RTEMS 6.1
TIM Time base Configuration Structure definition. More...
#include <stm32h7xx_hal_tim.h>
Data Fields | |
| uint32_t | Prescaler |
| uint32_t | CounterMode |
| uint32_t | Period |
| uint32_t | ClockDivision |
| uint32_t | RepetitionCounter |
| uint32_t | AutoReloadPreload |
| uint32_t TIM_Base_InitTypeDef::AutoReloadPreload |
Specifies the auto-reload preload. This parameter can be a value of TIM Auto-Reload Preload
| uint32_t TIM_Base_InitTypeDef::ClockDivision |
Specifies the clock division. This parameter can be a value of TIM Clock Division
| uint32_t TIM_Base_InitTypeDef::CounterMode |
Specifies the counter mode. This parameter can be a value of TIM Counter Mode
| uint32_t TIM_Base_InitTypeDef::Period |
Specifies the period value to be loaded into the active Auto-Reload Register at the next update event. This parameter can be a number between Min_Data = 0x0000 and Max_Data = 0xFFFF.
| uint32_t TIM_Base_InitTypeDef::Prescaler |
Specifies the prescaler value used to divide the TIM clock. This parameter can be a number between Min_Data = 0x0000 and Max_Data = 0xFFFF
| uint32_t TIM_Base_InitTypeDef::RepetitionCounter |
Specifies the repetition counter value. Each time the RCR downcounter reaches zero, an update event is generated and counting restarts from the RCR value (N). This means in PWM mode that (N+1) corresponds to:
