RTEMS 5.2
record.h
2
3/*
4 * Copyright (C) 2018, 2020 embedded brains GmbH (http://www.embedded-brains.de)
5 *
6 * Redistribution and use in source and binary forms, with or without
7 * modification, are permitted provided that the following conditions
8 * are met:
9 * 1. Redistributions of source code must retain the above copyright
10 * notice, this list of conditions and the following disclaimer.
11 * 2. Redistributions in binary form must reproduce the above copyright
12 * notice, this list of conditions and the following disclaimer in the
13 * documentation and/or other materials provided with the distribution.
14 *
15 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
16 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25 * POSSIBILITY OF SUCH DAMAGE.
26 */
27
28#ifndef _RTEMS_RECORD_H
29#define _RTEMS_RECORD_H
30
31#include "recorddata.h"
32
33#include <rtems/score/atomic.h>
34#include <rtems/score/cpu.h>
35#include <rtems/score/interr.h>
36#include <rtems/score/percpu.h>
38#include <rtems/counter.h>
39
40#ifdef __cplusplus
41extern "C" {
42#endif /* __cplusplus */
43
44typedef struct Record_Control {
45 Atomic_Uint head;
46 unsigned int tail;
47 unsigned int mask;
48 Watchdog_Control Watchdog;
49 rtems_record_item Header[ 3 ];
51 rtems_record_item Items[ RTEMS_ZERO_LENGTH_ARRAY ];
53
54typedef struct {
55 unsigned int item_count;
56 Record_Control *controls;
58
59typedef struct {
61 unsigned int head;
62 uint32_t now;
63 uint32_t level;
65
66extern const Record_Configuration _Record_Configuration;
67
68void _Record_Initialize( void );
69
70bool _Record_Thread_create(
71 struct _Thread_Control *executing,
72 struct _Thread_Control *created
73);
74
75void _Record_Thread_start(
76 struct _Thread_Control *executing,
77 struct _Thread_Control *started
78);
79
80void _Record_Thread_restart(
81 struct _Thread_Control *executing,
82 struct _Thread_Control *restarted
83);
84
85void _Record_Thread_delete(
86 struct _Thread_Control *executing,
87 struct _Thread_Control *deleted
88);
89
90void _Record_Thread_switch(
91 struct _Thread_Control *executing,
92 struct _Thread_Control *heir
93);
94
95void _Record_Thread_begin( struct _Thread_Control *executing );
96
97void _Record_Thread_exitted( struct _Thread_Control *executing );
98
99void _Record_Fatal_dump_base64(
101 bool always_set_to_false,
102 Internal_errors_t code
103);
104
105void _Record_Fatal_dump_base64_zlib(
107 bool always_set_to_false,
108 Internal_errors_t code
109);
110
111void _Record_Thread_terminate(
112 struct _Thread_Control *executing
113);
114
115RTEMS_INLINE_ROUTINE unsigned int _Record_Index(
116 const Record_Control *control,
117 unsigned int index
118)
119{
120 return index & control->mask;
121}
122
123RTEMS_INLINE_ROUTINE unsigned int _Record_Head( const Record_Control *control )
124{
125 return _Atomic_Load_uint( &control->head, ATOMIC_ORDER_RELAXED );
126}
127
128RTEMS_INLINE_ROUTINE unsigned int _Record_Tail( const Record_Control *control )
129{
130 return control->tail;
131}
132
133RTEMS_INLINE_ROUTINE bool _Record_Is_overflow(
134 const Record_Control *control,
135 unsigned int tail,
136 unsigned int head
137)
138{
139 return head - tail >= control->mask + 1U;
140}
141
142RTEMS_INLINE_ROUTINE unsigned int _Record_Capacity(
143 const Record_Control *control,
144 unsigned int tail,
145 unsigned int head
146)
147{
148 return ( tail - head - 1U ) & control->mask;
149}
150
152{
153 return rtems_counter_read();
154}
155
156typedef struct RTEMS_PACKED {
157 uint32_t format;
158 uint32_t magic;
159 rtems_record_item Version;
160 rtems_record_item Processor_maximum;
161 rtems_record_item Count;
162 rtems_record_item Frequency;
163 rtems_record_item Info[64];
165
166size_t _Record_Stream_header_initialize( Record_Stream_header *header );
