Barrier_Control Struct Reference
This type defines the control block used to manage each barrier. More...
#include <barrier.h>
Collaboration diagram for Barrier_Control:
Collaboration graph
[legend]
Objects_Control Object
 This is used to manage a barrier as an object. More...
rtems_attribute attribute_set
 This is used to specify the attributes of a barrier. More...
CORE_barrier_Control Barrier
 This is used to implement the barrier. More...
Field Documentation
◆ attribute_set
rtems_attribute Barrier_Control::attribute_set
Referenced by rtems_barrier_create().
◆ Barrier
CORE_barrier_Control Barrier_Control::Barrier
◆ Object
Objects_Control Barrier_Control::Object
