RTEMS 5.2
Files | Macros | Typedefs | Functions | Variables
Modes
file  modes.h
file  modes.c
 Body for RTEMS_INTERRUPT_LEVEL Macro.
#define RTEMS_ALL_MODE_MASKS   0x0000ffff
#define RTEMS_DEFAULT_MODES   0x00000000
#define RTEMS_CURRENT_MODE   0
#define RTEMS_TIMESLICE_MASK   0x00000200
#define RTEMS_PREEMPT_MASK   0x00000100
#define RTEMS_ASR_MASK   0x00000400
#define RTEMS_INTERRUPT_MASK   CPU_MODES_INTERRUPT_MASK
#define RTEMS_PREEMPT   0x00000000
#define RTEMS_NO_PREEMPT   0x00000100
#define RTEMS_NO_TIMESLICE   0x00000000
#define RTEMS_TIMESLICE   0x00000200
#define RTEMS_ASR   0x00000000
#define RTEMS_NO_ASR   0x00000400
#define RTEMS_INTERRUPT_LEVEL(_mode_set)    ( (_mode_set) & RTEMS_INTERRUPT_MASK )
 RTEMS_INTERRUPT_LEVEL. More...
typedef uint32_t rtems_mode
rtems_mode rtems_interrupt_level_body (uint32_t level)
 Body for RTEMS_INTERRUPT_LEVEL Macro. More...
const uint32_t rtems_interrupt_mask
 Interrupt Mask Variable. More...
This encapsulates functionality related to the task modes supported by the Classic API Task Manager.
◆ RTEMS_ALL_MODE_MASKS
The following constants define the individual modes and masks which may be used to compose a mode set and to alter modes.
◆ RTEMS_ASR
This mode constant is used to indicate signal processing is enabled.
◆ RTEMS_ASR_MASK
This mode constant corresponds to the signal enable/disable bit.
◆ RTEMS_CURRENT_MODE
This mode constant is used when the user wishes to obtain their current execution mode.
◆ RTEMS_DEFAULT_MODES
This mode constant is the default mode set.
◆ RTEMS_INTERRUPT_LEVEL
#define RTEMS_INTERRUPT_LEVEL (   _mode_set)     ( (_mode_set) & RTEMS_INTERRUPT_MASK )
This function returns the processor dependent interrupt level which corresponds to the requested interrupt level.
Note
RTEMS supports 256 interrupt levels using the least significant eight bits of MODES.CONTROL. On any particular CPU, fewer than 256 levels may be supported.
◆ RTEMS_INTERRUPT_MASK
This mode constant corresponds to the interrupt enable/disable bits.
◆ RTEMS_NO_ASR
This mode constant is used to indicate signal processing is disabled.
◆ RTEMS_NO_PREEMPT
This mode constant is used to indicate preemption is disabled.
◆ RTEMS_NO_TIMESLICE
This mode constant is used to indicate timeslicing is disabled.
◆ RTEMS_PREEMPT
This mode constant is used to indicate preemption is enabled.
◆ RTEMS_PREEMPT_MASK
This mode constant corresponds to the preemption enable/disable bit.
◆ RTEMS_TIMESLICE
This mode constant is used to indicate timeslicing is enabled.
◆ RTEMS_TIMESLICE_MASK
This mode constant corresponds to the timeslice enable/disable bit.
Typedef Documentation
◆ rtems_mode
The following type defines the control block used to manage each a mode set.
◆ rtems_interrupt_level_body()
rtems_mode rtems_interrupt_level_body ( uint32_t  level)
Parameters
[in]levelis the desired interrupt level
Return values
Thismethods returns a mode with the desired interrupt level in the proper bitfield location.
Note
This variable is used by bindings from languages other than C and C++.
Variable Documentation
◆ rtems_interrupt_mask
extern