167
168size_t _Record_String_to_items(
169 rtems_record_event event,
170 const char *str,
171 size_t len,
172 rtems_record_item *items,
173 size_t item_count
174);
175
176void _Record_Caller( void *return_address );
177
178void _Record_Caller_3(
179 void *return_address,
180 rtems_record_event event,
182);
183
184void _Record_Caller_4(
185 void *return_address,
186 rtems_record_event event_0,
187 rtems_record_data data_0,
188 rtems_record_event event_1,
189 rtems_record_data data_1
190);
191
192void _Record_Caller_arg( void *return_address, rtems_record_data data );
193
194void _Record_Caller_arg_2(
195 void *return_address,
196 rtems_record_data data_0,
197 rtems_record_data data_1
198);
199
200void _Record_Caller_arg_3(
201 void *return_address,
202 rtems_record_data data_0,
203 rtems_record_data data_1,
204 rtems_record_data data_2
205);
206
207void _Record_Caller_arg_4(
208 void *return_address,
209 rtems_record_data data_0,
210 rtems_record_data data_1,
211 rtems_record_data data_2,
212 rtems_record_data data_3
213);
214
215void _Record_Caller_arg_5(
216 void *return_address,
217 rtems_record_data data_0,
218 rtems_record_data data_1,
219 rtems_record_data data_2,
220 rtems_record_data data_3,
221 rtems_record_data data_4
222);
223
224void _Record_Caller_arg_6(
225 void *return_address,
226 rtems_record_data data_0,
227 rtems_record_data data_1,
228 rtems_record_data data_2,
229 rtems_record_data data_3,
230 rtems_record_data data_4,
231 rtems_record_data data_5
232);
233
234void _Record_Caller_arg_7(
235 void *return_address,
236 rtems_record_data data_0,
237 rtems_record_data data_1,
238 rtems_record_data data_2,
239 rtems_record_data data_3,
240 rtems_record_data data_4,
241 rtems_record_data data_5,
242 rtems_record_data data_6
243);
244
245void _Record_Caller_arg_8(
246 void *return_address,
247 rtems_record_data data_0,
248 rtems_record_data data_1,
249 rtems_record_data data_2,
250 rtems_record_data data_3,
251 rtems_record_data data_4,
252 rtems_record_data data_5,
253 rtems_record_data data_6,
254 rtems_record_data data_7
255);
256
257void _Record_Caller_arg_9(
258 void *return_address,
259 rtems_record_data data_0,
260 rtems_record_data data_1,
261 rtems_record_data data_2,
262 rtems_record_data data_3,
263 rtems_record_data data_4,
264 rtems_record_data data_5,
265 rtems_record_data data_6,
266 rtems_record_data data_7,
267 rtems_record_data data_8
268);
269
270void _Record_Caller_arg_10(
271 void *return_address,
272 rtems_record_data data_0,
273 rtems_record_data data_1,
274 rtems_record_data data_2,
275 rtems_record_data data_3,
276 rtems_record_data data_4,
277 rtems_record_data data_5,
278 rtems_record_data data_6,
279 rtems_record_data data_7,
280 rtems_record_data data_8,
281 rtems_record_data data_9
282);
283
284void _Record_Entry_2(
285 void *return_address,
286 rtems_record_event event,
287 rtems_record_data data_0,
288 rtems_record_data data_1
289);
290
291void _Record_Entry_3(
292 void *return_address,
293 rtems_record_event event,
294 rtems_record_data data_0,
295 rtems_record_data data_1,
296 rtems_record_data data_2
297);
298
299void _Record_Entry_4(
300 void *return_address,
301 rtems_record_event event,
302 rtems_record_data data_0,
303 rtems_record_data data_1,
304 rtems_record_data data_2,
305 rtems_record_data data_3
306);
307
308void _Record_Entry_5(
309 void *return_address,
310 rtems_record_event event,
311 rtems_record_data data_0,
312 rtems_record_data data_1,
313 rtems_record_data data_2,
314 rtems_record_data data_3,
315 rtems_record_data data_4
316);
317
318void _Record_Entry_6(
319 void *return_address,
320 rtems_record_event event,
321 rtems_record_data data_0,
322 rtems_record_data data_1,
