RTEMS 5.2
irq-extension.h
1
9/*
10 * Based on concepts of Pavel Pisa, Till Straumann and Eric Valette.
11 *
12 * Copyright (C) 2008, 2020 embedded brains GmbH (http://www.embedded-brains.de)
13 *
14 * The license and distribution terms for this file may be
15 * found in the file LICENSE in this distribution or at
16 * http://www.rtems.org/license/LICENSE.
17 */
18
19#ifndef RTEMS_IRQ_EXTENSION_H
20#define RTEMS_IRQ_EXTENSION_H
21
22#include <rtems.h>
23#include <rtems/chain.h>
24
25#ifdef __cplusplus
26extern "C" {
27#endif /* __cplusplus */
28
44#define RTEMS_INTERRUPT_UNIQUE ((rtems_option) 0x00000001)
45
50#define RTEMS_INTERRUPT_SHARED ((rtems_option) 0x00000000)
51
56#define RTEMS_INTERRUPT_REPLACE ((rtems_option) 0x00000002)
57
61#define RTEMS_INTERRUPT_IS_UNIQUE( options) \
62 ((options) & RTEMS_INTERRUPT_UNIQUE)
63
67#define RTEMS_INTERRUPT_IS_SHARED( options) \
68 (!RTEMS_INTERRUPT_IS_UNIQUE( options))
69
73#define RTEMS_INTERRUPT_IS_REPLACE( options) \
74 ((options) & RTEMS_INTERRUPT_REPLACE)
75
79typedef void (*rtems_interrupt_handler)(void *);
80
133 rtems_vector_number vector,
134 const char *info,
135 rtems_option options,
137 void *arg
138);
139
159 rtems_vector_number vector,
161 void *arg
162);
163
170 void *, const char *, rtems_option, rtems_interrupt_handler, void *
171);
172
195 rtems_vector_number vector,
197 void *arg
198);
199
214 rtems_vector_number vector,
215 size_t affinity_size,
216 const cpu_set_t *affinity
217);
218
232 rtems_vector_number vector,
233 size_t affinity_size,
234 cpu_set_t *affinity
235);
236
248 void *arg;
250
254#define RTEMS_INTERRUPT_SERVER_DEFAULT 0
255
266 rtems_chain_control entries;
267 rtems_id server;
268 unsigned long errors;
269 uint32_t index;
270 rtems_chain_node node;
271 void ( *destroy )( struct rtems_interrupt_server_control * );
273
279typedef struct {
284
289
297
305
310
315
323 void ( *destroy )( rtems_interrupt_server_control * );
325
337typedef struct {
338 rtems_chain_node node;
339 void *server;
340 rtems_vector_number vector;
343
355typedef struct {
359
391 rtems_task_priority priority,
392 size_t stack_size,
393 rtems_mode modes,
394 rtems_attribute attributes,
395 uint32_t *server_count
396);
397
424 uint32_t *server_index
425);
426
444rtems_status_code rtems_interrupt_server_delete( uint32_t server_index );
445
464 uint32_t server_index,
465 rtems_vector_number vector,
466 const char *info,
467 rtems_option options,
469 void *arg
470);
471
489 uint32_t server_index,
490 rtems_vector_number vector,
492 void *arg
493);
494
511 uint32_t server_index,
512 rtems_vector_number vector,
514 void *arg
515);
516
538 uint32_t source_server_index,
539 rtems_vector_number vector,
540 uint32_t destination_server_index
541);
542
563
580rtems_status_code rtems_interrupt_server_resume( uint32_t server_index );
581
612 uint32_t server_index,
613 size_t affinity_size,
614 const cpu_set_t *affinity,
615 rtems_task_priority priority
616);
617
632 uint32_t server_index,
634);
635
654 void *arg
655);
656
676);
677
697 uint32_t destination_server_index
698);
699
712);
713
730 uint32_t server_index,
733 void *arg
734);
735
755)
756{
757 request->entry.vector = vector;
758}
759
779)
780{
781 rtems_interrupt_server_entry_submit( &request->entry );
782}
783
796)
797{
798 rtems_interrupt_server_entry_destroy( &request->entry );
799}
800
803#ifdef __cplusplus
804}
805#endif /* __cplusplus */
806
807#endif /* RTEMS_IRQ_EXTENSION_H */
Chain API.
