Device information. More...
#include <drvmgr.h>
Data Fields | |
int | obj_type |
DRVMGR_OBJ_DEV. | |
struct drvmgr_dev * | next |
Next device. | |
struct drvmgr_dev * | next_in_bus |
Next device on the same bus. | |
struct drvmgr_dev * | next_in_drv |
Next device using the same driver. | |
struct drvmgr_drv * | drv |
The driver owning this device. | |
struct drvmgr_bus * | parent |
Bus that this device resides on. | |
short | minor_drv |
Device number within driver. | |
short | minor_bus |
Device number on bus (for device separation) | |
char * | name |
Name of Device Hardware. | |
void * | priv |
Pointer to driver private device structure. | |
void * | businfo |
Host bus specific information. | |
struct drvmgr_bus * | bus |
Pointer to bus, set only if this is a bridge. | |
unsigned int | state |
State of device, see DEV_STATE_*. | |
int | level |
Init Level. | |
int | error |
Error state returned by driver. | |
Device information.
