOT_APPLICABLE   ((uint32_t)0x04000000U)
#define SDMMC_ERROR_INVALID_PARAMETER   ((uint32_t)0x08000000U)
#define SDMMC_ERROR_UNSUPPORTED_FEATURE   ((uint32_t)0x10000000U)
#define SDMMC_ERROR_BUSY   ((uint32_t)0x20000000U)
#define SDMMC_ERROR_DMA   ((uint32_t)0x40000000U)
#define SDMMC_ERROR_TIMEOUT   ((uint32_t)0x80000000U)
#define SDMMC_CMD_GO_IDLE_STATE   ((uint8_t)0U)
 SDMMC Commands Index.
#define SDMMC_CMD_SEND_OP_COND   ((uint8_t)1U)
#define SDMMC_CMD_ALL_SEND_CID   ((uint8_t)2U)
#define SDMMC_CMD_SET_REL_ADDR   ((uint8_t)3U)
#define SDMMC_CMD_SET_DSR   ((uint8_t)4U)
#define SDMMC_CMD_SDMMC_SEN_OP_COND   ((uint8_t)5U)
#define SDMMC_CMD_HS_SWITCH   ((uint8_t)6U)
#define SDMMC_CMD_SEL_DESEL_CARD   ((uint8_t)7U)
#define SDMMC_CMD_HS_SEND_EXT_CSD   ((uint8_t)8U)
#define SDMMC_CMD_SEND_CSD   ((uint8_t)9U)
#define SDMMC_CMD_SEND_CID   ((uint8_t)10U)
#define SDMMC_CMD_VOLTAGE_SWITCH   ((uint8_t)11U)
#define SDMMC_CMD_STOP_TRANSMISSION   ((uint8_t)12U)
#define SDMMC_CMD_SEND_STATUS   ((uint8_t)13U)
#define SDMMC_CMD_HS_BUSTEST_READ   ((uint8_t)14U)
#define SDMMC_CMD_GO_INACTIVE_STATE   ((uint8_t)15U)
#define SDMMC_CMD_SET_BLOCKLEN   ((uint8_t)16U)
#define SDMMC_CMD_READ_SINGLE_BLOCK   ((uint8_t)17U)
#define SDMMC_CMD_READ_MULT_BLOCK   ((uint8_t)18U)
#define SDMMC_CMD_HS_BUSTEST_WRITE   ((uint8_t)19U)
#define SDMMC_CMD_WRITE_DAT_UNTIL_STOP   ((uint8_t)20U)
#define SDMMC_CMD_SET_BLOCK_COUNT   ((uint8_t)23U)
#define SDMMC_CMD_WRITE_SINGLE_BLOCK   ((uint8_t)24U)
#define SDMMC_CMD_WRITE_MULT_BLOCK   ((uint8_t)25U)
#define SDMMC_CMD_PROG_CID   ((uint8_t)26U)
#define SDMMC_CMD_PROG_CSD   ((uint8_t)27U)
#define SDMMC_CMD_SET_WRITE_PROT   ((uint8_t)28U)
#define SDMMC_CMD_CLR_WRITE_PROT   ((uint8_t)29U)
#define SDMMC_CMD_SEND_WRITE_PROT   ((uint8_t)30U)
#define SDMMC_CMD_SD_ERASE_GRP_START   ((uint8_t)32U)
#define SDMMC_CMD_SD_ERASE_GRP_END   ((uint8_t)33U)
#define SDMMC_CMD_ERASE_GRP_START   ((uint8_t)35U)
#define SDMMC_CMD_ERASE_GRP_END   ((uint8_t)36U)
#define SDMMC_CMD_ERASE   ((uint8_t)38U)
#define SDMMC_CMD_FAST_IO   ((uint8_t)39U)
#define SDMMC_CMD_GO_IRQ_STATE   ((uint8_t)40U)
#define SDMMC_CMD_LOCK_UNLOCK   ((uint8_t)42U)
#define SDMMC_CMD_APP_CMD   ((uint8_t)55U)
#define SDMMC_CMD_GEN_CMD   ((uint8_t)56U)
#define SDMMC_CMD_NO_CMD   ((uint8_t)64U)
#define SDMMC_CMD_APP_SD_SET_BUSWIDTH   ((uint8_t)6U)
 Following commands are SD Card Specific commands. SDMMC_APP_CMD should be sent before sending these commands.
