RTEMS 6.1
TIM Clear Input Configuration Handle Structure definition. More...
#include <stm32h7xx_hal_tim.h>
Data Fields | |
| uint32_t | ClearInputState |
| uint32_t | ClearInputSource |
| uint32_t | ClearInputPolarity |
| uint32_t | ClearInputPrescaler |
| uint32_t | ClearInputFilter |
| uint32_t TIM_ClearInputConfigTypeDef::ClearInputFilter |
TIM Clear Input filter This parameter can be a number between Min_Data = 0x0 and Max_Data = 0xF
| uint32_t TIM_ClearInputConfigTypeDef::ClearInputPolarity |
TIM Clear Input polarity This parameter can be a value of TIM Clear Input Polarity
| uint32_t TIM_ClearInputConfigTypeDef::ClearInputPrescaler |
TIM Clear Input prescaler This parameter must be 0: When OCRef clear feature is used with ETR source, ETR prescaler must be off
| uint32_t TIM_ClearInputConfigTypeDef::ClearInputSource |
TIM clear Input sources This parameter can be a value of TIM Clear Input Source
| uint32_t TIM_ClearInputConfigTypeDef::ClearInputState |
TIM clear Input state This parameter can be ENABLE or DISABLE
