RTEMS 6.1
SD Error status enumeration Structure definition
#define HAL_SD_ERROR_NONE   SDMMC_ERROR_NONE
#define HAL_SD_ERROR_CMD_CRC_FAIL   SDMMC_ERROR_CMD_CRC_FAIL
#define HAL_SD_ERROR_DATA_CRC_FAIL   SDMMC_ERROR_DATA_CRC_FAIL
#define HAL_SD_ERROR_CMD_RSP_TIMEOUT   SDMMC_ERROR_CMD_RSP_TIMEOUT
#define HAL_SD_ERROR_DATA_TIMEOUT   SDMMC_ERROR_DATA_TIMEOUT
#define HAL_SD_ERROR_TX_UNDERRUN   SDMMC_ERROR_TX_UNDERRUN
#define HAL_SD_ERROR_RX_OVERRUN   SDMMC_ERROR_RX_OVERRUN
#define HAL_SD_ERROR_ADDR_MISALIGNED   SDMMC_ERROR_ADDR_MISALIGNED
#define HAL_SD_ERROR_BLOCK_LEN_ERR   SDMMC_ERROR_BLOCK_LEN_ERR
#define HAL_SD_ERROR_ERASE_SEQ_ERR   SDMMC_ERROR_ERASE_SEQ_ERR
#define HAL_SD_ERROR_BAD_ERASE_PARAM   SDMMC_ERROR_BAD_ERASE_PARAM
#define HAL_SD_ERROR_WRITE_PROT_VIOLATION   SDMMC_ERROR_WRITE_PROT_VIOLATION
#define HAL_SD_ERROR_LOCK_UNLOCK_FAILED   SDMMC_ERROR_LOCK_UNLOCK_FAILED
#define HAL_SD_ERROR_COM_CRC_FAILED   SDMMC_ERROR_COM_CRC_FAILED
#define HAL_SD_ERROR_ILLEGAL_CMD   SDMMC_ERROR_ILLEGAL_CMD
#define HAL_SD_ERROR_CARD_ECC_FAILED   SDMMC_ERROR_CARD_ECC_FAILED
#define HAL_SD_ERROR_CC_ERR   SDMMC_ERROR_CC_ERR
#define HAL_SD_ERROR_GENERAL_UNKNOWN_ERR   SDMMC_ERROR_GENERAL_UNKNOWN_ERR
#define HAL_SD_ERROR_STREAM_READ_UNDERRUN   SDMMC_ERROR_STREAM_READ_UNDERRUN
#define HAL_SD_ERROR_STREAM_WRITE_OVERRUN   SDMMC_ERROR_STREAM_WRITE_OVERRUN
#define HAL_SD_ERROR_CID_CSD_OVERWRITE   SDMMC_ERROR_CID_CSD_OVERWRITE
#define HAL_SD_ERROR_WP_ERASE_SKIP   SDMMC_ERROR_WP_ERASE_SKIP
#define HAL_SD_ERROR_CARD_ECC_DISABLED   SDMMC_ERROR_CARD_ECC_DISABLED
#define HAL_SD_ERROR_ERASE_RESET   SDMMC_ERROR_ERASE_RESET
#define HAL_SD_ERROR_AKE_SEQ_ERR   SDMMC_ERROR_AKE_SEQ_ERR
#define HAL_SD_ERROR_INVALID_VOLTRANGE   SDMMC_ERROR_INVALID_VOLTRANGE
#define HAL_SD_ERROR_ADDR_OUT_OF_RANGE   SDMMC_ERROR_ADDR_OUT_OF_RANGE
#define HAL_SD_ERROR_REQUEST_NOT_APPLICABLE   SDMMC_ERROR_REQUEST_NOT_APPLICABLE
#define HAL_SD_ERROR_PARAM   SDMMC_ERROR_INVALID_PARAMETER
#define HAL_SD_ERROR_UNSUPPORTED_FEATURE   SDMMC_ERROR_UNSUPPORTED_FEATURE
#define HAL_SD_ERROR_BUSY   SDMMC_ERROR_BUSY
#define HAL_SD_ERROR_DMA   SDMMC_ERROR_DMA
#define HAL_SD_ERROR_TIMEOUT   SDMMC_ERROR_TIMEOUT
◆ HAL_SD_ERROR_ADDR_MISALIGNED
Misaligned address
◆ HAL_SD_ERROR_ADDR_OUT_OF_RANGE
Error when addressed block is out of range
◆ HAL_SD_ERROR_AKE_SEQ_ERR
Error in sequence of authentication
◆ HAL_SD_ERROR_BAD_ERASE_PARAM
An invalid selection for erase groups
◆ HAL_SD_ERROR_BLOCK_LEN_ERR
Transferred block length is not allowed for the card or the
number of transferred bytes does not match the block length
◆ HAL_SD_ERROR_BUSY
Error when transfer process is busy
◆ HAL_SD_ERROR_CARD_ECC_DISABLED
Command has been executed without using internal ECC
◆ HAL_SD_ERROR_CARD_ECC_FAILED
Card internal ECC was applied but failed to correct the data
◆ HAL_SD_ERROR_CC_ERR
Internal card controller error
◆ HAL_SD_ERROR_CID_CSD_OVERWRITE
CID/CSD overwrite error
◆ HAL_SD_ERROR_CMD_CRC_FAIL
Command response received (but CRC check failed)
◆ HAL_SD_ERROR_CMD_RSP_TIMEOUT
Command response timeout
◆ HAL_SD_ERROR_COM_CRC_FAILED
CRC check of the previous command failed
◆ HAL_SD_ERROR_DATA_CRC_FAIL
Data block sent/received (CRC check failed)
◆ HAL_SD_ERROR_DATA_TIMEOUT
Data timeout
◆ HAL_SD_ERROR_DMA
Error while DMA transfer
◆ HAL_SD_ERROR_ERASE_RESET
Erase sequence was cleared before executing because an out
of erase sequence command was received
◆ HAL_SD_ERROR_ERASE_SEQ_ERR
An error in the sequence of erase command occurs
◆ HAL_SD_ERROR_GENERAL_UNKNOWN_ERR
General or unknown error
◆ HAL_SD_ERROR_ILLEGAL_CMD
Command is not legal for the card state
◆ HAL_SD_ERROR_INVALID_VOLTRANGE
Error in case of invalid voltage range
◆ HAL_SD_ERROR_LOCK_UNLOCK_FAILED
Sequence or password error has been detected in unlock
command or if there was an attempt to access a locked card
◆ HAL_SD_ERROR_NONE
No error
◆ HAL_SD_ERROR_PARAM
the used parameter is not valid
◆ HAL_SD_ERROR_REQUEST_NOT_APPLICABLE
Error when command request is not applicable
◆ HAL_SD_ERROR_RX_OVERRUN
Receive FIFO overrun
◆ HAL_SD_ERROR_STREAM_READ_UNDERRUN
The card could not sustain data reading in stream rmode
◆ HAL_SD_ERROR_STREAM_WRITE_OVERRUN
The card could not sustain data programming in stream mode
◆ HAL_SD_ERROR_TIMEOUT
Timeout error
◆ HAL_SD_ERROR_TX_UNDERRUN
Transmit FIFO underrun
◆ HAL_SD_ERROR_UNSUPPORTED_FEATURE
Error when feature is not insupported
◆ HAL_SD_ERROR_WP_ERASE_SKIP
Only partial address space was erased
◆ HAL_SD_ERROR_WRITE_PROT_VIOLATION
Attempt to program a write protect block
