RTEMS
5.2
bsps
no_cpu
no_bsp
include
bsp.h
1
9
/* bsp.h
10
11
* This include file contains all board IO definitions.
12
13
* XXX : put yours in here
14
15
16
17
* COPYRIGHT (c) 1989-1999.
18
* On-Line Applications Research Corporation (OAR).
19
20
* The license and distribution terms for this file may be
21
* found in the file LICENSE in this distribution or at
22
* http://www.rtems.org/license/LICENSE.
23
24
25
#ifndef LIBBSP_NO_CPU_NO_BSP_BSP_H
26
#define LIBBSP_NO_CPU_NO_BSP_BSP_H
27
34
#include <bspopts.h>
35
bsp/default-initial-extension.h
36
37
rtems.h
38
39
#ifdef __cplusplus
40
extern
"C"
41
#endif
42
43
/* functions */
44
45
rtems_isr_entry
set_vector
/* returns old vector */
46
rtems_isr_entry handler,
/* isr routine */
47
rtems_vector_number
vector,
/* vector number */
48
int
type
/* RTEMS or RAW intr */
49
50
51
#ifdef __cplusplus
52
53
#endif
54
57
#endif
DEFAULT_INITIAL_EXTENSION Support.
rtems_vector_number
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition:
intr.h:47
set_vector
rtems_isr_entry set_vector(rtems_isr_entry handler, rtems_vector_number vector, int type)
Install an interrupt handler.
Definition:
setvec.c:28
rtems.h