323 rtems_record_data data_2,
324 rtems_record_data data_3,
325 rtems_record_data data_4,
326 rtems_record_data data_5
327);
328
329void _Record_Entry_7(
330 void *return_address,
331 rtems_record_event event,
332 rtems_record_data data_0,
333 rtems_record_data data_1,
334 rtems_record_data data_2,
335 rtems_record_data data_3,
336 rtems_record_data data_4,
337 rtems_record_data data_5,
338 rtems_record_data data_6
339);
340
341void _Record_Entry_8(
342 void *return_address,
343 rtems_record_event event,
344 rtems_record_data data_0,
345 rtems_record_data data_1,
346 rtems_record_data data_2,
347 rtems_record_data data_3,
348 rtems_record_data data_4,
349 rtems_record_data data_5,
350 rtems_record_data data_6,
351 rtems_record_data data_7
352);
353
354void _Record_Entry_9(
355 void *return_address,
356 rtems_record_event event,
357 rtems_record_data data_0,
358 rtems_record_data data_1,
359 rtems_record_data data_2,
360 rtems_record_data data_3,
361 rtems_record_data data_4,
362 rtems_record_data data_5,
363 rtems_record_data data_6,
364 rtems_record_data data_7,
365 rtems_record_data data_8
366);
367
368void _Record_Entry_10(
369 void *return_address,
370 rtems_record_event event,
371 rtems_record_data data_0,
372 rtems_record_data data_1,
373 rtems_record_data data_2,
374 rtems_record_data data_3,
375 rtems_record_data data_4,
376 rtems_record_data data_5,
377 rtems_record_data data_6,
378 rtems_record_data data_7,
379 rtems_record_data data_8,
380 rtems_record_data data_9
381);
382
383void _Record_Exit_2(
384 void *return_address,
385 rtems_record_event event,
386 rtems_record_data data_0,
387 rtems_record_data data_1
388);
389
390void _Record_Exit_3(
391 void *return_address,
392 rtems_record_event event,
393 rtems_record_data data_0,
394 rtems_record_data data_1,
395 rtems_record_data data_2
396);
397
398void _Record_Exit_4(
399 void *return_address,
400 rtems_record_event event,
401 rtems_record_data data_0,
402 rtems_record_data data_1,
403 rtems_record_data data_2,
404 rtems_record_data data_3
405);
406
407void _Record_Exit_5(
408 void *return_address,
409 rtems_record_event event,
410 rtems_record_data data_0,
411 rtems_record_data data_1,
412 rtems_record_data data_2,
413 rtems_record_data data_3,
414 rtems_record_data data_4
415);
416
417void _Record_Exit_6(
418 void *return_address,
419 rtems_record_event event,
420 rtems_record_data data_0,
421 rtems_record_data data_1,
422 rtems_record_data data_2,
423 rtems_record_data data_3,
424 rtems_record_data data_4,
425 rtems_record_data data_5
426);
427
428void _Record_Exit_7(
429 void *return_address,
430 rtems_record_event event,
431 rtems_record_data data_0,
432 rtems_record_data data_1,
433 rtems_record_data data_2,
434 rtems_record_data data_3,
435 rtems_record_data data_4,
436 rtems_record_data data_5,
437 rtems_record_data data_6
438);
439
440void _Record_Exit_8(
441 void *return_address,
442 rtems_record_event event,
443 rtems_record_data data_0,
444 rtems_record_data data_1,
445 rtems_record_data data_2,
446 rtems_record_data data_3,
447 rtems_record_data data_4,
448 rtems_record_data data_5,
449 rtems_record_data data_6,
450 rtems_record_data data_7
451);
452
453void _Record_Exit_9(
454 void *return_address,
455 rtems_record_event event,
456 rtems_record_data data_0,
457 rtems_record_data data_1,
458 rtems_record_data data_2,
459 rtems_record_data data_3,
460 rtems_record_data data_4,
461 rtems_record_data data_5,
462 rtems_record_data data_6,
463 rtems_record_data data_7,
464 rtems_record_data data_8
465);
466
467void _Record_Exit_10(
468 void *return_address,
469 rtems_record_event event,
470 rtems_record_data data_0,
471 rtems_record_data data_1,
472 rtems_record_data data_2,
473 rtems_record_data data_3,