#define SDMMC_CMD_SD_APP_STATUS   ((uint8_t)13U)
#define SDMMC_CMD_SD_APP_SEND_NUM_WRITE_BLOCKS   ((uint8_t)22U)
#define SDMMC_CMD_SD_APP_OP_COND   ((uint8_t)41U)
#define SDMMC_CMD_SD_APP_SET_CLR_CARD_DETECT   ((uint8_t)42U)
#define SDMMC_CMD_SD_APP_SEND_SCR   ((uint8_t)51U)
#define SDMMC_CMD_SDMMC_RW_DIRECT   ((uint8_t)52U)
#define SDMMC_CMD_SDMMC_RW_EXTENDED   ((uint8_t)53U)
#define SDMMC_CMD_MMC_SLEEP_AWAKE   ((uint8_t)5U)
 Following commands are MMC Specific commands.
#define SDMMC_CMD_SD_APP_GET_MKB   ((uint8_t)43U)
 Following commands are SD Card Specific security commands. SDMMC_CMD_APP_CMD should be sent before sending these commands.
#define SDMMC_CMD_SD_APP_GET_MID   ((uint8_t)44U)
#define SDMMC_CMD_SD_APP_SET_CER_RN1   ((uint8_t)45U)
#define SDMMC_CMD_SD_APP_GET_CER_RN2   ((uint8_t)46U)
#define SDMMC_CMD_SD_APP_SET_CER_RES2   ((uint8_t)47U)
#define SDMMC_CMD_SD_APP_GET_CER_RES1   ((uint8_t)48U)
#define SDMMC_CMD_SD_APP_SECURE_READ_MULTIPLE_BLOCK   ((uint8_t)18U)
#define SDMMC_CMD_SD_APP_SECURE_WRITE_MULTIPLE_BLOCK   ((uint8_t)25U)
#define SDMMC_CMD_SD_APP_SECURE_ERASE   ((uint8_t)38U)
#define SDMMC_CMD_SD_APP_CHANGE_SECURE_AREA   ((uint8_t)49U)
#define SDMMC_CMD_SD_APP_SECURE_WRITE_MKB   ((uint8_t)48U)
#define SDMMC_OCR_ADDR_OUT_OF_RANGE   ((uint32_t)0x80000000U)
 Masks for errors Card Status R1 (OCR Register)
#define SDMMC_OCR_ADDR_MISALIGNED   ((uint32_t)0x40000000U)
#define SDMMC_OCR_BLOCK_LEN_ERR   ((uint32_t)0x20000000U)
#define SDMMC_OCR_ERASE_SEQ_ERR   ((uint32_t)0x10000000U)
#define SDMMC_OCR_BAD_ERASE_PARAM   ((uint32_t)0x08000000U)
#define SDMMC_OCR_WRITE_PROT_VIOLATION   ((uint32_t)0x04000000U)
#define SDMMC_OCR_LOCK_UNLOCK_FAILED   ((uint32_t)0x01000000U)
#define SDMMC_OCR_COM_CRC_FAILED   ((uint32_t)0x00800000U)
#define SDMMC_OCR_ILLEGAL_CMD   ((uint32_t)0x00400000U)
#define SDMMC_OCR_CARD_ECC_FAILED   ((uint32_t)0x00200000U)
#define SDMMC_OCR_CC_ERROR   ((uint32_t)0x00100000U)
#define SDMMC_OCR_GENERAL_UNKNOWN_ERROR   ((uint32_t)0x00080000U)
#define SDMMC_OCR_STREAM_READ_UNDERRUN   ((uint32_t)0x00040000U)
#define SDMMC_OCR_STREAM_WRITE_OVERRUN   ((uint32_t)0x00020000U)
#define SDMMC_OCR_CID_CSD_OVERWRITE   ((uint32_t)0x00010000U)
#define SDMMC_OCR_WP_ERASE_SKIP   ((uint32_t)0x00008000U)
#define SDMMC_OCR_CARD_ECC_DISABLED   ((uint32_t)0x00004000U)
#define SDMMC_OCR_ERASE_RESET   ((uint32_t)0x00002000U)
#define SDMMC_OCR_AKE_SEQ_ERROR   ((uint32_t)0x00000008U)
#define SDMMC_OCR_ERRORBITS   ((uint32_t)0xFDFFE008U)
#define SDMMC_R6_GENERAL_UNKNOWN_ERROR   ((uint32_t)0x00002000U)
 Masks for R6 Response.
