RTEMS 5.2
Data Structures | Macros | Enumerations | Functions
io.h File Reference
IO definitions. More...
#include <bspopts.h>
#include <stdbool.h>
struct  lm3s69xx_gpio_config
#define LM3S69XX_GPIO_PIN(port, idx)   (((port) << 3) | (idx))
#define LM3S69XX_GPIO_PORT_OF_PIN(pin)   (((pin) >> 3) & 0xf)
#define LM3S69XX_GPIO_INDEX_OF_PIN(pin)   ((pin) & 0x7)
#define LM3S69XX_PIN_UART_TX(port, idx)
#define LM3S69XX_PIN_UART_RX(port, idx)
#define LM3S69XX_PIN_UART_RTS(port, idx)
#define LM3S69XX_PIN_UART_CTS(port, idx)
#define LM3S69XX_PIN_LED(port, idx)
#define LM3S69XX_PIN_SSI_TX(port, idx)   LM3S69XX_PIN_UART_TX(port, idx)
#define LM3S69XX_PIN_SSI_RX(port, idx)   LM3S69XX_PIN_UART_RX(port, idx)
enum  lm3s69xx_gpio_direction { LM3S69XX_GPIO_DIRECTION_INPUT , LM3S69XX_GPIO_DIRECTION_OUTPUT }
enum  lm3s69xx_gpio_otype { LM3S69XX_GPIO_OTYPE_PUSH_PULL , LM3S69XX_GPIO_OTYPE_OPEN_DRAIN }
enum  lm3s69xx_gpio_drive { LM3S69XX_GPIO_DRIVE_2MA , LM3S69XX_GPIO_DRIVE_4MA , LM3S69XX_GPIO_DRIVE_8MA }
enum  lm3s69xx_gpio_pull { LM3S69XX_GPIO_NO_PULL , LM3S69XX_GPIO_PULL_UP , LM3S69XX_GPIO_PULL_DOWN }
enum  lm3s69xx_gpio_digital { LM3S69XX_GPIO_DIGITAL_DISABLE , LM3S69XX_GPIO_DIGITAL_ENABLE }
enum  lm3s69xx_gpio_af { LM3S69XX_GPIO_AF_DISABLE , LM3S69XX_GPIO_AF_ENABLE }
enum  lm3s69xx_gpio_analog { LM3S69XX_GPIO_ANALOG_DISABLE , LM3S69XX_GPIO_ANALOG_ENABLE }
enum  lm3s69xx_gpio_slew_rate_control { LM3S69XX_GPIO_NO_SLEW_RATE_CONTROL , LM3S69XX_GPIO_SLEW_RATE_CONTROL }
enum  lm3s69xx_gpio_port {
  LM3S69XX_PORT_A , LM3S69XX_PORT_B , LM3S69XX_PORT_C , LM3S69XX_PORT_D ,
  LM3S69XX_PORT_E , LM3S69XX_PORT_F , LM3S69XX_PORT_G
void lm3s69xx_gpio_set_config (const lm3s69xx_gpio_config *config)
void lm3s69xx_gpio_set_config_array (const lm3s69xx_gpio_config *configs, unsigned int count)
void lm3s69xx_gpio_digital_enable (unsigned int pin, bool enable)
void lm3s69xx_gpio_analog_mode_select (unsigned int pin, bool enable)
void lm3s69xx_gpio_set_pin (unsigned int pin, bool set)
bool lm3s69xx_gpio_get_pin (unsigned int pin)
IO definitions.
◆ LM3S69XX_PIN_LED
#define LM3S69XX_PIN_LED (   port,
  idx
Value:
.pin_first = LM3S69XX_GPIO_PIN(port, idx), \
.pin_last = LM3S69XX_GPIO_PIN(port, idx), \
.digital = LM3S69XX_GPIO_DIGITAL_ENABLE, \
.alternate = LM3S69XX_GPIO_AF_DISABLE, \
.analog = LM3S69XX_GPIO_ANALOG_DISABLE, \
.dir = LM3S69XX_GPIO_DIRECTION_OUTPUT, \
.otype = LM3S69XX_GPIO_OTYPE_PUSH_PULL, \
.drive = LM3S69XX_GPIO_DRIVE_8MA, \
.pull = LM3S69XX_GPIO_NO_PULL, \
.slr = LM3S69XX_GPIO_SLEW_RATE_CONTROL \
◆ LM3S69XX_PIN_UART_CTS
#define LM3S69XX_PIN_UART_CTS (   port,
  idx
Value:
.alternate = LM3S69XX_GPIO_AF_ENABLE, \
.dir = LM3S69XX_GPIO_DIRECTION_INPUT, \
.drive = LM3S69XX_GPIO_DRIVE_2MA, \
.pull = LM3S69XX_GPIO_PULL_UP, \
.slr = LM3S69XX_GPIO_NO_SLEW_RATE_CONTROL \
◆ LM3S69XX_PIN_UART_RTS
#define LM3S69XX_PIN_UART_RTS (   port,
  idx
Value:
◆ LM3S69XX_PIN_UART_RX
#define LM3S69XX_PIN_UART_RX (   port,
  idx
Value:
◆ LM3S69XX_PIN_UART_TX
#define LM3S69XX_PIN_UART_TX (   port,
  idx
Value:
◆ lm3s69xx_gpio_analog_mode_select()
void lm3s69xx_gpio_analog_mode_select ( unsigned int  pin,
bool  enable
Enables/disables analog mode on the specified pin.
◆ lm3s69xx_gpio_digital_enable()
void lm3s69xx_gpio_digital_enable ( unsigned int  pin,
bool  enable
Enables/disables digital function on the specified pin.
