RTEMS 6.1
Secure digital input/output Interface. More...
#include <stm32h723xx.h>
__IO uint32_t POWER
__IO uint32_t CLKCR
__IO uint32_t ARG
__IO uint32_t CMD
__I uint32_t RESPCMD
__I uint32_t RESP1
__I uint32_t RESP2
__I uint32_t RESP3
__I uint32_t RESP4
__IO uint32_t DTIMER
__IO uint32_t DLEN
__IO uint32_t DCTRL
__I uint32_t DCOUNT
__I uint32_t STA
__IO uint32_t ICR
__IO uint32_t MASK
__IO uint32_t ACKTIME
uint32_t RESERVED0 [3]
__IO uint32_t IDMACTRL
__IO uint32_t IDMABSIZE
__IO uint32_t IDMABASE0
__IO uint32_t IDMABASE1
uint32_t RESERVED1 [8]
__IO uint32_t FIFO
uint32_t RESERVED2 [222]
__IO uint32_t IPVR
Field Documentation
◆ ACKTIME
__IO uint32_t SDMMC_TypeDef::ACKTIME
SDMMC Acknowledgement timer register, Address offset: 0x40
◆ ARG
__IO uint32_t SDMMC_TypeDef::ARG
SDMMC argument register, Address offset: 0x08
◆ CLKCR
__IO uint32_t SDMMC_TypeDef::CLKCR
SDMMC clock control register, Address offset: 0x04
◆ CMD
__IO uint32_t SDMMC_TypeDef::CMD
SDMMC command register, Address offset: 0x0C
◆ DCOUNT
__I uint32_t SDMMC_TypeDef::DCOUNT
SDMMC data counter register, Address offset: 0x30
◆ DCTRL
__IO uint32_t SDMMC_TypeDef::DCTRL
SDMMC data control register, Address offset: 0x2C
◆ DLEN
__IO uint32_t SDMMC_TypeDef::DLEN
SDMMC data length register, Address offset: 0x28
◆ DTIMER
__IO uint32_t SDMMC_TypeDef::DTIMER
SDMMC data timer register, Address offset: 0x24
◆ FIFO
__IO uint32_t SDMMC_TypeDef::FIFO
SDMMC data FIFO register, Address offset: 0x80
◆ ICR
__IO uint32_t SDMMC_TypeDef::ICR
SDMMC interrupt clear register, Address offset: 0x38
◆ IDMABASE0
__IO uint32_t SDMMC_TypeDef::IDMABASE0
SDMMC DMA buffer 0 base address register, Address offset: 0x58
◆ IDMABASE1
__IO uint32_t SDMMC_TypeDef::IDMABASE1
SDMMC DMA buffer 1 base address register, Address offset: 0x5C
◆ IDMABSIZE
__IO uint32_t SDMMC_TypeDef::IDMABSIZE
SDMMC DMA buffer size register, Address offset: 0x54
◆ IDMACTRL
__IO uint32_t SDMMC_TypeDef::IDMACTRL
SDMMC DMA control register, Address offset: 0x50
◆ IPVR
__IO uint32_t SDMMC_TypeDef::IPVR
SDMMC data FIFO register, Address offset: 0x3FC
◆ MASK
__IO uint32_t SDMMC_TypeDef::MASK
SDMMC mask register, Address offset: 0x3C
◆ POWER
__IO uint32_t SDMMC_TypeDef::POWER
SDMMC power control register, Address offset: 0x00
◆ RESERVED0
uint32_t SDMMC_TypeDef::RESERVED0
Reserved, 0x44 - 0x4C - 0x4C
◆ RESERVED1
uint32_t SDMMC_TypeDef::RESERVED1
Reserved, 0x60-0x7C
◆ RESERVED2
uint32_t SDMMC_TypeDef::RESERVED2
Reserved, 0x84-0x3F8
◆ RESP1
__I uint32_t SDMMC_TypeDef::RESP1
SDMMC response 1 register, Address offset: 0x14
◆ RESP2
__I uint32_t SDMMC_TypeDef::RESP2
SDMMC response 2 register, Address offset: 0x18
◆ RESP3
__I uint32_t SDMMC_TypeDef::RESP3
SDMMC response 3 register, Address offset: 0x1C
◆ RESP4
__I uint32_t SDMMC_TypeDef::RESP4
SDMMC response 4 register, Address offset: 0x20
◆ RESPCMD
__I uint32_t SDMMC_TypeDef::RESPCMD
SDMMC command response register, Address offset: 0x10
◆ STA
__I uint32_t SDMMC_TypeDef::STA
SDMMC status register, Address offset: 0x34
The documentation for this struct was generated from the following files:
