RTEMS 6.1
TIM_Encoder_InitTypeDef Struct Reference
TIM Encoder Configuration Structure definition. More...
#include <stm32h7xx_hal_tim.h>
uint32_t EncoderMode
uint32_t IC1Polarity
uint32_t IC1Selection
uint32_t IC1Prescaler
uint32_t IC1Filter
uint32_t IC2Polarity
uint32_t IC2Selection
uint32_t IC2Prescaler
uint32_t IC2Filter
Field Documentation
◆ EncoderMode
uint32_t TIM_Encoder_InitTypeDef::EncoderMode
Specifies the active edge of the input signal. This parameter can be a value of TIM Encoder Mode
◆ IC1Filter
uint32_t TIM_Encoder_InitTypeDef::IC1Filter
Specifies the input capture filter. This parameter can be a number between Min_Data = 0x0 and Max_Data = 0xF
◆ IC1Polarity
uint32_t TIM_Encoder_InitTypeDef::IC1Polarity
Specifies the active edge of the input signal. This parameter can be a value of TIM Encoder Input Polarity
◆ IC1Prescaler
uint32_t TIM_Encoder_InitTypeDef::IC1Prescaler
Specifies the Input Capture Prescaler. This parameter can be a value of TIM Input Capture Prescaler
◆ IC1Selection
uint32_t TIM_Encoder_InitTypeDef::IC1Selection
Specifies the input. This parameter can be a value of TIM Input Capture Selection
◆ IC2Filter
uint32_t TIM_Encoder_InitTypeDef::IC2Filter
◆ IC2Polarity
uint32_t TIM_Encoder_InitTypeDef::IC2Polarity
◆ IC2Prescaler
uint32_t TIM_Encoder_InitTypeDef::IC2Prescaler
◆ IC2Selection
uint32_t TIM_Encoder_InitTypeDef::IC2Selection