uint32_t rtems_attribute
Definition: attr.h:41
#define RTEMS_INTERRUPT_LOCK_MEMBER(_designator)
Defines an interrupt lock member.
Definition: intr.h:209
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
uint32_t rtems_mode
Definition: modes.h:41
uint32_t rtems_option
Definition: options.h:42
rtems_status_code
Classic API Status.
Definition: status.h:43
uint32_t rtems_name
Classic API object name type.
Definition: types.h:77
uint32_t rtems_task_priority
Definition: tasks.h:55
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
rtems_status_code rtems_interrupt_handler_install(rtems_vector_number vector, const char *info, rtems_option options, rtems_interrupt_handler handler, void *arg)
Installs the interrupt handler routine handler for the interrupt vector with number vector.
Definition: irq.c:127
rtems_status_code rtems_interrupt_server_handler_iterate(uint32_t server_index, rtems_vector_number vector, rtems_interrupt_per_handler_routine routine, void *arg)
Iterates over all interrupt handler of the interrupt vector with number vector which are installed on...
Definition: irq-server.c:461
RTEMS_INLINE_ROUTINE void rtems_interrupt_server_request_destroy(rtems_interrupt_server_request *request)
Destroys the specified interrupt server request.
Definition: irq-extension.h:794
struct rtems_interrupt_server_control rtems_interrupt_server_control
An interrupt server control.
rtems_status_code rtems_interrupt_set_affinity(rtems_vector_number vector, size_t affinity_size, const cpu_set_t *affinity)
Sets the processor affinity set of an interrupt vector.
Definition: irq-generic.c:580
rtems_status_code rtems_interrupt_handler_iterate(rtems_vector_number vector, rtems_interrupt_per_handler_routine routine, void *arg)
Iterates over all installed interrupt handler of the interrupt vector with number vector.
Definition: irq.c:210
rtems_status_code rtems_interrupt_server_handler_install(uint32_t server_index, rtems_vector_number vector, const char *info, rtems_option options, rtems_interrupt_handler handler, void *arg)
Installs the interrupt handler routine handler for the interrupt vector with number vector on the ser...
Definition: irq-server.c:373
rtems_status_code rtems_interrupt_server_resume(uint32_t server_index)
Resumes the specified interrupt server.
Definition: irq-server.c:989
rtems_status_code rtems_interrupt_server_request_initialize(uint32_t server_index, rtems_interrupt_server_request *request, rtems_interrupt_handler handler, void *arg)
Initializes the specified interrupt server request.
Definition: irq-server.c:851
void rtems_interrupt_server_action_prepend(rtems_interrupt_server_entry *entry, rtems_interrupt_server_action *action, rtems_interrupt_handler handler, void *arg)
Prepends the specified interrupt server action to the list of actions of the specified interrupt serv...
Definition: irq-server.c:783
rtems_status_code rtems_interrupt_server_set_affinity(uint32_t server_index, size_t affinity_size, const cpu_set_t *affinity, rtems_task_priority priority)
Sets the processor affinity of the specified interrupt server.
Definition: irq-server.c:1011
rtems_status_code rtems_interrupt_server_initialize(rtems_task_priority priority, size_t stack_size, rtems_mode modes, rtems_attribute attributes, uint32_t *server_count)
Initializes the interrupt server tasks.
Definition: irq-server.c:577
RTEMS_INLINE_ROUTINE void rtems_interrupt_server_request_submit(rtems_interrupt_server_request *request)
Submits the specified interrupt server request so that its interrupt server action can be invoked by ...
