RTEMS 5.2
smplock.h
1
9/*
10 * COPYRIGHT (c) 1989-2011.
11 * On-Line Applications Research Corporation (OAR).
12 *
13 * Copyright (c) 2013, 2016 embedded brains GmbH
14 *
15 * The license and distribution terms for this file may be
16 * found in the file LICENSE in this distribution or at
17 * http://www.rtems.org/license/LICENSE.
18 */
19
20#ifndef _RTEMS_SCORE_SMPLOCK_H
21#define _RTEMS_SCORE_SMPLOCK_H
22
23#include <rtems/score/cpuopts.h>
24
43#if defined(RTEMS_SMP)
44
48
49#if defined(RTEMS_DEBUG)
50#include <rtems/score/assert.h>
51#include <rtems/score/smp.h>
52#endif
53
54#ifdef __cplusplus
55extern "C" {
56#endif /* __cplusplus */
57
58#if defined(RTEMS_DEBUG) || defined(RTEMS_PROFILING)
59#define RTEMS_SMP_LOCK_DO_NOT_INLINE
60#endif
61
65typedef struct {
66 SMP_ticket_lock_Control Ticket_lock;
67#if defined(RTEMS_DEBUG)
80 uint32_t owner;
81#endif
82#if defined(RTEMS_PROFILING)
83 SMP_lock_Stats Stats;
84#endif
85} SMP_lock_Control;
86
90typedef struct {
91 ISR_Level isr_level;
92#if defined(RTEMS_DEBUG)
93 SMP_lock_Control *lock_used_for_acquire;
94#endif
95#if defined(RTEMS_PROFILING)
96 SMP_lock_Stats_context Stats_context;
97#endif
98} SMP_lock_Context;
99
100#if defined(RTEMS_DEBUG)
101#define SMP_LOCK_NO_OWNER 0
102#endif
103
107#if defined(RTEMS_DEBUG) && defined(RTEMS_PROFILING)
108 #define SMP_LOCK_INITIALIZER( name ) \
109 { \
110 SMP_TICKET_LOCK_INITIALIZER, \
111 SMP_LOCK_NO_OWNER, \
112 SMP_LOCK_STATS_INITIALIZER( name ) \
113 }
114#elif defined(RTEMS_DEBUG)
115 #define SMP_LOCK_INITIALIZER( name ) \
116 { SMP_TICKET_LOCK_INITIALIZER, SMP_LOCK_NO_OWNER }
117#elif defined(RTEMS_PROFILING)
118 #define SMP_LOCK_INITIALIZER( name ) \
119 { SMP_TICKET_LOCK_INITIALIZER, SMP_LOCK_STATS_INITIALIZER( name ) }
120#else
121 #define SMP_LOCK_INITIALIZER( name ) { SMP_TICKET_LOCK_INITIALIZER }
122#endif
123
129static inline void _SMP_lock_Initialize_inline(
130 SMP_lock_Control *lock,
131 const char *name
132)
133{
134 _SMP_ticket_lock_Initialize( &lock->Ticket_lock );
135#if defined(RTEMS_DEBUG)
136 lock->owner = SMP_LOCK_NO_OWNER;
137#endif
138#if defined(RTEMS_PROFILING)
139 _SMP_lock_Stats_initialize( &lock->Stats, name );
140#else
141 (void) name;
142#endif
143}
144
154#if defined(RTEMS_SMP_LOCK_DO_NOT_INLINE)
155void _SMP_lock_Initialize(
156 SMP_lock_Control *lock,
157 const char *name
158);
159#else
160#define _SMP_lock_Initialize( lock, name ) \
161 _SMP_lock_Initialize_inline( lock, name )
162#endif
163
169static inline void _SMP_lock_Destroy_inline( SMP_lock_Control *lock )
170{
171 _SMP_ticket_lock_Destroy( &lock->Ticket_lock );
172 _SMP_lock_Stats_destroy( &lock->Stats );
173}
174
182#if defined(RTEMS_SMP_LOCK_DO_NOT_INLINE)
183void _SMP_lock_Destroy( SMP_lock_Control *lock );
184#else
185#define _SMP_lock_Destroy( lock ) \
186 _SMP_lock_Destroy_inline( lock )
187#endif
188
196static inline void _SMP_lock_Set_name(
197 SMP_lock_Control *lock,
198 const char *name
199)
200{
201#if defined(RTEMS_PROFILING)
202 lock->Stats.name = name;
203#else
204 (void) name;
205#endif
206}
207
213#if defined(RTEMS_DEBUG)
214static inline uint32_t _SMP_lock_Who_am_I( void )
215{
216 /*
217 * The CPU index starts with zero. Increment it by one, to allow global SMP
218 * locks to reside in the BSS section.