474 rtems_record_data data_4,
475 rtems_record_data data_5,
476 rtems_record_data data_6,
477 rtems_record_data data_7,
478 rtems_record_data data_8,
479 rtems_record_data data_9
480);
481
503 const Per_CPU_Control *cpu_self
504)
505{
507 unsigned int head;
508
509 context->now = RTEMS_RECORD_TIME_EVENT( _Record_Now(), 0 );
510 control = cpu_self->record;
511 context->control = control;
512 head = _Record_Head( control );
513 context->head = head;
514}
515
528{
529 uint32_t level;
530 const Per_CPU_Control *cpu_self;
532 unsigned int head;
533
534 _CPU_ISR_Disable( level );
536 context->now = RTEMS_RECORD_TIME_EVENT( _Record_Now(), 0 );
537 context->level = level;
538 cpu_self = _Per_CPU_Get();
539 control = cpu_self->record;
540 context->control = control;
541 head = _Record_Head( control );
542 context->head = head;
543}
544
554 rtems_record_event event,
556)
557{
559 rtems_record_item *item;
560 unsigned int head;
561
562 control = context->control;
563 head = context->head;
564 item = &control->Items[ _Record_Index( control, head ) ];
565 context->head = head + 1;
566
567 item->event = context->now | event;
568 item->data = data;
569}
570
579{
580 _Atomic_Store_uint(
581 &context->control->head,
582 context->head,
583 ATOMIC_ORDER_RELEASE
584 );
585}
586
593{
596 _CPU_ISR_Enable( context->level );
597}
598
606
616 rtems_record_event event_0,
617 rtems_record_data data_0,
618 rtems_record_event event_1,
619 rtems_record_data data_1
620);
621
629 const rtems_record_item *items,
630 size_t n
631);
632
638void rtems_record_line( void );
639
649 rtems_record_event event,
651);
652
664 rtems_record_event event_0,
665 rtems_record_data data_0,
666 rtems_record_event event_1,
667 rtems_record_data data_1
668);
669
679
690 rtems_record_data data_0,
691 rtems_record_data data_1
692);
693
705 rtems_record_data data_0,
706 rtems_record_data data_1,
707 rtems_record_data data_2
708);
709
722 rtems_record_data data_0,
723 rtems_record_data data_1,
724 rtems_record_data data_2,
725 rtems_record_data data_3
726);
727
741 rtems_record_data data_0,
742 rtems_record_data data_1,
743 rtems_record_data data_2,
744 rtems_record_data data_3,
745 rtems_record_data data_4
746);
747
762 rtems_record_data data_0,
763 rtems_record_data data_1,
764 rtems_record_data data_2,
765 rtems_record_data data_3,
766 rtems_record_data data_4,
767 rtems_record_data data_5
768);
769
785 rtems_record_data data_0,
786 rtems_record_data data_1,
787 rtems_record_data data_2,
788 rtems_record_data data_3,
789 rtems_record_data data_4,
790 rtems_record_data data_5,
791 rtems_record_data data_6
792);
793
810 rtems_record_data data_0,
811 rtems_record_data data_1,
812 rtems_record_data data_2,
813 rtems_record_data data_3,
814 rtems_record_data data_4,
815 rtems_record_data data_5,
816 rtems_record_data data_6,
817 rtems_record_data data_7
818);
819
837 rtems_record_data data_0,
838 rtems_record_data data_1,
839 rtems_record_data data_2,
840 rtems_record_data data_3,
841 rtems_record_data data_4,
842 rtems_record_data data_5,
843 rtems_record_data data_6,
844 rtems_record_data data_7,
845 rtems_record_data data_8
846);
847
866 rtems_record_data data_0,
867 rtems_record_data data_1,
868 rtems_record_data data_2,
869 rtems_record_data data_3,
870 rtems_record_data data_4,
871 rtems_record_data data_5,
872 rtems_record_data data_6,
873 rtems_record_data data_7,
874 rtems_record_data data_8,
875 rtems_record_data data_9
876);
877
887#define rtems_record_caller() _Record_Caller( RTEMS_RETURN_ADDRESS() )
888
902#define rtems_record_caller_3( event, data ) \
903 _Record_Caller_3( RTEMS_RETURN_ADDRESS(), event, data )
904
920#define rtems_record_caller_4( event_0, data_0, event_1, data_1 ) \
921 _Record_Caller_4( \
922 RTEMS_RETURN_ADDRESS(), \
