RTEMS 5.2
bestcomm_glue.h
1/*===============================================================*\
2| Project: RTEMS generic MPC5200 BSP |
3+-----------------------------------------------------------------+
4| Copyright (c) 2004-2005 |
5| Embedded Brains GmbH |
6| Obere Lagerstr. 30 |
7| D-82178 Puchheim |
8| Germany |
9| rtems@embedded-brains.de |
10+-----------------------------------------------------------------+
11| The license and distribution terms for this file may be |
12| found in the file LICENSE in this distribution or at |
13| |
14| http://www.rtems.org/license/LICENSE. |
15| |
16+-----------------------------------------------------------------+
17| this file declares glue functions to the Freescale BestComm API |
18\*===============================================================*/
19#ifndef _BESTCOMM_GLUE_H
20#define _BESTCOMM_GLUE_H
21
22#include <rtems/irq-extension.h>
23
24#ifdef __cplusplus
25extern "C" {
26#endif /* __cplusplus */
27
28/*=========================================================================*\
29| Function: |
30\*-------------------------------------------------------------------------*/
31void bestcomm_glue_irq_enable
32(
33/*-------------------------------------------------------------------------*\
34| Purpose: |
35| enable interrupt for given task number |
36+---------------------------------------------------------------------------+
37| Input Parameters: |
38\*-------------------------------------------------------------------------*/
39 int bestcomm_taskno /* task number to enable */
40 );
41/*-------------------------------------------------------------------------*\
42| Return Value: |
43| none |
44\*=========================================================================*/
45
46/*=========================================================================*\
47| Function: |
48\*-------------------------------------------------------------------------*/
49void bestcomm_glue_irq_disable
50(
51/*-------------------------------------------------------------------------*\
52| Purpose: |
53| disable interrupt for given task number |
54+---------------------------------------------------------------------------+
55| Input Parameters: |
56\*-------------------------------------------------------------------------*/
57 int bestcomm_taskno /* task number to disable */
58 );
59/*-------------------------------------------------------------------------*\
60| Return Value: |
61| none |
62\*=========================================================================*/
63
64/*=========================================================================*\
65| Function: |
66\*-------------------------------------------------------------------------*/
67void bestcomm_glue_irq_install
68(
69/*-------------------------------------------------------------------------*\
70| Purpose: |
71| install given function as bestcomm interrupt handler |
72+---------------------------------------------------------------------------+
73| Input Parameters: |
74\*-------------------------------------------------------------------------*/
75 int bestcomm_taskno, /* task number for handler */
76 rtems_interrupt_handler handler, /* function to call */
77 void *arg
78 );
79/*-------------------------------------------------------------------------*\
80| Return Value: |
81| none |
82\*=========================================================================*/
83
84/*=========================================================================*\
85| Function: |
86\*-------------------------------------------------------------------------*/
87void bestcomm_glue_init
88(
89/*-------------------------------------------------------------------------*\
90| Purpose: |
91| initialize the bestcomm module (if not yet done): |
92| - load code |
93| - initialize registers |
94| - initialize bus arbiter |
95| - initialize interrupt control |
96+---------------------------------------------------------------------------+
97| Input Parameters: |
98\*-------------------------------------------------------------------------*/
99 void /* none */
100 );
101/*-------------------------------------------------------------------------*\
102| Return Value: |
103| none |
104\*=========================================================================*/
105
106void *bestcomm_malloc(size_t size);
107
108void bestcomm_free(void *ptr);
109
110#ifdef __cplusplus
111}
112#endif /* __cplusplus */
113
114#endif /* _BESTCOMM_GLUE_H */
void(* rtems_interrupt_handler)(void *)
Interrupt handler routine type.
Definition: irq-extension.h:79
Header file for the Interrupt Manager Extension.
unsigned size
Definition: tte.h:1
