Here is a list of all documented functions, variables, defines, enums, and typedefs with links to the documentation:
- s -
- SAPI_EXTERN
: basedefs.h
- sched_get_priority_min()
: sched_getprioritymin.c
- sched_getparam()
: sched_getparam.c
- Scheduler_CBS_Budget_overrun
: schedulercbs.h
- SCHEDULER_CBS_ENTRY_POINTS
: schedulercbs.h
- Scheduler_CBS_Server_id
: schedulercbs.h
- Scheduler_Context
: score/include/rtems/score/scheduler.h
- SCHEDULER_EDF_ENTRY_POINTS
: scheduleredf.h
- SCHEDULER_EDF_PRIO_MSB
: scheduleredf.h
- Scheduler_EDF_Queue_state
: scheduleredf.h
- SCHEDULER_PRIORITY_AFFINITY_SMP_ENTRY_POINTS
: schedulerpriorityaffinitysmp.h
- SCHEDULER_PRIORITY_ENTRY_POINTS
: schedulerpriority.h
- SCHEDULER_PRIORITY_SMP_ENTRY_POINTS
: schedulerprioritysmp.h
- SCHEDULER_SIMPLE_ENTRY_POINTS
: schedulersimple.h
- SCHEDULER_SIMPLE_SMP_ENTRY_POINTS
: schedulersimplesmp.h
- SCHEDULER_SMP_NODE_BLOCKED
: schedulersmp.h
- SCHEDULER_SMP_NODE_READY
: schedulersmp.h
- SCHEDULER_SMP_NODE_SCHEDULED
: schedulersmp.h
- Scheduler_SMP_Node_state
: schedulersmp.h
- SCORE_EXTERN
: basedefs.h
- Semaphore_MP_Remote_operations
: semmp.h
- serial_mouse_close()
: serial_mouse.c
, serial_mouse.h
- serial_mouse_control()
: serial_mouse.c
, serial_mouse.h
- SERIAL_MOUSE_DEVICE_PS2
: serial_mouse.h
- SERIAL_MOUSE_DRIVER_TABLE_ENTRY
: serial_mouse.h
- serial_mouse_initialize()
: serial_mouse.c
, serial_mouse.h
- serial_mouse_open()
: serial_mouse.c
, serial_mouse.h
- serial_mouse_read()
: serial_mouse.c
, serial_mouse.h
- serial_mouse_write()
: serial_mouse.c
, serial_mouse.h
- setegid()
: setegid.c
- setpgid()
: setpgid.c
- setsid()
: setsid.c
- Signal_MP_Remote_operations
: signalmp.h
- sigprocmask()
: sigprocmask.c
- sigtimedwait()
: sigtimedwait.c
- sleep_cpu
: sleep.h
- sleep_enable
: sleep.h
- SMP_BARRIER_CONTROL_INITIALIZER
: smpbarrier.h
- SMP_BARRIER_STATE_INITIALIZER
: smpbarrier.h
- SMP_Fatal_code
: smpimpl.h
- SMP_MESSAGE_MULTICAST_ACTION
: smpimpl.h
- SMP_MESSAGE_SHUTDOWN
: smpimpl.h
- SMP_MESSAGE_TEST
: smpimpl.h
- SPARC_ASYNCHRONOUS_TRAP
: score/cpu/sparc/rtems/score/cpu.h
- sparc_flash_interrupts
: sparc.h
- sparc_get_interrupt_level
: sparc.h
- sparc_get_psr
: sparc.h
- sparc_get_tbr
: sparc.h
- sparc_get_wim
: sparc.h
- sparc_get_y
: sparc.h
- SPARC_HAS_BITSCAN
: sparc.h
- SPARC_HAS_FPU
: sparc.h
- sparc_isr
: score/cpu/sparc/rtems/score/types.h
- sparc_isr_entry
- SPARC_NUMBER_OF_REGISTER_WINDOWS
: sparc.h
- SPARC_PER_CPU_ISR_DISPATCH_DISABLE
- SPARC_PSR_CWP_BIT_POSITION
