RTEMS 5.2
io.h
1
9/*
10 * Copyright © 2013 Eugeniy Meshcheryakov <eugen@debian.org>
11 *
12 * The license and distribution terms for this file may be
13 * found in the file LICENSE in this distribution or at
14 * http://www.rtems.org/license/LICENSE.
15 */
16
17#ifndef LIBBSP_ARM_LM3S69XX_IO_H
18#define LIBBSP_ARM_LM3S69XX_IO_H
19#include <bspopts.h>
20#include <stdbool.h>
21
30typedef enum {
31 LM3S69XX_GPIO_DIRECTION_INPUT,
32 LM3S69XX_GPIO_DIRECTION_OUTPUT
33} lm3s69xx_gpio_direction;
34
35typedef enum {
36 LM3S69XX_GPIO_OTYPE_PUSH_PULL,
37 LM3S69XX_GPIO_OTYPE_OPEN_DRAIN
38} lm3s69xx_gpio_otype;
39
40typedef enum {
41 LM3S69XX_GPIO_DRIVE_2MA,
42 LM3S69XX_GPIO_DRIVE_4MA,
43 LM3S69XX_GPIO_DRIVE_8MA
44} lm3s69xx_gpio_drive;
45
46typedef enum {
47 LM3S69XX_GPIO_NO_PULL,
48 LM3S69XX_GPIO_PULL_UP,
49 LM3S69XX_GPIO_PULL_DOWN
50} lm3s69xx_gpio_pull;
51
52typedef enum {
53 LM3S69XX_GPIO_DIGITAL_DISABLE,
54 LM3S69XX_GPIO_DIGITAL_ENABLE,
55} lm3s69xx_gpio_digital;
56
57typedef enum {
58 LM3S69XX_GPIO_AF_DISABLE,
59 LM3S69XX_GPIO_AF_ENABLE
60} lm3s69xx_gpio_af;
61
62typedef enum {
63 LM3S69XX_GPIO_ANALOG_DISABLE,
64 LM3S69XX_GPIO_ANALOG_ENABLE
65} lm3s69xx_gpio_analog;
66
67typedef enum {
68 LM3S69XX_GPIO_NO_SLEW_RATE_CONTROL,
69 LM3S69XX_GPIO_SLEW_RATE_CONTROL
70} lm3s69xx_gpio_slew_rate_control;
71
72typedef struct {
73 unsigned int pin_first : 8;
74 unsigned int pin_last : 8;
75 unsigned int digital : 1;
76 unsigned int alternate : 1;
77 unsigned int analog : 1;
78 unsigned int dir : 1;
79 unsigned int otype : 1;
80 unsigned int drive : 2;
81 unsigned int pull : 2;
82 unsigned int slr : 1;
84
85typedef enum {
86 LM3S69XX_PORT_A,
87 LM3S69XX_PORT_B,
88 LM3S69XX_PORT_C,
89 LM3S69XX_PORT_D,
90 LM3S69XX_PORT_E,
91 LM3S69XX_PORT_F,
92 LM3S69XX_PORT_G,
93#if LM3S69XX_NUM_GPIO_BLOCKS > 7
94 LM3S69XX_PORT_H
95#endif
96} lm3s69xx_gpio_port;
97
98#define LM3S69XX_GPIO_PIN(port, idx) (((port) << 3) | (idx))
99#define LM3S69XX_GPIO_PORT_OF_PIN(pin) (((pin) >> 3) & 0xf)
100#define LM3S69XX_GPIO_INDEX_OF_PIN(pin) ((pin) & 0x7)
101
102#define LM3S69XX_PIN_UART_TX(port, idx) \
103 { \
104 .pin_first = LM3S69XX_GPIO_PIN(port, idx), \
105 .pin_last = LM3S69XX_GPIO_PIN(port, idx), \
106 .digital = LM3S69XX_GPIO_DIGITAL_ENABLE, \
107 .alternate = LM3S69XX_GPIO_AF_ENABLE, \
108 .analog = LM3S69XX_GPIO_ANALOG_DISABLE, \
109 .dir = LM3S69XX_GPIO_DIRECTION_OUTPUT, \
110 .otype = LM3S69XX_GPIO_OTYPE_PUSH_PULL, \
111 .drive = LM3S69XX_GPIO_DRIVE_2MA, \
112 .pull = LM3S69XX_GPIO_NO_PULL, \
113 .slr = LM3S69XX_GPIO_NO_SLEW_RATE_CONTROL \
114 }
115
116#define LM3S69XX_PIN_UART_RX(port, idx) \
117 { \
118 .pin_first = LM3S69XX_GPIO_PIN(port, idx), \
119 .pin_last = LM3S69XX_GPIO_PIN(port, idx), \
