RTEMS 6.1
| struct | TIM_Base_InitTypeDef |
| TIM Time base Configuration Structure definition. More... | |
| struct | TIM_OC_InitTypeDef |
| TIM Output Compare Configuration Structure definition. More... | |
| struct | TIM_OnePulse_InitTypeDef |
| TIM One Pulse Mode Configuration Structure definition. More... | |
| struct | TIM_IC_InitTypeDef |
| TIM Input Capture Configuration Structure definition. More... | |
| struct | TIM_Encoder_InitTypeDef |
| TIM Encoder Configuration Structure definition. More... | |
| struct | TIM_ClockConfigTypeDef |
| Clock Configuration Handle Structure definition. More... | |
| struct | TIM_ClearInputConfigTypeDef |
| TIM Clear Input Configuration Handle Structure definition. More... | |
| struct | TIM_MasterConfigTypeDef |
| TIM Master configuration Structure definition. More... | |
| struct | TIM_SlaveConfigTypeDef |
| TIM Slave configuration Structure definition. More... | |
| struct | TIM_BreakDeadTimeConfigTypeDef |
| TIM Break input(s) and Dead time configuration Structure definition. More... | |
| struct | TIM_HandleTypeDef |
| TIM Time Base Handle Structure definition. More... | |
Enumerations | |
| enum | HAL_TIM_StateTypeDef { HAL_TIM_STATE_RESET = 0x00U , HAL_TIM_STATE_READY = 0x01U , HAL_TIM_STATE_BUSY = 0x02U , HAL_TIM_STATE_TIMEOUT = 0x03U , HAL_TIM_STATE_ERROR = 0x04U } |
| HAL State structures definition. More... | |
| enum | HAL_TIM_ChannelStateTypeDef { HAL_TIM_CHANNEL_STATE_RESET = 0x00U , HAL_TIM_CHANNEL_STATE_READY = 0x01U , HAL_TIM_CHANNEL_STATE_BUSY = 0x02U } |
| TIM Channel States definition. More... | |
| enum | HAL_TIM_DMABurstStateTypeDef { HAL_DMA_BURST_STATE_RESET = 0x00U , HAL_DMA_BURST_STATE_READY = 0x01U , HAL_DMA_BURST_STATE_BUSY = 0x02U } |
| DMA Burst States definition. More... | |
| enum | HAL_TIM_ActiveChannel { HAL_TIM_ACTIVE_CHANNEL_1 = 0x01U , HAL_TIM_ACTIVE_CHANNEL_2 = 0x02U , HAL_TIM_ACTIVE_CHANNEL_3 = 0x04U , HAL_TIM_ACTIVE_CHANNEL_4 = 0x08U , HAL_TIM_ACTIVE_CHANNEL_5 = 0x10U , HAL_TIM_ACTIVE_CHANNEL_6 = 0x20U , HAL_TIM_ACTIVE_CHANNEL_CLEARED = 0x00U } |
| HAL Active channel structures definition. More... | |
| enum HAL_TIM_StateTypeDef |
