RTEMS 6.1
SDMMC Configuration Structure definition. More...
#include <stm32h7xx_ll_sdmmc.h>
uint32_t ClockEdge
uint32_t ClockPowerSave
uint32_t BusWide
uint32_t HardwareFlowControl
uint32_t ClockDiv
Field Documentation
◆ BusWide
uint32_t SDMMC_InitTypeDef::BusWide
Specifies the SDMMC bus width. This parameter can be a value of Bus Width
◆ ClockDiv
uint32_t SDMMC_InitTypeDef::ClockDiv
Specifies the clock frequency of the SDMMC controller. This parameter can be a value between Min_Data = 0 and Max_Data = 1023
◆ ClockEdge
uint32_t SDMMC_InitTypeDef::ClockEdge
Specifies the SDMMC_CCK clock transition on which Data and Command change. This parameter can be a value of Clock Edge
◆ ClockPowerSave
uint32_t SDMMC_InitTypeDef::ClockPowerSave
Specifies whether SDMMC Clock output is enabled or disabled when the bus is idle. This parameter can be a value of Clock Power Saving
◆ HardwareFlowControl
uint32_t SDMMC_InitTypeDef::HardwareFlowControl
Specifies whether the SDMMC hardware flow control is enabled or disabled. This parameter can be a value of Hardware Flow Control