923 event_0, \
924 data_0, \
925 event_1, \
926 data_1 \
927 )
928
941#define rtems_record_caller_arg( data ) \
942 _Record_Caller_arg( RTEMS_RETURN_ADDRESS(), data )
943
957#define rtems_record_caller_arg_2( data_0, data_1 ) \
958 _Record_Caller_arg_2( \
959 RTEMS_RETURN_ADDRESS(), \
960 data_0, \
961 data_1 \
962 )
963
978#define rtems_record_caller_arg_3( data_0, data_1, data_2 ) \
979 _Record_Caller_arg_3( \
980 RTEMS_RETURN_ADDRESS(), \
981 data_0, \
982 data_1, \
983 data_2 \
984 )
985
1001#define rtems_record_caller_arg_4( data_0, data_1, data_2, data_3 ) \
1002 _Record_Caller_arg_4( \
1003 RTEMS_RETURN_ADDRESS(), \
1004 data_0, \
1005 data_1, \
1006 data_2, \
1007 data_3 \
1008 )
1009
1026#define rtems_record_caller_arg_5( data_0, data_1, data_2, data_3, data_4 ) \
1027 _Record_Caller_arg_5( \
1028 RTEMS_RETURN_ADDRESS(), \
1029 data_0, \
1030 data_1, \
1031 data_2, \
1032 data_3, \
1033 data_4 \
1034 )
1035
1053#define rtems_record_caller_arg_6( \
1054 data_0, \
1055 data_1, \
1056 data_2, \
1057 data_3, \
1058 data_4, \
1059 data_5 \
1060) \
1061 _Record_Caller_arg_6( \
1062 RTEMS_RETURN_ADDRESS(), \
1063 data_0, \
1064 data_1, \
1065 data_2, \
1066 data_3, \
1067 data_4, \
1068 data_5 \
1069 )
1070
1089#define rtems_record_caller_arg_7( \
1090 data_0, \
1091 data_1, \
1092 data_2, \
1093 data_3, \
1094 data_4, \
1095 data_5, \
1096 data_6 \
1097) \
1098 _Record_Caller_arg_7( \
1099 RTEMS_RETURN_ADDRESS(), \
1100 data_0, \
1101 data_1, \
1102 data_2, \
1103 data_3, \
1104 data_4, \
1105 data_5, \
1106 data_6 \
1107 )
1108
1128#define rtems_record_caller_arg_8( \
1129 data_0, \
1130 data_1, \
1131 data_2, \
1132 data_3, \
1133 data_4, \
1134 data_5, \
1135 data_6, \
1136 data_7 \
1137) \
1138 _Record_Caller_arg_8( \
1139 RTEMS_RETURN_ADDRESS(), \
1140 data_0, \
1141 data_1, \
1142 data_2, \
1143 data_3, \
1144 data_4, \
1145 data_5, \
1146 data_6, \
1147 data_7 \
1148 )
1149
1170#define rtems_record_caller_arg_9( \
1171 data_0, \
1172 data_1, \
1173 data_2, \
1174 data_3, \
1175 data_4, \
1176 data_5, \
1177 data_6, \
1178 data_7, \
1179 data_8 \
1180) \
1181 _Record_Caller_arg_9( \
1182 RTEMS_RETURN_ADDRESS(), \
1183 data_0, \
1184 data_1, \
1185 data_2, \
1186 data_3, \
1187 data_4, \
1188 data_5, \
1189 data_6, \
1190 data_7, \
1191 data_8 \
1192 )
1193
1215#define rtems_record_caller_arg_10( \
1216 data_0, \
1217 data_1, \
1218 data_2, \
1219 data_3, \
1220 data_4, \
1221 data_5, \
1222 data_6, \
1223 data_7, \
1224 data_8, \
1225 data_9 \
1226) \
1227 _Record_Caller_arg_10( \
1228 RTEMS_RETURN_ADDRESS(), \
1229 data_0, \
1230 data_1, \
1231 data_2, \
1232 data_3, \
1233 data_4, \
1234 data_5, \
1235 data_6, \
1236 data_7, \
1237 data_8, \
1238 data_9 \
1239 )
1240
1249#define rtems_record_entry( event ) \
1250 rtems_record_produce( event, (rtems_record_data) RTEMS_RETURN_ADDRESS() )
1251
1261#define rtems_record_entry_1( event, data ) \
1262 rtems_record_produce_2( \
1263 event, \
1264 (rtems_record_data) RTEMS_RETURN_ADDRESS(), \
1265 RTEMS_RECORD_ARG_0, \
1266 data \
1267 )
1268
1279#define rtems_record_entry_2( event, data_0, data_1 ) \
1280 _Record_Entry_2( RTEMS_RETURN_ADDRESS(), event, data_0, data_1 )
1281
1293#define rtems_record_entry_3( event, data_0, data_1, data_2 ) \
1294 _Record_Entry_3( \
1295 RTEMS_RETURN_ADDRESS(), \
1296 event, \
1297 data_0, \
1298 data_1, \
1299 data_2 \
1300 )
1301
1314#define rtems_record_entry_4( event, data_0, data_1, data_2, data_3 ) \
1315 _Record_Entry_4( \
1316 RTEMS_RETURN_ADDRESS(), \
1317 event, \
1318 data_0, \
1319 data_1, \
1320 data_2, \
1321 data_3 \
1322 )
1323
1337#define rtems_record_entry_5( \
1338 event, \
1339 data_0, \
1340 data_1, \
1341 data_2, \
1342 data_3, \
1343 data_4 \
1344) \