#define SDMMC_R6_ILLEGAL_CMD   ((uint32_t)0x00004000U)
#define SDMMC_R6_COM_CRC_FAILED   ((uint32_t)0x00008000U)
#define SDMMC_VOLTAGE_WINDOW_SD   ((uint32_t)0x80100000U)
#define SDMMC_HIGH_CAPACITY   ((uint32_t)0x40000000U)
#define SDMMC_STD_CAPACITY   ((uint32_t)0x00000000U)
#define SDMMC_CHECK_PATTERN   ((uint32_t)0x000001AAU)
#define SD_SWITCH_1_8V_CAPACITY   ((uint32_t)0x01000000U)
#define SDMMC_DDR50_SWITCH_PATTERN   ((uint32_t)0x80FFFF04U)
#define SDMMC_SDR104_SWITCH_PATTERN   ((uint32_t)0x80FF1F03U)
#define SDMMC_SDR50_SWITCH_PATTERN   ((uint32_t)0x80FF1F02U)
#define SDMMC_SDR25_SWITCH_PATTERN   ((uint32_t)0x80FFFF01U)
#define SDMMC_SDR12_SWITCH_PATTERN   ((uint32_t)0x80FFFF00U)
#define SDMMC_MAX_VOLT_TRIAL   ((uint32_t)0x0000FFFFU)
#define SDMMC_MAX_TRIAL   ((uint32_t)0x0000FFFFU)
#define SDMMC_ALLZERO   ((uint32_t)0x00000000U)
#define SDMMC_WIDE_BUS_SUPPORT   ((uint32_t)0x00040000U)
#define SDMMC_SINGLE_BUS_SUPPORT   ((uint32_t)0x00010000U)
#define SDMMC_CARD_LOCKED   ((uint32_t)0x02000000U)
#define SDMMC_DATATIMEOUT   ((uint32_t)0xFFFFFFFFU)
#define SDMMC_0TO7BITS   ((uint32_t)0x000000FFU)
#define SDMMC_8TO15BITS   ((uint32_t)0x0000FF00U)
#define SDMMC_16TO23BITS   ((uint32_t)0x00FF0000U)
#define SDMMC_24TO31BITS   ((uint32_t)0xFF000000U)
#define SDMMC_MAX_DATA_LENGTH   ((uint32_t)0x01FFFFFFU)
#define SDMMC_HALFFIFO   ((uint32_t)0x00000008U)
#define SDMMC_HALFFIFOBYTES   ((uint32_t)0x00000020U)
#define SDMMC_CCCC_ERASE   ((uint32_t)0x00000020U)
 Command Class supported.
#define SDMMC_CMDTIMEOUT   ((uint32_t)5000U) /* Command send and response timeout */
#define SDMMC_MAXERASETIMEOUT   ((uint32_t)63000U) /* Max erase Timeout 63 s */
#define SDMMC_STOPTRANSFERTIMEOUT   ((uint32_t)100000000U) /* Timeout for STOP TRANSMISSION command */
◆ SDMMC_CMD_ALL_SEND_CID
Asks any card connected to the host to send the CID numbers on the CMD line.
◆ SDMMC_CMD_APP_CMD
Indicates to the card that the next command is an application specific command rather than a standard command.
◆ SDMMC_CMD_APP_SD_SET_BUSWIDTH
(ACMD6) Defines the data bus width to be used for data transfer. The allowed data bus widths are given in SCR register.
◆ SDMMC_CMD_CLR_WRITE_PROT
Clears the write protection bit of the addressed group.
◆ SDMMC_CMD_ERASE
Reserved for SD security applications.
◆ SDMMC_CMD_ERASE_GRP_END
Sets the address of the last write block of the continuous range to be erased. Reserved for each command system set by switch function command (CMD6).
◆ SDMMC_CMD_ERASE_GRP_START
Sets the address of the first write block to be erased. Reserved for each command system set by switch function command (CMD6).