120 .digital = LM3S69XX_GPIO_DIGITAL_ENABLE, \
121 .alternate = LM3S69XX_GPIO_AF_ENABLE, \
122 .analog = LM3S69XX_GPIO_ANALOG_DISABLE, \
123 .dir = LM3S69XX_GPIO_DIRECTION_INPUT, \
124 .otype = LM3S69XX_GPIO_OTYPE_PUSH_PULL, \
125 .drive = LM3S69XX_GPIO_DRIVE_2MA, \
126 .pull = LM3S69XX_GPIO_PULL_UP, \
127 .slr = LM3S69XX_GPIO_NO_SLEW_RATE_CONTROL \
128 }
129
130#define LM3S69XX_PIN_UART_RTS(port, idx) \
131 { \
132 .pin_first = LM3S69XX_GPIO_PIN(port, idx), \
133 .pin_last = LM3S69XX_GPIO_PIN(port, idx), \
134 .digital = LM3S69XX_GPIO_DIGITAL_ENABLE, \
135 .alternate = LM3S69XX_GPIO_AF_ENABLE, \
136 .analog = LM3S69XX_GPIO_ANALOG_DISABLE, \
137 .dir = LM3S69XX_GPIO_DIRECTION_OUTPUT, \
138 .otype = LM3S69XX_GPIO_OTYPE_PUSH_PULL, \
139 .drive = LM3S69XX_GPIO_DRIVE_2MA, \
140 .pull = LM3S69XX_GPIO_NO_PULL, \
141 .slr = LM3S69XX_GPIO_NO_SLEW_RATE_CONTROL \
142 }
143
144#define LM3S69XX_PIN_UART_CTS(port, idx) \
145 { \
146 .pin_first = LM3S69XX_GPIO_PIN(port, idx), \
147 .pin_last = LM3S69XX_GPIO_PIN(port, idx), \
148 .digital = LM3S69XX_GPIO_DIGITAL_ENABLE, \
149 .alternate = LM3S69XX_GPIO_AF_ENABLE, \
150 .analog = LM3S69XX_GPIO_ANALOG_DISABLE, \
151 .dir = LM3S69XX_GPIO_DIRECTION_INPUT, \
152 .otype = LM3S69XX_GPIO_OTYPE_PUSH_PULL, \
153 .drive = LM3S69XX_GPIO_DRIVE_2MA, \
154 .pull = LM3S69XX_GPIO_PULL_UP, \
155 .slr = LM3S69XX_GPIO_NO_SLEW_RATE_CONTROL \
156 }
157
158#define LM3S69XX_PIN_LED(port, idx) \
159 { \
160 .pin_first = LM3S69XX_GPIO_PIN(port, idx), \
161 .pin_last = LM3S69XX_GPIO_PIN(port, idx), \
162 .digital = LM3S69XX_GPIO_DIGITAL_ENABLE, \
163 .alternate = LM3S69XX_GPIO_AF_DISABLE, \
164 .analog = LM3S69XX_GPIO_ANALOG_DISABLE, \
165 .dir = LM3S69XX_GPIO_DIRECTION_OUTPUT, \
166 .otype = LM3S69XX_GPIO_OTYPE_PUSH_PULL, \
167 .drive = LM3S69XX_GPIO_DRIVE_8MA, \
168 .pull = LM3S69XX_GPIO_NO_PULL, \
169 .slr = LM3S69XX_GPIO_SLEW_RATE_CONTROL \
170 }
171
172#define LM3S69XX_PIN_SSI_TX(port, idx) LM3S69XX_PIN_UART_TX(port, idx)
173#define LM3S69XX_PIN_SSI_RX(port, idx) LM3S69XX_PIN_UART_RX(port, idx)
174
175#ifdef __cplusplus
176extern "C" {
177#endif
178
179void lm3s69xx_gpio_set_config(const lm3s69xx_gpio_config *config);
180void lm3s69xx_gpio_set_config_array(const lm3s69xx_gpio_config *configs, unsigned int count);
181void lm3s69xx_gpio_digital_enable(unsigned int pin, bool enable);
182void lm3s69xx_gpio_analog_mode_select(unsigned int pin, bool enable);
183
184void lm3s69xx_gpio_set_pin(unsigned int pin, bool set);
185bool lm3s69xx_gpio_get_pin(unsigned int pin);
186
187#ifdef __cplusplus
188}
189#endif
190
191#endif /* LIBBSP_ARM_LM3S69XX_IO_H */
Definition: io.c:114
Definition: io.c:99
Definition: deflate.c:115
Definition: io.h:72