: sparc.h
- SPARC_PSR_CWP_MASK
: sparc.h
- SPARC_PSR_EC_BIT_POSITION
: sparc.h
- SPARC_PSR_EC_MASK
: sparc.h
- SPARC_PSR_EF_BIT_POSITION
: sparc.h
- SPARC_PSR_EF_MASK
: sparc.h
- SPARC_PSR_ET_BIT_POSITION
: sparc.h
- SPARC_PSR_ET_MASK
: sparc.h
- SPARC_PSR_ICC_BIT_POSITION
: sparc.h
- SPARC_PSR_ICC_MASK
: sparc.h
- SPARC_PSR_IMPL_BIT_POSITION
: sparc.h
- SPARC_PSR_IMPL_MASK
: sparc.h
- SPARC_PSR_PIL_BIT_POSITION
: sparc.h
- SPARC_PSR_PIL_MASK
: sparc.h
- SPARC_PSR_PS_BIT_POSITION
: sparc.h
- SPARC_PSR_PS_MASK
: sparc.h
- SPARC_PSR_S_BIT_POSITION
: sparc.h
- SPARC_PSR_S_MASK
: sparc.h
- SPARC_PSR_VER_BIT_POSITION
: sparc.h
- SPARC_PSR_VER_MASK
: sparc.h
- SPARC_REAL_TRAP_NUMBER
- sparc_set_psr
: sparc.h
- sparc_set_tbr
: sparc.h
- sparc_set_wim
: sparc.h
- sparc_set_y
: sparc.h
- SPARC_SYNCHRONOUS_TRAP
- SPARC_SYNCHRONOUS_TRAP_BIT_MASK
- sparc_syscall_exit()
: sparc.h
- STACK_MINIMUM_SIZE
: stack.h
- STATES_ALL_SET
: statesimpl.h
- STATES_BLOCKED
: statesimpl.h
- States_Control
: states.h
- STATES_DELAYING
: statesimpl.h
- STATES_DORMANT
: statesimpl.h
- STATES_INTERRUPTIBLE_BY_SIGNAL
: statesimpl.h
- STATES_LOCALLY_BLOCKED
: statesimpl.h
- STATES_MIGRATING
: statesimpl.h
- STATES_READY
: statesimpl.h
- STATES_RESTARTING
: statesimpl.h
- STATES_SUSPENDED
: statesimpl.h
- STATES_WAITING_FOR_BARRIER
: statesimpl.h
- STATES_WAITING_FOR_BSD_WAKEUP
: statesimpl.h
- STATES_WAITING_FOR_BUFFER
: statesimpl.h
- STATES_WAITING_FOR_CONDITION_VARIABLE
: statesimpl.h
- STATES_WAITING_FOR_EVENT
: statesimpl.h
- STATES_WAITING_FOR_JOIN
: statesimpl.h
- STATES_WAITING_FOR_JOIN_AT_EXIT
: statesimpl.h
- STATES_WAITING_FOR_MESSAGE
: statesimpl.h
- STATES_WAITING_FOR_MUTEX
: statesimpl.h
- STATES_WAITING_FOR_PERIOD
: statesimpl.h
- STATES_WAITING_FOR_RPC_REPLY
: statesimpl.h
- STATES_WAITING_FOR_RWLOCK
: statesimpl.h
- STATES_WAITING_FOR_SEGMENT
: statesimpl.h
- STATES_WAITING_FOR_SEMAPHORE
: statesimpl.h
- STATES_WAITING_FOR_SIGNAL
: statesimpl.h
- STATES_WAITING_FOR_SYSTEM_EVENT
: statesimpl.h
- STATES_WAITING_FOR_TERMINATION
: statesimpl.h
- STATES_WAITING_FOR_TIME
: statesimpl.h
- STATES_ZOMBIE
: statesimpl.h
- strlcat()
: pppd.h
, strlcat.c
- SYM
: m32c/rtems/asm.h
, no_cpu/rtems/asm.h
, m32r/rtems/asm.h
, bfin/rtems/asm.h
, v850/rtems/asm.h
, lm32/rtems/asm.h
- sync()
: sync.c
- SYSTEM_STATE_BEFORE_INITIALIZATION
: sysstate.h
- SYSTEM_STATE_BEFORE_MULTITASKING
: sysstate.h
- System_state_Codes
: sysstate.h
- SYSTEM_STATE_TERMINATED
: sysstate.h
- SYSTEM_STATE_UP
: sysstate.h