◆ SDMMC_CMD_FAST_IO
SD card doesn't support it (Reserved).
◆ SDMMC_CMD_GEN_CMD
Used either to transfer a data block to the card or to get a data block from the card for general purpose/application specific commands.
◆ SDMMC_CMD_GO_IDLE_STATE
Resets the SD memory card.
◆ SDMMC_CMD_GO_INACTIVE_STATE
Sends an addressed card into the inactive state.
◆ SDMMC_CMD_GO_IRQ_STATE
◆ SDMMC_CMD_HS_BUSTEST_READ
Reserved
◆ SDMMC_CMD_HS_BUSTEST_WRITE
64 bytes tuning pattern is sent for SDR50 and SDR104.
◆ SDMMC_CMD_HS_SEND_EXT_CSD
Sends SD Memory Card interface condition, which includes host supply voltage information and asks the card whether card supports voltage.
◆ SDMMC_CMD_HS_SWITCH
Checks switchable function (mode 0) and switch card function (mode 1).
◆ SDMMC_CMD_LOCK_UNLOCK
Sets/resets the password or lock/unlock the card. The size of the data block is set by the SET_BLOCK_LEN command.
◆ SDMMC_CMD_MMC_SLEEP_AWAKE
Toggle the device between Sleep state and Standby state.
◆ SDMMC_CMD_NO_CMD
No command
◆ SDMMC_CMD_PROG_CID
Reserved for manufacturers.
◆ SDMMC_CMD_PROG_CSD
Programming of the programmable bits of the CSD.
◆ SDMMC_CMD_READ_MULT_BLOCK
Continuously transfers data blocks from card to host until interrupted by STOP_TRANSMISSION command.
◆ SDMMC_CMD_READ_SINGLE_BLOCK
Reads single block of size selected by SET_BLOCKLEN in case of SDSC, and a block of fixed 512 bytes in case of SDHC and SDXC.
◆ SDMMC_CMD_SD_APP_OP_COND
(ACMD41) Sends host capacity support information (HCS) and asks the accessed card to send its operating condition register (OCR) content in the response on the CMD line.
◆ SDMMC_CMD_SD_APP_SEND_NUM_WRITE_BLOCKS
(ACMD22) Sends the number of the written (without errors) write blocks. Responds with 32bit+CRC data block.
◆ SDMMC_CMD_SD_APP_SEND_SCR
Reads the SD Configuration Register (SCR).
◆ SDMMC_CMD_SD_APP_SET_CLR_CARD_DETECT
(ACMD42) Connect/Disconnect the 50 KOhm pull-up resistor on CD/DAT3 (pin 1) of the card
◆ SDMMC_CMD_SD_APP_STATUS
(ACMD13) Sends the SD status.
◆ SDMMC_CMD_SD_ERASE_GRP_END
◆ SDMMC_CMD_SD_ERASE_GRP_START
Sets the address of the first write block to be erased. (For SD card only).
◆ SDMMC_CMD_SDMMC_RW_DIRECT
For SD I/O card only, reserved for security specification.
◆ SDMMC_CMD_SDMMC_RW_EXTENDED
◆ SDMMC_CMD_SDMMC_SEN_OP_COND
◆ SDMMC_CMD_SEL_DESEL_CARD
Selects the card by its own relative address and gets deselected by any other address
◆ SDMMC_CMD_SEND_CID
Addressed card sends its card identification (CID) on the CMD line.
◆ SDMMC_CMD_SEND_CSD
Addressed card sends its card specific data (CSD) on the CMD line.
◆ SDMMC_CMD_SEND_OP_COND
Sends host capacity support information and activates the card's initialization process.
◆ SDMMC_CMD_SEND_STATUS
Addressed card sends its status register.
◆ SDMMC_CMD_SEND_WRITE_PROT
Asks the card to send the status of the write protection bits.
◆ SDMMC_CMD_SET_BLOCK_COUNT
Specify block count for CMD18 and CMD25.
◆ SDMMC_CMD_SET_BLOCKLEN
Sets the block length (in bytes for SDSC) for all following block commands (read, write, lock). Default block length is fixed to 512 Bytes. Not effective
for SDHS and SDXC.