219 */
220 return _SMP_Get_current_processor() + 1;
221}
222#endif
223
230static inline void _SMP_lock_Acquire_inline(
231 SMP_lock_Control *lock,
232 SMP_lock_Context *context
233)
234{
235#if defined(RTEMS_DEBUG)
236 context->lock_used_for_acquire = lock;
237#else
238 (void) context;
239#endif
240 _SMP_ticket_lock_Acquire(
241 &lock->Ticket_lock,
242 &lock->Stats,
243 &context->Stats_context
244 );
245#if defined(RTEMS_DEBUG)
246 lock->owner = _SMP_lock_Who_am_I();
247#endif
248}
249
261void _SMP_lock_Acquire(
262 SMP_lock_Control *lock,
263 SMP_lock_Context *context
264);
265
272static inline void _SMP_lock_Release_inline(
273 SMP_lock_Control *lock,
274 SMP_lock_Context *context
275)
276{
277#if defined(RTEMS_DEBUG)
278 _Assert( context->lock_used_for_acquire == lock );
279 context->lock_used_for_acquire = NULL;
280 _Assert( lock->owner == _SMP_lock_Who_am_I() );
281 lock->owner = SMP_LOCK_NO_OWNER;
282#else
283 (void) context;
284#endif
285 _SMP_ticket_lock_Release(
286 &lock->Ticket_lock,
287 &context->Stats_context
288 );
289}
290
298#if defined(RTEMS_SMP_LOCK_DO_NOT_INLINE)
299void _SMP_lock_Release(
300 SMP_lock_Control *lock,
301 SMP_lock_Context *context
302);
303#else
304#define _SMP_lock_Release( lock, context ) \
305 _SMP_lock_Release_inline( lock, context )
306#endif
307
314static inline void _SMP_lock_ISR_disable_and_acquire_inline(
315 SMP_lock_Control *lock,
316 SMP_lock_Context *context
317)
318{
319 _ISR_Local_disable( context->isr_level );
320 _SMP_lock_Acquire_inline( lock, context );
321}
322
330void _SMP_lock_ISR_disable_and_acquire(
331 SMP_lock_Control *lock,
332 SMP_lock_Context *context
333);
334
341static inline void _SMP_lock_Release_and_ISR_enable_inline(
342 SMP_lock_Control *lock,
343 SMP_lock_Context *context
344)
345{
346 _SMP_lock_Release_inline( lock, context );
347 _ISR_Local_enable( context->isr_level );
348}
349
357#if defined(RTEMS_SMP_LOCK_DO_NOT_INLINE)
358void _SMP_lock_Release_and_ISR_enable(
359 SMP_lock_Control *lock,
360 SMP_lock_Context *context
361);
362#else
363#define _SMP_lock_Release_and_ISR_enable( lock, context ) \
364 _SMP_lock_Release_and_ISR_enable_inline( lock, context )
365#endif
366
367#if defined(RTEMS_DEBUG)
376bool _SMP_lock_Is_owner( const SMP_lock_Control *lock );
377#endif
378
381#ifdef __cplusplus
382}
383#endif /* __cplusplus */
384
385#endif /* RTEMS_SMP */
386
387#endif /* _RTEMS_SCORE_SMPLOCK_H */
Information for the Assert Handler.
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
#define _Assert(_e)
Assertion similar to assert() controlled via RTEMS_DEBUG instead of NDEBUG.
Definition: assert.h:100
#define _ISR_Local_disable(_level)
Disables interrupts on this processor.
Definition: isrlevel.h:57
#define _ISR_Local_enable(_level)
Enables interrupts on this processor.
Definition: isrlevel.h:74
uint32_t ISR_Level
Definition: isrlevel.h:41
ISR Level Type.
SuperCore SMP Support API.
SMP Lock API.
SMP Lock API.
unsigned context
Definition: tlb.h:1