1345 _Record_Entry_5( \
1346 RTEMS_RETURN_ADDRESS(), \
1347 event, \
1348 data_0, \
1349 data_1, \
1350 data_2, \
1351 data_3, \
1352 data_4 \
1353 )
1354
1369#define rtems_record_entry_6( \
1370 event, \
1371 data_0, \
1372 data_1, \
1373 data_2, \
1374 data_3, \
1375 data_4, \
1376 data_5 \
1377) \
1378 _Record_Entry_6( \
1379 RTEMS_RETURN_ADDRESS(), \
1380 event, \
1381 data_0, \
1382 data_1, \
1383 data_2, \
1384 data_3, \
1385 data_4, \
1386 data_5 \
1387 )
1388
1404#define rtems_record_entry_7( \
1405 event, \
1406 data_0, \
1407 data_1, \
1408 data_2, \
1409 data_3, \
1410 data_4, \
1411 data_5, \
1412 data_6 \
1413) \
1414 _Record_Entry_7( \
1415 RTEMS_RETURN_ADDRESS(), \
1416 event, \
1417 data_0, \
1418 data_1, \
1419 data_2, \
1420 data_3, \
1421 data_4, \
1422 data_5, \
1423 data_6 \
1424 )
1425
1442#define rtems_record_entry_8( \
1443 event, \
1444 data_0, \
1445 data_1, \
1446 data_2, \
1447 data_3, \
1448 data_4, \
1449 data_5, \
1450 data_6, \
1451 data_7 \
1452) \
1453 _Record_Entry_8( \
1454 RTEMS_RETURN_ADDRESS(), \
1455 event, \
1456 data_0, \
1457 data_1, \
1458 data_2, \
1459 data_3, \
1460 data_4, \
1461 data_5, \
1462 data_6, \
1463 data_7 \
1464 )
1465
1483#define rtems_record_entry_9( \
1484 event, \
1485 data_0, \
1486 data_1, \
1487 data_2, \
1488 data_3, \
1489 data_4, \
1490 data_5, \
1491 data_6, \
1492 data_7, \
1493 data_8 \
1494) \
1495 _Record_Entry_9( \
1496 RTEMS_RETURN_ADDRESS(), \
1497 event, \
1498 data_0, \
1499 data_1, \
1500 data_2, \
1501 data_3, \
1502 data_4, \
1503 data_5, \
1504 data_6, \
1505 data_7, \
1506 data_8 \
1507 )
1508
1527#define rtems_record_entry_10( \
1528 event, \
1529 data_0, \
1530 data_1, \
1531 data_2, \
1532 data_3, \
1533 data_4, \
1534 data_5, \
1535 data_6, \
1536 data_7, \
1537 data_8, \
1538 data_9 \
1539) \
1540 _Record_Entry_10( \
1541 RTEMS_RETURN_ADDRESS(), \
1542 event, \
1543 data_0, \
1544 data_1, \
1545 data_2, \
1546 data_3, \
1547 data_4, \
1548 data_5, \
1549 data_6, \
1550 data_7, \
1551 data_8, \
1552 data_9 \
1553 )
1554
1563#define rtems_record_exit( event ) \
1564 rtems_record_produce( event, (rtems_record_data) RTEMS_RETURN_ADDRESS() )
1565
1575#define rtems_record_exit_1( event, data ) \
1576 rtems_record_produce_2( \
1577 event, \
1578 (rtems_record_data) RTEMS_RETURN_ADDRESS(), \
1579 RTEMS_RECORD_RETURN_0, \
1580 data \
1581 )
1582
1593#define rtems_record_exit_2( event, data_0, data_1 ) \
1594 _Record_Entry_2( RTEMS_RETURN_ADDRESS(), event, data_0, data_1 )
1595
1607#define rtems_record_exit_3( event, data_0, data_1, data_2 ) \
1608 _Record_Exit_3( \
1609 RTEMS_RETURN_ADDRESS(), \
1610 event, \
1611 data_0, \
1612 data_1, \
1613 data_2 \
1614 )
1615
1628#define rtems_record_exit_4( event, data_0, data_1, data_2, data_3 ) \
1629 _Record_Exit_4( \
1630 RTEMS_RETURN_ADDRESS(), \
1631 event, \
1632 data_0, \
1633 data_1, \
1634 data_2, \
1635 data_3 \
1636 )
1637
1651#define rtems_record_exit_5( \
1652 event, \
1653 data_0, \
1654 data_1, \
1655 data_2, \
1656 data_3, \
1657 data_4 \
1658) \
1659 _Record_Exit_5( \
1660 RTEMS_RETURN_ADDRESS(), \
1661 event, \
1662 data_0, \
1663 data_1, \
1664 data_2, \
1665 data_3, \
1666 data_4 \
1667 )
1668
1683#define rtems_record_exit_6( \
1684 event, \
1685 data_0, \
1686 data_1, \
1687 data_2, \
1688 data_3, \
1689 data_4, \
1690 data_5 \
1691) \
1692 _Record_Exit_6( \
1693 RTEMS_RETURN_ADDRESS(), \
1694 event, \
1695 data_0, \
1696 data_1, \
1697 data_2, \
1698 data_3, \
1699 data_4, \
1700 data_5 \
1701 )
1702
1718#define rtems_record_exit_7( \
1719 event, \
1720 data_0, \
1721 data_1, \
1722 data_2, \
1723 data_3, \
1724 data_4, \
1725 data_5, \
1726 data_6 \
1727) \
1728 _Record_Exit_7( \
1729 RTEMS_RETURN_ADDRESS(), \
1730 event, \
1731 data_0, \
1732 data_1, \
