RTEMS 6.1
TIM Output Compare Configuration Structure definition. More...
#include <stm32h7xx_hal_tim.h>
Data Fields | |
| uint32_t | OCMode |
| uint32_t | Pulse |
| uint32_t | OCPolarity |
| uint32_t | OCNPolarity |
| uint32_t | OCFastMode |
| uint32_t | OCIdleState |
| uint32_t | OCNIdleState |
| uint32_t TIM_OC_InitTypeDef::OCFastMode |
Specifies the Fast mode state. This parameter can be a value of TIM Output Fast State
| uint32_t TIM_OC_InitTypeDef::OCIdleState |
Specifies the TIM Output Compare pin state during Idle state. This parameter can be a value of TIM Output Compare Idle State
| uint32_t TIM_OC_InitTypeDef::OCMode |
Specifies the TIM mode. This parameter can be a value of TIM Output Compare and PWM Modes
| uint32_t TIM_OC_InitTypeDef::OCNIdleState |
Specifies the TIM Output Compare pin state during Idle state. This parameter can be a value of TIM Complementary Output Compare Idle State
| uint32_t TIM_OC_InitTypeDef::OCNPolarity |
Specifies the complementary output polarity. This parameter can be a value of TIM Complementary Output Compare Polarity
| uint32_t TIM_OC_InitTypeDef::OCPolarity |
Specifies the output polarity. This parameter can be a value of TIM Output Compare Polarity
| uint32_t TIM_OC_InitTypeDef::Pulse |
Specifies the pulse value to be loaded into the Capture Compare Register. This parameter can be a number between Min_Data = 0x0000 and Max_Data = 0xFFFF