◆ SDMMC_CMD_SET_DSR
Programs the DSR of all cards.
◆ SDMMC_CMD_SET_REL_ADDR
Asks the card to publish a new relative address (RCA).
◆ SDMMC_CMD_SET_WRITE_PROT
Sets the write protection bit of the addressed group.
◆ SDMMC_CMD_STOP_TRANSMISSION
Forces the card to stop transmission.
◆ SDMMC_CMD_VOLTAGE_SWITCH
SD card Voltage switch to 1.8V mode.
◆ SDMMC_CMD_WRITE_DAT_UNTIL_STOP
Speed class control command.
◆ SDMMC_CMD_WRITE_MULT_BLOCK
Continuously writes blocks of data until a STOP_TRANSMISSION follows.
◆ SDMMC_CMD_WRITE_SINGLE_BLOCK
Writes single block of size selected by SET_BLOCKLEN in case of SDSC, and a block of fixed 512 bytes in case of SDHC and SDXC.
◆ SDMMC_ERROR_ADDR_MISALIGNED
Misaligned address
◆ SDMMC_ERROR_ADDR_OUT_OF_RANGE
Error when addressed block is out of range
◆ SDMMC_ERROR_AKE_SEQ_ERR
Error in sequence of authentication
◆ SDMMC_ERROR_BAD_ERASE_PARAM
An invalid selection for erase groups
◆ SDMMC_ERROR_BLOCK_LEN_ERR
Transferred block length is not allowed for the card or the number of transferred bytes does not match the block length
◆ SDMMC_ERROR_BUSY
Error when transfer process is busy
◆ SDMMC_ERROR_CARD_ECC_DISABLED
Command has been executed without using internal ECC
◆ SDMMC_ERROR_CARD_ECC_FAILED
Card internal ECC was applied but failed to correct the data
◆ SDMMC_ERROR_CC_ERR
Internal card controller error
◆ SDMMC_ERROR_CID_CSD_OVERWRITE
CID/CSD overwrite error
◆ SDMMC_ERROR_CMD_CRC_FAIL
Command response received (but CRC check failed)
◆ SDMMC_ERROR_CMD_RSP_TIMEOUT
Command response timeout
◆ SDMMC_ERROR_COM_CRC_FAILED
CRC check of the previous command failed
◆ SDMMC_ERROR_DATA_CRC_FAIL
Data block sent/received (CRC check failed)
◆ SDMMC_ERROR_DATA_TIMEOUT
Data timeout
◆ SDMMC_ERROR_DMA
Error while DMA transfer
◆ SDMMC_ERROR_ERASE_RESET
Erase sequence was cleared before executing because an out of erase sequence command was received
◆ SDMMC_ERROR_ERASE_SEQ_ERR
An error in the sequence of erase command occurs
◆ SDMMC_ERROR_GENERAL_UNKNOWN_ERR
General or unknown error
◆ SDMMC_ERROR_ILLEGAL_CMD
Command is not legal for the card state
◆ SDMMC_ERROR_INVALID_PARAMETER
the used parameter is not valid
◆ SDMMC_ERROR_INVALID_VOLTRANGE
Error in case of invalid voltage range
◆ SDMMC_ERROR_LOCK_UNLOCK_FAILED
Sequence or password error has been detected in unlock command or if there was an attempt to access a locked card
◆ SDMMC_ERROR_NONE
No error
◆ SDMMC_ERROR_REQUEST_NOT_APPLICABLE
Error when command request is not applicable
◆ SDMMC_ERROR_RX_OVERRUN
Receive FIFO overrun
◆ SDMMC_ERROR_STREAM_READ_UNDERRUN
The card could not sustain data reading in stream rmode
◆ SDMMC_ERROR_STREAM_WRITE_OVERRUN
The card could not sustain data programming in stream mode
◆ SDMMC_ERROR_TIMEOUT
Timeout error
◆ SDMMC_ERROR_TX_UNDERRUN
Transmit FIFO underrun
◆ SDMMC_ERROR_UNSUPPORTED_FEATURE
Error when feature is not insupported
◆ SDMMC_ERROR_WP_ERASE_SKIP
Only partial address space was erased
◆ SDMMC_ERROR_WRITE_PROT_VIOLATION
Attempt to program a write protect block
