RTEMS 6.1
TIM_IC_InitTypeDef Struct Reference
TIM Input Capture Configuration Structure definition. More...
#include <stm32h7xx_hal_tim.h>
uint32_t ICPolarity
uint32_t ICSelection
uint32_t ICPrescaler
uint32_t ICFilter
Field Documentation
◆ ICFilter
uint32_t TIM_IC_InitTypeDef::ICFilter
Specifies the input capture filter. This parameter can be a number between Min_Data = 0x0 and Max_Data = 0xF
◆ ICPolarity
uint32_t TIM_IC_InitTypeDef::ICPolarity
Specifies the active edge of the input signal. This parameter can be a value of TIM Input Capture Polarity
◆ ICPrescaler
uint32_t TIM_IC_InitTypeDef::ICPrescaler
Specifies the Input Capture Prescaler. This parameter can be a value of TIM Input Capture Prescaler
◆ ICSelection
uint32_t TIM_IC_InitTypeDef::ICSelection
Specifies the input. This parameter can be a value of TIM Input Capture Selection
