RTEMS 6.1
SDMMC Command Control structure. More...
#include <stm32h7xx_ll_sdmmc.h>
uint32_t Argument
uint32_t CmdIndex
uint32_t Response
uint32_t WaitForInterrupt
uint32_t CPSM
Field Documentation
◆ Argument
uint32_t SDMMC_CmdInitTypeDef::Argument
Specifies the SDMMC command argument which is sent to a card as part of a command message. If a command contains an argument, it must be loaded into this register before writing the command to the command register.
◆ CmdIndex
uint32_t SDMMC_CmdInitTypeDef::CmdIndex
Specifies the SDMMC command index. It must be Min_Data = 0 and Max_Data = 64
◆ CPSM
uint32_t SDMMC_CmdInitTypeDef::CPSM
Specifies whether SDMMC Command path state machine (CPSM) is enabled or disabled. This parameter can be a value of CPSM State
◆ Response
uint32_t SDMMC_CmdInitTypeDef::Response
Specifies the SDMMC response type. This parameter can be a value of Response Type
◆ WaitForInterrupt
uint32_t SDMMC_CmdInitTypeDef::WaitForInterrupt
Specifies whether SDMMC wait for interrupt request is enabled or disabled. This parameter can be a value of Wait Interrupt
