RTEMS
5.2
include
extensiondata.h
1
9
10
* COPYRIGHT (c) 1989-2008.
11
* On-Line Applications Research Corporation (OAR).
12
13
* The license and distribution terms for this file may be
14
* found in the file LICENSE in this distribution or at
15
* http://www.rtems.org/license/LICENSE.
16
17
18
#ifndef _RTEMS_EXTENSIONDATA_H
19
#define _RTEMS_EXTENSIONDATA_H
20
21
rtems/extension.h
22
rtems/score/objectdata.h
23
rtems/score/userextdata.h
24
25
#ifdef __cplusplus
26
extern
"C"
27
#endif
28
35
typedef
struct
36
Objects_Control
Object;
37
User_extensions_Control
Extension;
38
Extension_Control
39
43
extern
Objects_Information
_Extension_Information
44
54
#define EXTENSION_INFORMATION_DEFINE( max ) \
55
OBJECTS_INFORMATION_DEFINE( \
56
_Extension, \
57
OBJECTS_CLASSIC_API, \
58
OBJECTS_RTEMS_EXTENSIONS, \
59
Extension_Control, \
60
max, \
61
OBJECTS_NO_STRING_NAME, \
62
NULL \
63
64
67
#ifdef __cplusplus
68
69
#endif
70
71
#endif
72
/* end of include file */
extension.h
User Extensions API.
Objects_Information _Extension_Information
The Classic Extensions objects information.
objectdata.h
Object Handler Data Structures.
Extension_Control
Definition:
extensiondata.h:35
Objects_Control
Definition:
objectdata.h:39
Objects_Information
The information structure used to manage each API class of objects.
Definition:
objectdata.h:176
Manages each user extension set.
Definition:
userextdata.h:50
userextdata.h
User Extension Handler Data Structures.
