RTEMS 5.2
barrierdata.h
1
10/* COPYRIGHT (c) 1989-2008.
11 * On-Line Applications Research Corporation (OAR).
12 *
13 * The license and distribution terms for this file may be
14 * found in the file LICENSE in this distribution or at
15 * http://www.rtems.org/license/LICENSE.
16 */
17
18#ifndef _RTEMS_RTEMS_BARRIERDATA_H
19#define _RTEMS_RTEMS_BARRIERDATA_H
20
21#include <rtems/rtems/barrier.h>
24
25#ifdef __cplusplus
26extern "C" {
27#endif
28
38typedef struct {
46
51
61#define BARRIER_INFORMATION_DEFINE( max ) \
62 OBJECTS_INFORMATION_DEFINE( \
63 _Barrier, \
64 OBJECTS_CLASSIC_API, \
65 OBJECTS_RTEMS_BARRIERS, \
66 Barrier_Control, \
67 max, \
68 OBJECTS_NO_STRING_NAME, \
69 NULL \
70 )
71
74#ifdef __cplusplus
75}
76#endif
77
78#endif
79/* end of include file */
Classic Barrier Manager API.
Constants and Structures Associated with the Barrier Handler.
uint32_t rtems_attribute
Definition: attr.h:41
Objects_Information _Barrier_Information
The Classic Barrier objects information.
Object Handler Data Structures.
Definition: barrierdata.h:38
rtems_attribute attribute_set
Definition: barrierdata.h:44
CORE_barrier_Control Barrier
Definition: barrierdata.h:42
Objects_Control Object
Definition: barrierdata.h:40
Definition: corebarrier.h:75
Definition: objectdata.h:39
The information structure used to manage each API class of objects.
Definition: objectdata.h:176