1733 data_2, \
1734 data_3, \
1735 data_4, \
1736 data_5, \
1737 data_6 \
1738 )
1739
1756#define rtems_record_exit_8( \
1757 event, \
1758 data_0, \
1759 data_1, \
1760 data_2, \
1761 data_3, \
1762 data_4, \
1763 data_5, \
1764 data_6, \
1765 data_7 \
1766) \
1767 _Record_Exit_8( \
1768 RTEMS_RETURN_ADDRESS(), \
1769 event, \
1770 data_0, \
1771 data_1, \
1772 data_2, \
1773 data_3, \
1774 data_4, \
1775 data_5, \
1776 data_6, \
1777 data_7 \
1778 )
1779
1797#define rtems_record_exit_9( \
1798 event, \
1799 data_0, \
1800 data_1, \
1801 data_2, \
1802 data_3, \
1803 data_4, \
1804 data_5, \
1805 data_6, \
1806 data_7, \
1807 data_8 \
1808) \
1809 _Record_Exit_9( \
1810 RTEMS_RETURN_ADDRESS(), \
1811 event, \
1812 data_0, \
1813 data_1, \
1814 data_2, \
1815 data_3, \
1816 data_4, \
1817 data_5, \
1818 data_6, \
1819 data_7, \
1820 data_8 \
1821 )
1822
1841#define rtems_record_exit_10( \
1842 event, \
1843 data_0, \
1844 data_1, \
1845 data_2, \
1846 data_3, \
1847 data_4, \
1848 data_5, \
1849 data_6, \
1850 data_7, \
1851 data_8, \
1852 data_9 \
1853) \
1854 _Record_Exit_10( \
1855 RTEMS_RETURN_ADDRESS(), \
1856 event, \
1857 data_0, \
1858 data_1, \
1859 data_2, \
1860 data_3, \
1861 data_4, \
1862 data_5, \
1863 data_6, \
1864 data_7, \
1865 data_8, \
1866 data_9 \
1867 )
1868
1874uint32_t rtems_record_interrupt_disable( void );
1875
1883void rtems_record_interrupt_enable( uint32_t level );
1884
1885typedef void ( *rtems_record_drain_visitor )(
1886 const rtems_record_item *items,
1887 size_t count,
1888 void *arg
1889);
1890
1891void _Record_Drain(
1893 uint32_t cpu_index,
1894 rtems_record_drain_visitor visitor,
1895 void *arg
1896);
1897
1906void rtems_record_drain( rtems_record_drain_visitor visitor, void *arg );
1907
1910#ifdef __cplusplus
1911}
1912#endif /* __cplusplus */
1913
1914#endif /* _RTEMS_RECORD_H */
Free-Running Counter and Busy Wait Delay API.
Constants and Structures Associated with Watchdog Timers.
CPU_Counter_ticks rtems_counter_ticks
Unsigned integer type for counter values.
Definition: counter.h:62
RTEMS_INLINE_ROUTINE void rtems_record_prepare_critical(rtems_record_context *context, const Per_CPU_Control *cpu_self)
Prepares to add and commit record items in a critical section with interrupts disabled.
Definition: record.h:501
void rtems_record_line_arg(rtems_record_data data)
Generates an RTEMS_RECORD_LINE event and one argument event.
Definition: record-util.c:73
void rtems_record_produce(rtems_record_event event, rtems_record_data data)
Produces a record item.
Definition: record.c:47
#define RTEMS_RECORD_TIME_EVENT(time, event)
Builds a time event for the specified time stamp and event.
Definition: recorddata.h:1150
void rtems_record_line_arg_10(rtems_record_data data_0, rtems_record_data data_1, rtems_record_data data_2, rtems_record_data data_3, rtems_record_data data_4, rtems_record_data data_5, rtems_record_data data_6, rtems_record_data data_7, rtems_record_data data_8, rtems_record_data data_9)
Generates an RTEMS_RECORD_LINE event and ten argument events.
Definition: record-util.c:295
RTEMS_INLINE_ROUTINE void rtems_record_commit_critical(rtems_record_context *context)
Commits a set of record items in a critical section with interrupts disabled.
Definition: record.h:578
void rtems_record_line_arg_4(rtems_record_data data_0, rtems_record_data data_1, rtems_record_data data_2, rtems_record_data data_3)
Generates an RTEMS_RECORD_LINE event and four argument events.
Definition: record-util.c:118
void rtems_record_line_arg_6(rtems_record_data data_0, rtems_record_data data_1, rtems_record_data data_2, rtems_record_data data_3, rtems_record_data data_4, rtems_record_data data_5)
Generates an RTEMS_RECORD_LINE event and six argument events.
