Here is a list of all documented struct and union fields with links to the struct/union documentation for each field:
- o -
- o6_sp
: Context_Control
- o7
: Context_Control
- obj
: rtems_rtl_unresolv_reloc_s
- obj_num
: rtems_rtl_obj_s
- obj_type
: drvmgr_bus
, drvmgr_dev
, drvmgr_drv
- Object
: API_Mutex_Control
, Barrier_Control
, Dual_ported_memory_Control
, Message_queue_Control
, Partition_Control
, POSIX_Barrier_Control
, POSIX_Keys_Control
, POSIX_RWLock_Control
, POSIX_Spinlock_Control
, Rate_monotonic_Control
, Semaphore_Control
, Thread_Control
, Thread_Proxy_control
, Timer_Control
- object_blocks
: Objects_Information
- objects
: rtems_rtl_data_s
- OEMName
: msdos_format_request_param_t
- offset
: _rtems_rfs_inode_handle
, rtems_fdisk_segment_desc
, rtems_rfs_block_size_s
, rtems_rtl_obj_cache_s
, rtems_rtl_obj_cpmp_s
, rtems_rtl_obj_sect_s
, section_detail
- ofs
: drvmgr_list
- oname
: rtems_rtl_obj_print_t
, rtems_rtl_obj_s
- only_owner_release
: CORE_mutex_Attributes
- ooffset
: rtems_rtl_obj_s
- operation
: MPCI_Internal_packet
- Operations
: Scheduler_Control
- operations
: Thread_queue_Control
, Thread_Wait_information
- ops
: drvmgr_bus
, drvmgr_drv
- option
: Thread_Wait_information
- options
: rtems_fstab_entry
- owner
: _rtems_rfs_inode
, Resource_Control
, rtems_rate_monotonic_period_status
