RTEMS 6.1
TIM_OnePulse_InitTypeDef Struct Reference
TIM One Pulse Mode Configuration Structure definition. More...
#include <stm32h7xx_hal_tim.h>
uint32_t OCMode
uint32_t Pulse
uint32_t OCPolarity
uint32_t OCNPolarity
uint32_t OCIdleState
uint32_t OCNIdleState
uint32_t ICPolarity
uint32_t ICSelection
uint32_t ICFilter
Field Documentation
◆ ICFilter
uint32_t TIM_OnePulse_InitTypeDef::ICFilter
Specifies the input capture filter. This parameter can be a number between Min_Data = 0x0 and Max_Data = 0xF
◆ ICPolarity
uint32_t TIM_OnePulse_InitTypeDef::ICPolarity
Specifies the active edge of the input signal. This parameter can be a value of TIM Input Capture Polarity
◆ ICSelection
uint32_t TIM_OnePulse_InitTypeDef::ICSelection
Specifies the input. This parameter can be a value of TIM Input Capture Selection
◆ OCIdleState
uint32_t TIM_OnePulse_InitTypeDef::OCIdleState
Specifies the TIM Output Compare pin state during Idle state. This parameter can be a value of TIM Output Compare Idle State
Note
This parameter is valid only for timer instances supporting break feature.
◆ OCMode
uint32_t TIM_OnePulse_InitTypeDef::OCMode
Specifies the TIM mode. This parameter can be a value of TIM Output Compare and PWM Modes
◆ OCNIdleState
uint32_t TIM_OnePulse_InitTypeDef::OCNIdleState
Specifies the TIM Output Compare pin state during Idle state. This parameter can be a value of TIM Complementary Output Compare Idle State
Note
◆ OCNPolarity
uint32_t TIM_OnePulse_InitTypeDef::OCNPolarity
Specifies the complementary output polarity. This parameter can be a value of TIM Complementary Output Compare Polarity
Note
◆ OCPolarity
uint32_t TIM_OnePulse_InitTypeDef::OCPolarity
Specifies the output polarity. This parameter can be a value of TIM Output Compare Polarity
◆ Pulse
uint32_t TIM_OnePulse_InitTypeDef::Pulse
Specifies the pulse value to be loaded into the Capture Compare Register. This parameter can be a number between Min_Data = 0x0000 and Max_Data = 0xFFFF
