#define | RTEMS_INTERRUPT_UNIQUE ((rtems_option) 0x00000001) |
| | Makes the interrupt handler unique. Prevents other handler from using the same interrupt vector.
#define | RTEMS_INTERRUPT_SHARED ((rtems_option) 0x00000000) |
| | Allows that this interrupt handler may share a common interrupt vector with other handler.
#define | RTEMS_INTERRUPT_REPLACE ((rtems_option) 0x00000002) |
| | Forces that this interrupt handler replaces the first handler with the same argument.
#define | RTEMS_INTERRUPT_IS_UNIQUE(options) ((options) & RTEMS_INTERRUPT_UNIQUE) |
| | Returns true if the interrupt handler unique option is set.
#define | RTEMS_INTERRUPT_IS_SHARED(options) (!RTEMS_INTERRUPT_IS_UNIQUE( options)) |
| | Returns true if the interrupt handler shared option is set.
#define | RTEMS_INTERRUPT_IS_REPLACE(options) ((options) & RTEMS_INTERRUPT_REPLACE) |
| | Returns true if the interrupt handler replace option is set.
#define | RTEMS_INTERRUPT_SERVER_DEFAULT 0 |
| | The interrupt server index of the default interrupt server.
| rtems_status_code | rtems_interrupt_handler_install (rtems_vector_number vector, const char *info, rtems_option options, rtems_interrupt_handler handler, void *arg) |
| | Installs the interrupt handler routine handler for the interrupt vector with number vector. More...
| rtems_status_code | rtems_interrupt_handler_remove (rtems_vector_number vector, rtems_interrupt_handler handler, void *arg) |
| | Removes the interrupt handler routine handler with argument arg for the interrupt vector with number vector. More...
| rtems_status_code | rtems_interrupt_handler_iterate (rtems_vector_number vector, rtems_interrupt_per_handler_routine routine, void *arg) |
| | Iterates over all installed interrupt handler of the interrupt vector with number vector. More...
| rtems_status_code | rtems_interrupt_set_affinity (rtems_vector_number vector, size_t affinity_size, const cpu_set_t *affinity) |
| | Sets the processor affinity set of an interrupt vector. More...
| rtems_status_code | rtems_interrupt_get_affinity (rtems_vector_number vector, size_t affinity_size, cpu_set_t *affinity) |
| | Gets the processor affinity set of an interrupt vector. More...
| rtems_status_code | rtems_interrupt_server_initialize (rtems_task_priority priority, size_t stack_size, rtems_mode modes, rtems_attribute attributes, uint32_t *server_count) |
| | Initializes the interrupt server tasks. More...
| rtems_status_code | rtems_interrupt_server_create (rtems_interrupt_server_control *control, const rtems_interrupt_server_config *config, uint32_t *server_index) |
| | Creates an interrupt server. More...
| rtems_status_code | rtems_interrupt_server_delete (uint32_t server_index) |
| | Destroys the interrupt server. More...
| rtems_status_code | rtems_interrupt_server_handler_install (uint32_t server_index, rtems_vector_number vector, const char *info, rtems_option options, rtems_interrupt_handler handler, void *arg) |
| | Installs the interrupt handler routine handler for the interrupt vector with number vector on the server server. More...
| rtems_status_code | rtems_interrupt_server_handler_remove (uint32_t server_index, rtems_vector_number vector, rtems_interrupt_handler handler, void *arg) |
| | Removes the interrupt handler routine handler with argument arg for the interrupt vector with number vector from the server server. More...
| rtems_status_code | rtems_interrupt_server_handler_iterate (uint32_t server_index, rtems_vector_number vector, rtems_interrupt_per_handler_routine routine, void *arg) |
| | Iterates over all interrupt handler of the interrupt vector with number vector which are installed on the interrupt server specified by server. More...
| rtems_status_code | rtems_interrupt_server_move (uint32_t source_server_index, rtems_vector_number vector, uint32_t destination_server_index) |
| | Moves the interrupt handlers installed on the specified source interrupt server to the destination interrupt server. More...
| rtems_status_code | rtems_interrupt_server_suspend (uint32_t server_index) |
| | Suspends the specified interrupt server. More...
| rtems_status_code | rtems_interrupt_server_resume (uint32_t server_index) |
| | Resumes the specified interrupt server. More...
| rtems_status_code | rtems_interrupt_server_set_affinity (uint32_t server_index, size_t affinity_size, const cpu_set_t *affinity, rtems_task_priority priority) |
| | Sets the processor affinity of the specified interrupt server. More...
| rtems_status_code | rtems_interrupt_server_entry_initialize (uint32_t server_index, rtems_interrupt_server_entry *entry) |
| | Initializes the specified interrupt server entry. More...
| void | rtems_interrupt_server_action_prepend (rtems_interrupt_server_entry *entry, rtems_interrupt_server_action *action, rtems_interrupt_handler handler, void *arg) |
| | Prepends the specified interrupt server action to the list of actions of the specified interrupt server entry. More...
| void | rtems_interrupt_server_entry_submit (rtems_interrupt_server_entry *entry) |
| | Submits the specified interrupt server entry so that its interrupt server actions can be invoked by the specified interrupt server. More...
| rtems_status_code | rtems_interrupt_server_entry_move (rtems_interrupt_server_entry *entry, uint32_t destination_server_index) |
| | Moves the interrupt server entry to the specified destination interrupt server. More...
| void | rtems_interrupt_server_entry_destroy (rtems_interrupt_server_entry *entry) |
| | Destroys the specified interrupt server entry. More...
| rtems_status_code | rtems_interrupt_server_request_initialize (uint32_t server_index, rtems_interrupt_server_request *request, rtems_interrupt_handler handler, void *arg) |
| | Initializes the specified interrupt server request. More...
| RTEMS_INLINE_ROUTINE void | rtems_interrupt_server_request_set_vector (rtems_interrupt_server_request *request, rtems_vector_number vector) |
| | Sets the interrupt vector in the specified interrupt server request. More...
| RTEMS_INLINE_ROUTINE void | rtems_interrupt_server_request_submit (rtems_interrupt_server_request *request) |
| | Submits the specified interrupt server request so that its interrupt server action can be invoked by the specified interrupt server. More...
| RTEMS_INLINE_ROUTINE void | rtems_interrupt_server_request_destroy (rtems_interrupt_server_request *request) |
| | Destroys the specified interrupt server request. More...
Header file for the Interrupt Manager Extension.