Definition: record-util.c:165
void rtems_record_line_arg_2(rtems_record_data data_0, rtems_record_data data_1)
Generates an RTEMS_RECORD_LINE event and two argument events.
Definition: record-util.c:83
RTEMS_INLINE_ROUTINE void rtems_record_add(rtems_record_context *context, rtems_record_event event, rtems_record_data data)
Adds a record item.
Definition: record.h:552
void rtems_record_line_arg_9(rtems_record_data data_0, rtems_record_data data_1, rtems_record_data data_2, rtems_record_data data_3, rtems_record_data data_4, rtems_record_data data_5, rtems_record_data data_6, rtems_record_data data_7, rtems_record_data data_8)
Generates an RTEMS_RECORD_LINE event and nine argument events.
Definition: record-util.c:258
void rtems_record_line_arg_5(rtems_record_data data_0, rtems_record_data data_1, rtems_record_data data_2, rtems_record_data data_3, rtems_record_data data_4)
Generates an RTEMS_RECORD_LINE event and five argument events.
Definition: record-util.c:140
void rtems_record_produce_n(const rtems_record_item *items, size_t n)
Produces n record items.
Definition: record.c:71
void rtems_record_line_2(rtems_record_event event, rtems_record_data data)
Generates an RTEMS_RECORD_LINE event and an extra event.
Definition: record-util.c:42
void rtems_record_line_arg_8(rtems_record_data data_0, rtems_record_data data_1, rtems_record_data data_2, rtems_record_data data_3, rtems_record_data data_4, rtems_record_data data_5, rtems_record_data data_6, rtems_record_data data_7)
Generates an RTEMS_RECORD_LINE event and eight argument events.
Definition: record-util.c:224
uint32_t rtems_record_interrupt_disable(void)
Disables interrupts and generates an RTEMS_RECORD_ISR_DISABLE event.
Definition: record-util.c:1215
void rtems_record_drain(rtems_record_drain_visitor visitor, void *arg)
Drains the record items on all processors.
Definition: record.c:172
void rtems_record_produce_2(rtems_record_event event_0, rtems_record_data data_0, rtems_record_event event_1, rtems_record_data data_1)
Produces two record items.
Definition: record.c:56
void rtems_record_line_arg_3(rtems_record_data data_0, rtems_record_data data_1, rtems_record_data data_2)
Generates an RTEMS_RECORD_LINE event and three argument events.
Definition: record-util.c:99
unsigned long rtems_record_data
The record data integer type.
Definition: recorddata.h:1170
rtems_record_event
The record events.
Definition: recorddata.h:90
RTEMS_INLINE_ROUTINE void rtems_record_commit(rtems_record_context *context)
Commits a set of record items.
Definition: record.h:592
RTEMS_INLINE_ROUTINE void rtems_record_prepare(rtems_record_context *context)
Prepares to add and commit record items.
Definition: record.h:527
void rtems_record_interrupt_enable(uint32_t level)
Restores the previous interrupt level and generates an RTEMS_RECORD_ISR_ENABLE event.
Definition: record-util.c:1232
void rtems_record_line_arg_7(rtems_record_data data_0, rtems_record_data data_1, rtems_record_data data_2, rtems_record_data data_3, rtems_record_data data_4, rtems_record_data data_5, rtems_record_data data_6)
Generates an RTEMS_RECORD_LINE event and seven argument events.
Definition: record-util.c:193
void rtems_record_line_3(rtems_record_event event_0, rtems_record_data data_0, rtems_record_event event_1, rtems_record_data data_1)
Generates an RTEMS_RECORD_LINE event and two extra events.
Definition: record-util.c:55
void rtems_record_line(void)
Generates an RTEMS_RECORD_LINE event.
Definition: record-util.c:34
#define RTEMS_ALIGNED(_alignment)
Instructs the compiler to enforce the specified alignment.
Definition: basedefs.h:216
#define RTEMS_COMPILER_MEMORY_BARRIER()
Definition: basedefs.h:77
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
Internal_errors_Source
This type lists the possible sources from which an error can be reported.
Definition: interr.h:47
Atomic Operations API.
Constants and Prototypes Related to the Internal Error Handler.
#define CPU_CACHE_LINE_BYTES
Definition: cpu.h:218
Per CPU Core Structure.
Definition: percpu.h:347
Used for passing and retrieving registers content to/from real mode interrupt call.
Definition: realmode_int.h:43
Definition: record.h:54
Definition: record.h:44
The control block used to manage each watchdog timer.
Definition: watchdog.h:90
Definition: thread.h:732
Definition: inftrees.h:24
Definition: intercom.c:74
Definition: mknod-pack_dev.c:254
unsigned context
Definition: tlb.h:1