Definition: irq-extension.h:777
rtems_status_code rtems_interrupt_server_entry_initialize(uint32_t server_index, rtems_interrupt_server_entry *entry)
Initializes the specified interrupt server entry.
Definition: irq-server.c:766
void rtems_interrupt_server_entry_destroy(rtems_interrupt_server_entry *entry)
Destroys the specified interrupt server entry.
Definition: irq-server.c:824
rtems_status_code rtems_interrupt_handler_remove(rtems_vector_number vector, rtems_interrupt_handler handler, void *arg)
Removes the interrupt handler routine handler with argument arg for the interrupt vector with number ...
Definition: irq.c:175
void rtems_interrupt_server_entry_submit(rtems_interrupt_server_entry *entry)
Submits the specified interrupt server entry so that its interrupt server actions can be invoked by t...
Definition: irq-server.c:793
rtems_status_code rtems_interrupt_server_delete(uint32_t server_index)
Destroys the interrupt server.
Definition: irq-server.c:721
rtems_status_code rtems_interrupt_server_entry_move(rtems_interrupt_server_entry *entry, uint32_t destination_server_index)
Moves the interrupt server entry to the specified destination interrupt server.
Definition: irq-server.c:800
rtems_status_code rtems_interrupt_server_suspend(uint32_t server_index)
Suspends the specified interrupt server.
Definition: irq-server.c:968
void(* rtems_interrupt_handler)(void *)
Interrupt handler routine type.
RTEMS_INLINE_ROUTINE void rtems_interrupt_server_request_set_vector(rtems_interrupt_server_request *request, rtems_vector_number vector)
Sets the interrupt vector in the specified interrupt server request.
Definition: irq-extension.h:752
void(* rtems_interrupt_per_handler_routine)(void *, const char *, rtems_option, rtems_interrupt_handler, void *)
Interrupt handler iteration routine type.
Definition: irq-extension.h:169
struct rtems_interrupt_server_action rtems_interrupt_server_action
An interrupt server action.
rtems_status_code rtems_interrupt_server_create(rtems_interrupt_server_control *control, const rtems_interrupt_server_config *config, uint32_t *server_index)
Creates an interrupt server.
Definition: irq-server.c:656
rtems_status_code rtems_interrupt_server_handler_remove(uint32_t server_index, rtems_vector_number vector, rtems_interrupt_handler handler, void *arg)
Definition: irq-server.c:400
rtems_status_code rtems_interrupt_server_move(uint32_t source_server_index, rtems_vector_number vector, uint32_t destination_server_index)
Moves the interrupt handlers installed on the specified source interrupt server to the destination in...
Definition: irq-server.c:917
rtems_status_code rtems_interrupt_get_affinity(rtems_vector_number vector, size_t affinity_size, cpu_set_t *affinity)
Gets the processor affinity set of an interrupt vector.
Definition: irq-generic.c:604
Definition: chain.h:68
Definition: deflate.c:115
Definition: intercom.c:74
Definition: mmu-config.c:40
Definition: irq-extension.h:245
An interrupt server configuration.
Definition: irq-extension.h:279
size_t storage_size
The task storage size of the interrupt server.
Definition: irq-extension.h:304
rtems_mode modes
The initial task modes of the interrupt server.
Definition: irq-extension.h:309
The task attributes of the interrupt server.
Definition: irq-extension.h:314
rtems_name name
The task name of the interrupt server.
Definition: irq-extension.h:283
The initial task priority of the interrupt server.
Definition: irq-extension.h:288
void * storage_area
The task storage area of the interrupt server.
Definition: irq-extension.h:296
Definition: irq-extension.h:264
An interrupt server entry.
Definition: irq-extension.h:337
An interrupt server request.
Definition: irq-extension.h:355
Definition: chain.h:86
